Question about Coleman Mach 15 Air Conditioner
I have a 1988 Prowler TT with a Coleman TSR Mach3. I've installed a new blower motor.The fan side works fine on high and low but when i move the selector to High Cool the compressor does not turn on..however when i move the selector to Low Cool the compressor turns on and it cools for a few seconds then locks up..now fan no cool air. Any ideas?? Is there a way to change/add oil to these units? Thanks, Hot in Alabama
SOURCE: coleman tsr mach 3 RV Air Conditioner
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
Posted on Dec 31, 2008
  • 340 Answers
SOURCE: broken selector switch on Coleman TSR air
you need a control if the center came out if it is just the plastic knob appliance parts store or google it. Tom
Posted on Jun 18, 2009
  • 82 Answers
SOURCE: coleman tsr rv air conditioner leaks into rv when running
It probably has a clogged condensate drain. Take off the cover on top the RV and check hoses or tubes leaving unit for debris or lint. Often this water is used to help cool the condenser so look for leaves pine needles etc in the pan. There may be a cover you can remove on the evaporator section that will allow you to clean the collection pan and hose or trough. Is it possible the RV is far enough out of level that the condensate can't "run uphill"? Always power off while working on this unit unless you are electric savvy. Good luck!
Posted on Jun 28, 2009
motor1258
  • 6674 Answers
SOURCE: coleman tsr roof ac does not cool 27' rv i've
Is this a new unit/RV by any chance?
Posted on Jul 23, 2009
BIKER T
  • 909 Answers
SOURCE: Coleman TSR Mach air conditioning roof mount trips breaker
The simplest answere to start is it' looks like the compressor is the ssue." Either it has siezed"or in my oppinion needs a proper household power to activate it. If the voltage drop on these units is a little below a certain value, it will not start and will burn out. Thats why i suggest a household power be tried first. I feel your generator is a little undersized. You will only know once you have applied household power.
Posted on Sep 23, 2009
1992 chevy C1500: Heat works on low speed, no medium, and high only works intermittantly.
On any other vehicle it sounds like the blower fan switch.
The fan switch provides power or ground to the resistor and there would be a high speed blower relay to bypass the resistor.
But in your case the fan switch is part of the controller.
I don't have a diagram for a 92 but the 94 model shows relays for low medium and high speeds. Each relay gets power from a fuseable link. The high relay gets power thru the low relay if the low relay is not engaged.
If you have the model with 3 relays you may need to check them.
Feb 01, 2013 | 1992 Chevrolet C1500
High side of fan motor trips breaker , low side cools just fine. can fan be replaced or do i have to replace whole unit
So, the condensor fan motor trips the breaker? Have you checked the run capacitor? It can easily be checked with a multimeter.
Aug 02, 2011 | Coleman Heating & Cooling
01 grand.prix ac fan switch only works on high. has a duel temp controller when you turn fan off the only way fan comes back on is to move the temp controller levers
Hi!!
When the Blower Motor Resistor (controls blower speeds) goes bad, the blower motor works only on HIGH SPEED. REPLACE IT.
BLOWER MOTOR RESISTOR Removal & Installation
  • Disconnect negative battery cable.
  • Remove right lower instrument panel insulator panel.
  • Disconnect blower resistor connector located behind right side of dash.
  • Remove blower resistor screws and blower resistor.
To install, reverse removal procedure
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Feb 18, 2011 | 2001 Pontiac Grand Prix
Replacement fan motor for coleman mach3..need wiring diagrm
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Apr 14, 2009 | Coleman Mach III Air Conditioner
What are the 1st 3 blower settings for?
Those are for the run time of the circulating fan after the heat has been satisfied.
Jan 26, 2009 | Coleman Mach 15 Air Conditioner
Tsr mach3 conditioner
The smell is because of the stuff growing inthe water from the air conditioner. When you run the a/c it keeps the water condensed on the coil. When you turn the a/c off and run just the fan, it allows the water to warm up and start evaporating thus allowing the goodies in the water to become airborn. It would be adviseable to have the unit disassembled and cleaned by a professional due to the obvious danger of mixing water and cleaning chemicals with electrical equipment
Jun 25, 2008 | Coleman Mach 15 Air Conditioner
Coleman tsr mach 3 RV Air Conditioner
I don't think you need a new one just a good cleaning and service. The unit has a liquid high temperature line near the compressor with a fan blowing outside air across it this coil gets clogged over time with air-borne dirt and pollen and leaves and such and must be cleaned regularly or the unit will be unable to remove the heat from the coil and during the peak demand (3pm) the circuits that protect the compressor and the trailer wiring from being overloaded and burning or melting will trip. From what you have described it sounds like the RV is working as it should with a condenser coil that needs to be cleaned. GL and happy camping!
P.S. I've only serviced the occasional RV unit but in those cases I laid a piece of plywood on top of the Rv for work platform removed the retaining screws from the top cover and used a spray bottle with a good heavy foaming cleaner a shop-vac and a brush to get the job done.
Jun 11, 2008 | Heating & Cooling
May 20, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
49 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
