Question about Dell 5110cn Laser Printer
PAPER JAM, 071-101, REMOVED PAPER JAM, CLOSED TRAY, AND IT JAMS AGAIN
Soulvisitor
  • 1113 Answers
SOURCE: Paper Jam
We need to the model/make to help you
but using some detective skills I've decided you are using a HP machine
Yup Dirty damaged worn feed roller but what model machine is it they are all different but pull out tray 2 cassette all the way and look in, there is probally a cylinder like rubber roller 5cm wide front centre of where cassette slides in, there might be roller on the cassette too at the front center as well.
Most modern printers feed rollers just slide off after lifting small plastic tabs on them and gently pulling, feed rollers are available but you can sometimes also get results by cleaning them with a dash of metho or water on a rag.
If paper feeds 2wo sheets at once then you need to change the seperation pad/roller too.
Posted on Nov 01, 2007
printech
  • 159 Answers
SOURCE: HP 4350n Printer says paper jam .
check the paper sensor maybe one of the sensor stuck
Posted on Mar 17, 2008
mohammed387
  • 1952 Answers
SOURCE: Paper Jam on Rear
clean this roller
Posted on Jan 22, 2009
  • 49 Answers
SOURCE: How to solve repeated paper jams in Dell 3010 laser printer
Replace the pick rollers. If you're out of warranty it'd be mighty expensive to have Dell replace them, but, if you call them, they can get you access to a website (I can't remember the name...sorry) that has walk through tear-downs with pictures of each and every step. (Only do this if you're handy and have time)
Otherwise, replacement is the next option.
Typically Jams on this unit are from worn rollers. :)
Good luck.
Posted on Feb 27, 2009
  • 300 Answers
SOURCE: 241 paper jam
Check the paper tray guides, check the the paper feed roller (remove the tray and look up in the printer) it is possibly worn and needs replacing, you can try to clean it (hand soap is as good as anything)
Posted on Apr 24, 2009
Will not print - paper jams - when open the back cover paper comes out on its own
Remove the paper from behind the back cover, then remove the paper tray and check for any other jammed paper. Once you've removed it all, turn the printer off then back on. Before printing again, take the paper out of the tray, fan it out, and flip it over so it's upside-down. (Paper curl and static can cause jams, and turning the paper over can often correct those issues.)
Does it still jam?
Mar 12, 2011 | Brother MFC 240C All-In-One InkJet Printer
IBM 1332 printer error #241 Paper jam
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
  • Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Oct 04, 2010 | IBM Infoprint 1332 Laser Printer
Help i have a paper jam!
Jul 20, 2010 | Epson Stylus NX300 All-In-One InkJet...
Major Paper Jam on Dell 5110
If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair. *
To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer. Preventing a printer paper jam As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer.
However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring. * If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled. * Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams. *
Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer. * Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper. * Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 17, 2009 | Dell 5110cn Laser Printer
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
After printing a page, 2 red light signals show and doesn't print anymore until after certainparts of the copier were opened and then closed. When the swiych in turned on again, it copies only 1 and then...
1)check properly if there is no paper jam, make sure all jams have been removed
it this doesn't work
2) Remove the paper in the paper tray and replace with papers tha do not have folded edges
Make sure you are not using a paper that cannot run smoothly through the photocopier (too light or too hard)
3) Also check if some papers are stucked under the paper tray.
Apr 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
Paper jam
For this and any other print jam problems try this;
Open the scan bed tray and push down the button at the front (scan bed tray open switch)
I found if your print jam occurs and you go through this procedure, the jam clears itself.
With the tray still up and switch held down, try and print something.
See how far the paper goes through the print cycle before jamming. If it jams when it reaches the print head...clean under the print head and try again.
Hope this helps
Mar 17, 2009 | Brother Multi-Function Center MFC-665CW...
Paper jam without any paper deskjet F370 all in one
Here is the most important thing to understand about paper jams in any printer....
The printer does not know if there is a paper jam anywhere in the printer.
What it does do, is respond to sensors ( optical sensors, either open or closed, by plastic flags). These flags are moved as paper moves through the paper path.
One example of a paper jam message when there is really no paper jam, is when the feed rollers are worn and do not pick up paper from the paper tray.
When you start printing, the printer expects that first sensor to open ( paper passes the sensor ) at a very specific point in time. If the paper did not get picked up from the tray, then the printer will ASSUME that the paper must be jammed somewhere because it did not reach it on time.
Now this will also happen if in fact the paper did get picked up and then jams prior to the sensor.
So... if you get the picture of how this works, understand then too, that if the printer is showing a paper jam message at power on, then one of the flags is open when it should be closed.
If you do not actually have a piece of paper holding this flag in the open position, then the flag is possible broken.
I usually see this kind of damage occur after a true paper jam, where the paper is removed either in the wrong direction ( pulled out back the way it was going instead of the way it should normally travel ), and this breaks the flag, or it was pulled out forcefully again, catching on and damaging the flag.
All of the above pertains to ANY printer, and not just yours. you must take care to fully inspect every inch of the paper path, from the paper tray, to the exit, use a flashlight, and look for the sensors and make sure they are not blocked or broken.
Good luck,
Cory
Nov 06, 2008 | HP DeskJet 3930 InkJet Printer
Paper jam
Good luck,
Cory
Nov 05, 2008 | Brother Multi-Function CenterĀ® MFC-215C...
Dell 5110cn Laser Printer Logo
264 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
