Question about Bissell Vacuums
I'm trying to replace the red retainers that hold the rollerbrush in place. If I could get a blowupof this assembly it would help alot. Bissell Proheat 7901-1
  • 276 Answers
Follow the link below to the how to video on brush/belt change instructions.
http://www.bissell.com/VideoRating.aspx?id=1555
Posted on Aug 05, 2010
I am trying to replace the belt on my bissell. The directions state "remove the screw that holds the red retainer in place, set red retainer arm and screw aside. I see the red retainer but can not get...
Did you release the handle first before you flipped it over?
Have you removed the screw and it still won't come out, or is it stuck even after the screw is out?
Are you having trouble getting to it?
Please reply back with more info.
Thanks,
Handie Andie
May 09, 2011 | Bissell 1699 ProHeat Clear View Upright...
The belt for the maain vaccume broke off and now with the new belt the roller will not work.
It sounds like your roller brush itself might be bad. Try holding the roller brush holding just the end caps with your finger tips, and spinning the roller. Does the roller spin freely? If no, this indicates that your roller brush's bearings have melted together. This is a common problem for Bissell vacuums, as they use cheaper plastic bearing caps. The roller brush is not covered under the warranty either.
When this part goes bad, this causes the belt to break almost immediately. If you tried replacing the belt, and it broke immediately, your roller brush has gone bad.
Here's a link to the Bissell LiftOff Revolution rollerbrush on our site;
Bissell Roller Brush for Lift Off Bagless
Please leave me some feedback, or rate my solution helpful if this helped you fix your problem. Thanks so much,
Chris Jones
GoVacuum.com
Jan 07, 2011 | Bissell LiftOff Revolution Pet Vac 37602...
Do the roller brushes freeze up?
Bissell rollerbrushes do tend to freeze up. They usually create so much friction to the endcaps and bearings that the ends melt and the brushroll freezes. you should always look for a vacuum which has a metal roller brush they will last alot longer, especially with pet hair.
Jan 02, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Need to replace red clips that hold rolling brush on 7901 Proheat
On the bottom of the machine, near the belt access area,
is a red retainer plate that holds the black brush arm and
brush in place. Using a Phillips head screwdriver remove the
screw that holds the red retainer plate in place. p/n 5559113
Jul 12, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissel pro heat /brushes do not turn
Belt worn or hair build up can clog it from spinning. I've seen this on other models. Just remove the hair slowly. If the Belt is worn you can replace that from Bissel or any store that sells their product.
Check to ensure that the pump belt and brush belt are intact and installed according to the instructions provided in the User's Guide.
The pump belt is located under the belt access door on the side of the machine. This belt should be looped around the red pulley and the silver motor shaft.
To check the brush belt, please follow these directions:
Turn the machine OFF and unplug from the wall outlet.
Step on the handle release pedal to lay the handle down on the floor.
Remove the Tank-in-Tank and SmartMix Bottle and set them aside.
Turn the machine over to expose the brush.
Look for the red retainer plates, which hold the black brush arms in place. Remove the two Phillips head screws to access the toothed brush belt. Check to ensure the belt is intact and looped around the brush end, as well as the red pulley with the ridges.
Remove any dirt or debris from the brush assembly.
Inspect brush, brush arms, red brush arm retainers and red pulley for damage and replace parts if applicable.
Jul 30, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Replacing the brush drive belt on model #1697 carpet cleaner
To replace the Brush Belt:
You will need a Phillips head screwdriver.
1. Turn the machine OFF and unplug from the wall outlet.
2. Step on the release pedal to lay the handle down on the floor.
3. Remove the Tank-in-Tank and SmartMix Bottle and set them aside.
4. Turn the machine over to expose the brush.
5. Look for the red retainers, which hold the black brush arms and gear-type brush belt in place. Unscrew the two Phillips head screws. Set these parts aside.
6. Loop the replacement brush roll belt around the brush end and the red pulley with the ridges.
7. Alternate holding each brush arm in place while replacing the red retainers.
8. Replace the Phillips head screws and turn until snug.
9. Turn the machine right side up to replace the Tank-in-Tank and SmartMix Bottle.
If you require additional assistance, please call BISSELL Consumer Services Toll free at 1-800-237-7691 Monday through Friday from 8 a.m. to 10 p.m. or Saturdays from 9 a.m. to 8 p.m. ET.
Jul 07, 2008 | Bissell Vacuums
Re-assembly after belt replacement
The small red clip has a tab on it to hold in place while putting back on. put the screw in the hole in clip and use tab to guide into place. if there is no tab, then you need to obtain a new set of clips, very inexpensive. the laege red clip is easy to put on since it goes into a groove and can't go on backward.
Jun 12, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7950 ProHeat Self Propelled Carpet cleaner Replacement Pump Belt part 215-0628
Normally, there is a post sticking out of the retainer to remove it. If the post is broken off, then you will have to lift the black arm and wiggle it at the same time and the retainer will pop up so you can remove it. On the belt side, the retainer is fairly large and you can usually get a hold of it with a pair of needle nose pliers. On the other side, the retainer is small and you can lift it out with the pliers by griping it gently using the hole that the screw goes through.
Jan 27, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
ADJUSTABLE BRISSLES
You may have to replace the brush roll retainers, part #5559113, you get borth sides with this part number. After you get the part, turn the unit on its side, at each side there is a red part with one screw holding it in place, take out that screw and pull it out, then you can pull the end caps out, replace them and re-install.
Jan 26, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Bissell model 8910 carpet cleaner
Depending on which style you have, it may have a opening on the right side as you look at the front of the machine. If not you may need to remove the cover. If it does it says "belt access" and has two 1/8" (about) slots in the cover. with a small screw driver or something similar insert tool into slot and gently pry(if you are looking from the side) the left slot up and towards the right and the right slot up and to the left. It will slowly (or quickly depending on how hard you have to push) pop up and you can slide it off and see the pump. I think it is easier to just remove the 4 screws that hold the pump in place so you can replace both belts at the same time and not struggle with having to stretch the new belts. The last time I did this the Sprocket(small metal peice with teeth that turns the brushes) had broken off. I cleaned and dried everything and used 30 second epoxy to glue the sprocket back on and it works fine lasts a long time. Once you have removed the 4 screws holding the pump you can use a flashlight and screwdriver, knitting needle, pen etc. to hook the belt from the brush on to the pump shaft(sprocket) very easy. You may need to tilt and angle the pump a little to gt the belt over the lip on the sprocket. Like I did when I did this you will need to put the smooth belt on over the pump shaft first then put on the brush belt and screw the pump back into place (4 screws just snug because you can easily strip the plastic mounting holes) and put smooth belt on the electric motor shaft. you may need to stretch the belt a little because it has no gears it is just friction that turns the pump. Clean and dry everything this will make this repair last longer. If you will take a few minutes after each use to clean at least around the belt area they will last a long time. You can even put a belt conditioner on them for added life. Have a wonderful day!!!!!
Oct 20, 2007 | Bissell 8910 ProHeat Clear View Upright...
Vacuums Logo
49 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
