Question about Audiovox Car Audio & Video
I need a manual for Audiovox AVCC 100 cable switch box
How do I deactivate my aps57c mobile audiovox alarm
  • Locate the push-button LED switch on the alarm box under the driver's side dash. The small red or black button is used to manually disable the alarm.
  • Put the key in the ignition and turn it to the "on" position. This activates your vehicle's battery, but doesn't start the engine. Press and hold the push-button LED until the LED light stops blinking. Once the LED stops blinking the alarm is disabled until you manually reset the alarm.
  • Start the car. Then, press and release the push-button LED switch once, to reset the alarm.
Apr 01, 2017 | Audiovox Vehicle Parts & Accessories
Audiovox Manual FR230-2
Audiovox has the manuals for many of their products on their web site. See http://www.audiovoxproducts.com/ and then click the button for Manual before you enter the product model number (before the dash) in the search box. The -2 in the model number only indicates that the box had a pair of FR230 two-way radios. The direct link to the manual is http://voxxintlcorp.com/docs/common/FR230/FR230_OM.pdf . You will need Adobe Reader or a similar program to access the manual.
I hope this helps.
Oct 27, 2013 | Audiovox Walkie-talkies
The Audiovox Rca RCRN04GR Universal Remote Control
Try to Google the model numbers of each for "manual" to see if available.
Jun 07, 2012 | Audiovox Rca RCRN04GR Universal Remote...
Manuals
Google the model number of the remote for a manual with the codes for the unit you want to try to program if for.
I am trying to hook my audiovox dv1202 up to a TV. The video is working, but I cannot figure out how to connect the audio.
The manual helps.
Register and download it for free at retrevo.com
http://www.retrevo.com/support/Audiovox-DV1201-Home-Theater-Systems-manual/id/363ag023/t/2/
Break it down. DVD Video goes TO the TV but you want the >>>audio<<< for TV programs FROM it, or perhaps from wherever IT originates. Your TV no doubt has audio output(s) that will work. If you have a Cable Box it, too, will have superior audio outputs. Unfortunately, this unit is NOT an AVR or it would be able to accept coaxial Digital Audio Output from a Cable Box or other source. Instead you have to use the AV IN RCA jacks (Item B, page 12) from either the TV or the Cable Box. You're stuck with analog 2-channel audio.
Jun 19, 2011 | Audiovox DV1201 System
I have a XM Model 136-4335. I need an operators manual. I need to program preset stations and don't know how. Thanks, Mike
The XM model number provided is branded DELPHI but is actually made by AUDIOVOX... a manufacturer that is commonly rebranded XM, TERK, RCA, etc. So the Audiovox manual is what you need. Now since Audiovox usually doesnt support directly its hard to get manual from them directly. The link to your manual (the third down on this page and the picture looks a bit diffferent but is the silver receiver not black box ones) Good luck
http://www.retrevo.com/support/Audiovox-XM-Satellite-Receivers-manual/id/395ag115/t/2/
Jun 02, 2010 | Delphi XpressRC XM Satellite Radio...
No manual in box for Audiovox PVS72901
I had the same issue. After searching the net & the Audiovox website (this model is not listed on their website BTW) for a downloadable copy, I emailed the Audiovox helpdesk. Within an hour, they had sent me a pdf file of the manual. You can download it from: here
Apr 06, 2009 | Audiovox PVS72901 Portable DVD Player
Front audio connections
OK, let the speaker cable be your guide, its a for pin female connector, form there you should find your way.
let me know
Dec 15, 2007 | A-Top XBlade Mid-Tower Case
AUDIOVOX CDA 100 AM/FM/CD setting clock
SETTING THE CLOCK - AUDIOVOX CDA-100
  1. Turn the vehicle ignition and radio "on".
  2. Press and hold the Time/Frequency Selector button approximately 2 seconds until the time display begins flashing on the display panel.
  3. Within 5 seconds after the time display begins flashing press the Manual Down Turning button (<<) to adjust the hours and the Manual Up Turning button (>>) to adjust the minutes to the correct time.
  4. Five seconds after the last hour or minute adjustment is made, the time will be set in the unit and normal operation can resume.
Contact Audiovox.com or 1-800-688-3135 and they will email (PDA) or fax a copy of the manual.
Oct 17, 2007 | Audiovox AM/FM/DVD/CD/MP3/WMA Receiver...
Car Audio & Video Logo
517 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
