Question about Daewoo Refrigerators
Leaks water from bottom left hand side every couple of days.I have taken off and cleaned rubber cap at bottom of fridge which was blocked.It looks like the tray had not seen water for some time and was dry and dusty. Still it leaks! Can you help please?
  • 4,070 Answers
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer
Posted on Aug 04, 2010
How to remove back panel of GS2326CEDW/11 Admiral fridge freezer
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. Also note on the maytags these days they put a rubber piece called a duck bill on the bottom half of the drain which will also cause this over time. To access this piece you'll have to pull the machine from the wall and remove the lower panel and find the plastic drain and remove the duck bill
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 29, 2012 | Refrigerators
How to replace a water pump on a 2004 dodge cummins motor, 3500 4x4 dulley
Replacing the water pump on my 2004 5.9 cummins 1ton Dually was easy,Disconnect neg. batt. cables, drain coolant,released serpentine belt tensioner with 1/2" drive ratchet and while in released position slipped belt from ac compressor,removed two bolts that held alt. to brackets, slipped alt. to one side then removed upper alt. brkt., removed two bolts on water pump, made sure mounting surface of block was clean and took new water pump put a small amt. of rtv sealant all around groove that rubber seals goes in,install rubber seal, "be sure and wipe off excess sealant then re-install water pump tightening carefully,reinstall alt. upper brkt., then alt. put belt back in correct position but be sure and leave it off of ac pulley so you can reinstall it on ac when you are underneath the eng. area while releasing tension on belt tensioner. Fill with proper coolant type till you have rad. full. Reinstall cables, start eng and with cap off you will have to add coolant as eng. warms up till it has air out of system. Once rad. is full install cap then refill coolant recovery bottle to full level, Keep and eye on it for leaks for a couple of days and "Happy Driving" Don't think I left anything out :)
Feb 24, 2011 | Dodge Ram Pickup 3500 Cars & Trucks
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Acquired second hand electrolux er3167bn fridge freeze. worked ok for about 10 days then fridge started to get warm, eventually ended up room temp. engineer said to switch off fridge freeze and leave for...
yep sounds as though it is iceing up after it runs for a couple of days
you may have a defrost heater or defrost timer not working
the fact it didnot have water in the tray, you prob have a blocked drain as well
May 02, 2009 | Electrolux ER3167BN Bottom Freezer...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Compressor very hot + water leaking
This is not normal. The coolant charge is low which means it leaked out some where. Return it.
Dec 22, 2008 | Sub-Zero 650 / O Bottom Freezer...
Water leaking from fridge
Hello I had a problem close to this, at the back of the fridge on the bottom you should find the motor ,sitting on top of the motor there should be a small cream plastic catch tray if you dont have one this may be the problem as the motor evaporates the excess water, Hope this helped. djdizzys
Feb 14, 2008 | Refrigerators
Tempature on fridge won't stay @ 38
might be freezing on the evaporator faulty defrost timer or drain is blocked water should run down back bottom tray
May 10, 2007 | Samsung RS2630SH Side by Side Refrigerator
Fridge leaking oil on the bottom right side
OK, usually if you see an oily substance that you are sure is not from the fridge contents it's oil from the sealed system. When a leak in the sealed system happens the refrigerant gas leaks out and the lubricating oil also leaks out. I'm afraid you may be in this situation. As the refrigerant leaks out the cooling efficientcy drops off quickly and eventually there is no cooling at all. You would have to use a refrigerant leak detector "sniffer" to locate the leak and then have a certified company repair the unit. Sadly, the cost to do a compressor replacement and leak repair is 2/3's or more the cost of a new fridge...
Jan 15, 2007 | Frigidaire GLRS237ZA Side by Side...
Refrigerators Logo
226 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
