I have a 1f56n-444 thermostat and i wanna no what that dial and guage between that cap is
2 Suggested Answers
  • 5 Answers
SOURCE: I own a White-Rodgers manual thermostat...Type
No that is an heat anticipator setting that should be set to the same amperage as the gas valve o your furnace.....do not adjust unless you can tell this or you coulld ruin the thermostat...
Posted on Jan 04, 2011
Does white Rogers thermostat 1f56n-444 have a reset button
White Rodgers 1F56N-444 User's Manual - ManualAgent
www.manualagent.com > White Rodgers Manuals > 1F56N-444
White Rodgers 1F56N-444 PDF User's Manual Download & Online Preview. ... Download Air Conditioners User's Manual of White Rodgers 1F56N-444 for free. .....Set anticipator to match the setting of your old thermostat you noted in Step 3, ..
Aug 04, 2015 | Home Security
Error 444 1993 Isuzu amigo
seen where.???
  1. on the cluster, no way in 1993 ever.
  2. on the radio ? dial. or CD or ?head end, or newer audio systems installed. what brand, what model is it.
  3. on a scan tool ,not in 1993
  4. you went to autozoned and he yelled this over shoulder? run
  5. or its the flash codes from ECU and is 44 and not 444. yes?
  6. or?
Apr 12, 2015 | 1993 Isuzu Amigo
Will not switch off
make sure the one that says "cool, hot, and off" is switched to off.
Mar 02, 2014 | WHITE-RODGERS DIV 1F56N-444 Universal...
My infiniti m35 2006 temperature guage keeps shooting up to hot...I recently replaced the radiator and thermostat...they used a 170degree thrmostat..does that make a difference? Also when they first change...
Okay. You might wanna have them check the temp switch. Also check to make sure that the fans are coming on when they are suppossed to. the temp switch would cause the fans not to work in most cases. This is just short sweet answers. hope this helps and if not ive got more where this came from.
Jan 28, 2011 | 2006 Infiniti M35
I own a White-Rodgers manual thermostat...Type 1F56N-444 (horizontal version). I own a 1-Heat 1-Cool single stage Carrier Electric Heat HVAC system. Pls answer two questions regarding the thermostat: 1)...
Jan 04, 2011 | Heating & Cooling
Model 1f90w-51 the up down buttons stopped working this is a white-rodgers
Electronic Digital Multi-Stage Thermostat 1F83-261
  • 1F83-51 - White Rodgers Installation and Operating Instructions Thermostat 1F83-51
  • 1F86-344 - White Rodgers owners manual Thermostat 1F86-344
  • 1F86-444 - White Rodgers Installation and Operating Instructions Thermostat 1F86-444
  • 1F87-251 - White Rodgers Thermostat 1F87-251 OPERATION INSTRUCTIONS
  • 1F87-51 - White Rodgers Installation and Operating Instructions Thermostat 1F87-51
  • 1F89-11 - White Rodgers Installation and Operating Instructions Thermostat 1F89-11
  • 1F90-51 - White Rodgers OPERATION GUIDE Thermostat 1F90-51
  • Hi, This is a good stat and I have used it alot in the past as it is a older model. If you have 24 volt control voltage at the stat, and the battires are good, then you have a malfuntion in the ciruitry and will need to replace it. I have sent you a ton of manuals on there products I thiught they may be helpful. Please dont forget to rate this post as I know you will be kind. I hope I have been of help to you.
  • Sincerely,
  • Shastalaker7
  • A/C, Heating Contractor
Sep 22, 2010 | Heating & Cooling
Walk through on how to replace a thermostat in a 2001 Jeep grand Cherokee
Jennipherbrr,
1. Make sure the car is cold. Remove the radiator cap (press & turn about 1/4 turn to remove pressure in the system) Once the pressure is bled off you can remove cap and leave it rest on the filler opening.
2. Find the petcock on the radiator (the little valve attached to the radiator. You have to open/turn clockwise to drain the anti-freeze. Drain anti freeze below thermostat housing. About 1/2 to 1 gallon.
3. Have a catch basin for the anti freeze under the car. Remove upper radiator hose from radiator and thermostat housing.
4. Remove thermostat housing from engine block (usually two or three bolts in the thermostat housing). Scrap off ALL old gasket material from engine block. Double check and make sure all gasket material is removed from surface. If not the thermostat housing will leak.
5. Install new gasket with some high temp silicone. Place a couple of dabs on the thermostat housing and gasket (the silicone is used to keep the gasket in place) *MAKE SURE YOU INSTALL the thermostat the same way you took it out. Don't over tighten the thermostat housing bolts.
6. Remove the radiator cap and replace the anti freeze you removed (make sure the anti freeze is clean). Fill the radiator to the top of the filler neck and replace the radiator cap (push and turn the radiator cap to the right- like a pill bottle). Start the car and make sure the temperture guage goes up. The guage pointer should be in the middle of the guage.
7. Check the radiator reservoir for proper anti freeze level. DO NOT OPEN THE RADIATOR CAP WHEN THE CAR IS HOT!!! THE ANTI FREEZE IS HOT AND WILL BURN YOU.
Hope this helps
Apr 19, 2010 | 2001 Jeep Grand Cherokee
Power supply
That depends. It could just be the guage of wire you're using. If using an 8 guage, try a 4. If the amp is running and your headlights dim, then chances are you need a cap instead.
Sep 08, 2006 | Kenwood KAC-9102D Car Audio Amplifier
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
