Question about Dell Latitude D600 Notebook
Dell latitude d60
Ok, we have narrowed it down a little i think. normally, it won't boot up at all. my husband took a memory out and now it boots up but operates at about half speed. what could be wrong?
Your husband took memory out which i assume was 1 out of the 2 memory chips in that computer.  Buy a new memory chip (RAM) to replace what you took out and found was bad.  You can also try creating a floppy or CD from a program called MEMTEST 86+ (google it) and run it with one stick of ram in.  This test runs infinite but if you get any red after 10 to 15 minutes then stop and place the other stick in and remove the one you just tested and repeat and anything that showed red lets you know its a bad stick of RAM.  Though it sounds like you only have one bad stick (the one you removed)
Posted on Apr 30, 2008
Dell xps 600 will not display any picture at all, beeps six times lights 2 and 3 are lit on front diagnostic display. Replaced memory with working ram from another pc, replaced pcie graphics card with...
sounds like youv'e covered all the possibles i would. could be the boot files got corrupted or the monitor is bad(have you checked it with another pc?) check the motherboard for swollen capacitors(those barrell looking objects randomly scattered over board. if the tops that have little crosses on them (+) are popping up/out unlike others, then your board needs replacement or new pc. cannot fix those. happened to a friend of mine. would not boot up to show windows.
Nov 03, 2013 | Dell XPS™ 600 PC Desktop
Dell 500 start up problem
Sounds like a memory problem.
Try to remove the memory from your laptop.
If you have more than one dimm, take one out and see if it boots, then replavce the one you left in the laptop and see if it boots.
If your laptop boots with one dimm reinstall the memory and make sure they are snug.
Good Luck, hope this helps, have a great day.
Nov 19, 2009 | Dell Latitude D600 Notebook
Loooong boot up issue on Dell Latitude C610.
Did you buy this from an individual? The computer is no speed demon at 1-GHz/733-MHz Pentium III-M CPU, 256MB of SDRAM, 512KB L2 cache, however it should not take 18 minutes to boot.
If I were in your shoes I would reformat and reinstall the OS and start over, especially if you got this from an individual.
The boot time should greatly improve! I think it is loaded down with the bloat of **** the last person had on it.
If you do not want to reformat, here are some tips, and programs to run to increase performance.
go to start - run - type msconfig hit enter,
startup tab uncheck everything not needed at startup time. - get it and run it on the laptop, clean it out. Make sure you run the registry cleaner too!
Make sure you run a good online virus scan! like trend micro house call.
That should speed it up a little if you cannot reformat it and start over.
Mar 06, 2009 | Dell Latitude C610 P3 Notebook
I got desktop rebooting that was solved by memory replacement, you have to determine what worked prior to the error and revert any change to another method
Jan 29, 2009 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Acer Aspire 5315 won't boot, black screen
I had the same symptoms on friends laptop. She had nothing to lose so gave me carte blanc.
Took out battery (to eliminate as problem) plugged in power, and powered up
Power light OK, HD flashed, CD flashed, then black screen. Powered down.
Did the following:
1) took cover off of fan/circuit board (see for details). (4 screws)
2) take out fan (3 screws) and find huge amount of gunk on cooling fins at fan disch. Blew out with compressed air. Also cleaned fan blades.(reboot shows didn't fix.)
3) Repeated step 2, Pulled out memory sticks and cleaned terminals by rubbing with lint free cloth. Replaced memory sticks.
4) System boots normally. Replaced battery. Boots normally.
Jan 05, 2009 | Dell Latitude D600 Notebook
Dell laptop Latitude c 810 BIOS revision A12
Your laptop's memory is malfunctioning. To remove the memory, power down your laptop.
Turn it over and you should see a cover about the middle of the back. Open it and there you should see the memory. You may or may not have more than 1 memory Dimm. Also there are 2 slots. The bad memory is the one in the first slot. Take it out and put the other in it's place. the laptop should boot up ok, but slower because of the missing memory which you should replace.
If you get the same message, replace the memory with the one you took out, then reboot.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 14, 2008 | Dell Latitude C810 Notebook
Internal Battery Problem?
This is what we call a "NO POST" problem. You need to contact Dell Tech Support for this to narrow down the issue to a part. This could be caused by any part that is not letting the computer to power on or boot up. Note: You may need to tear-down the computer for this issue whe call tech support.
Dec 09, 2007 | Dell Latitude C400 Notebook
Users manual for model PP01l dell
What is the full Name and Model? For example, Dell Latitude PP01L C610
Sep 14, 2007 | Dell Latitude C640 Notebook
Dell Latitude D600 Notebook Logo
691 people viewed this question
Alun Cox
