Question about KEF Audio KIT120 Theater System
My kef 120 kit theatre system has power but won't fire up. Can't get the disc tray to open and all of the electronic greetings which usually accompany the switch on proceedure. Can you help?
2 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: How to connect Panasonic DMR-EZ25EB to KEF KIT 120
OK for some odd reason I never noticed that this was a reghurgitated question
BUT hey
The only way to really do what you want is to insert an AUTO HDMI switch to the AV1 and go from there.
http://www.monoprice.com/products/subdepartment.asp?c_id=101&cp_id=10110
Have a selection
Posted on Aug 11, 2010
Disc tray is not opening. There is a CD already in the player
if you look closely then you will see there is small hole in the CD tray
push the end of a paperclip into it and it should open
Oct 26, 2013 | Sony DAV DZ610 Music Home Theatre System
Panasonic DVD Home Theatre not reading
Make sure the tray is clean - no debris on tray If the disc is misaligned slightly it will spit it out
Make sure you are not putting them in upside down
and lastly find a new disk (not home made one) and see if this one works
Disks get damaged much easier than people realize\
If nothing works you have no choice but use a proffessional
Feb 06, 2012 | Audio Players & Recorders
KEF KIT 100 DVD not opening. Display says "Open"...nothing happens. Plays the movie currently in the drive. Help...
Did you get the software update to work? I must be doing something wrong..
when I burn the files to a cd-r it says error 4 after the question yes/nowhen i burn them as ISO it says bad disc
Can't get it to work.. too bad, since the system has great sound!
Dec 28, 2010 | KEF Audio KIT100 System
BUT hey
Have a selection
Oct 06, 2009 | KEF Audio KIT120 Theater System
Kef dvd is stuck in tray. It is trying to read it and now wont allows us to eject, change for sat sound NOTHING!! Help!
First you do is to unplug the cord of your DVD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the DVD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the DVD unit and unplug the unit again to avoid electricshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the DVD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you; Regards; VOTIT DONT FORGET TO RATE;
Jun 10, 2009 | KEF Audio Instant Theatre KIT200 System
DVD drawer won't open and no audio on home theatre system
As far as with dvd and cd players in many devices they usually put a tiny hole under the dvd/cd tray. If you open the door with a precision screwdriver and look beneath the tray for a tiny hole and insert the screwdriver into the hole you will feel a gear, push a little more and this is the "emergency release" the disc should pop right out if it is a tray (not a front loader like ps3!) for the audio i need some more info like connections and what cables are being used, analog or digital. hope this helps you out.
May 05, 2009 | Electronics - Others
Kef instant theatre - kit200
Nice player. I'm not lucky enough to own one myself, but I found this info which might be worth a try:
Kef Kit 100 & Kef Kit 200 Instant DVD Theatre handset hacks 1. Press & hold the "Skip Back" button, "Play" button & "Volume Up" button on the main unit.
2. After a few seconds the front display should display "PAL RESET"
3. Release the "keys.
4. Power off your unit at the mains.
5. After 20 seconds, power on your DVD player, thats it!
Oct 27, 2008 | KEF Audio KIT100 System
Kef kit 100 subwoofer buzzing
if you have still the problem, I got the solution from Kef USA. It is somewhat involved in taking the unit apart and replacing a resistor and capacitor. With the instructions supplied any electronic techician or TV repair man can do it in less then 1 hour. email me and I forward the instruction in PDF: Xxel_g@mail.coX . Replace the first X with a and last X with m in my email address.
Jul 13, 2007 | KEF Audio KIT100 System
KEF Audio KIT120 Theater System Logo
142 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Vernon Taylor
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
