Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
The mower is not cutting even. we changed the blades and leveled the deck but can not seem to fix the problem
    New Friend:
Had this problem and found it to be one of the housings that holds the shaft for one of the blades had cracked causing the blade to wobble. Replaced it and works fine now. Hope this helps.
Posted on Jun 02, 2014
    Brigadier General:
  • 3,911 Answers
Everything sounds and looks good but the cut is uneven. I would think the only possibilities are a freewheeling blade, or an upside down blade. Neither situation is rare. If neither of those is possible I think I would set the whole thing up on jack stands and make sure nothing is going akilter in the mechanism which raises and lowers the deck, one side could be hung up.
Posted on Aug 05, 2010
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
Husky yth1542xp. I've changed the blades, leveled
When levelling the deck, rotate the blades so that the right blade has one of its cutting edges at or near the right side center of the deck. Do the opposite with the left. Measure to the blades from the level ground, not to the deck. Try leveling that way.
Gary
Jul 03, 2011 | Husqvarna Garden
LA110, 42" mower deck, 1
Check that the cutting tip of the blade that is cutting lower is not bent down. Also park the mower on a level surface and lower the deck and check the gap under the front of the deck is even. If not, there are levelling adjustments on the top of one side of the deck. Regards Phil
Apr 15, 2011 | John Deere 195HP Hydrostatic 42" Cut...
42 inch jd la115, hit stump in yard, changed blade cause I thought I bent the baldes still cuts uneven. Could the shaft be bent or broken? It appears to be cutting properly on the right side but the left...
try pushing the blade up into the deck,,,if there is any lift in it there is the fault,,the top nut has come off the blabe drive pully and let the drive shaft drop a little this will lower the cutting blade,,,fix it before the blade falls right out
Aug 15, 2010 | John Deere Garden
My mowers cuts uneven I replaced the blades but it still cuts uneven how can I level it?
Park mower on a level flat surface ( a concrete garage floor is ideal ) lift deck up until you can put a piece of a 2x4 flat underneath the deck and lower deck until it just contacts the 2x4. loosen adjustment nuts or turnbuckles and adjust until the deck just starts to clear the 2x4. this should level your deck. Now , lift the deck and remove the 2x4. put blade height lever on a known cut length and with a tape measure, measure the tips of the blades from the floor to the blade tip...they should all be the same within 1/8 of an inch...if not then you either have a bent blade, bent spindle shaft, or spindle bolts are loose or misaligned. Your deck could be warped too...depending on how hard a lick it took...good luck !!! ;-D
Jun 24, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
WHY IS CUT UN EVEN? MOWER LEAVES LINES IN LAWN
My 10 steps to ensure even cutting for any riding mower.
1. The rear tires must be the same diameter i.e. same tread type and the same amount of pressure
2. Level the deck following the instructions in the manual
3. Make sure the blades are not damaged or bent.
4. Make sure the deck nor its attachments are bent
5. keep the blades sharp and don't drive too fast when mowing.
6. Over lap rows about 20%
7. Cut the grass at intervals that ensures you never cut more than 1/3rd the total length of the grass.
9. Make sure the underside of the deck is free from chunks of clippings.
10. Use a blade with higher lift, yes you have to match the blades to the type of grass you cut most often, (commercial mowers use a universal blade and high speed decks).
Jun 18, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
2003 DLT3000 Craftsman riding mower. Air in tires correct, deck level front/back & side/side, new blades.. Still cuts uneven. Does this deck flex when cutting tall grass & how do I fix this...
when you put the new blades on did you notice if they were even with each other? the 42" decks have a tendency to "warp" inward on the left side. this causes the left blade to ride at an angle to the right blade - there is a tool to correct this, but not all shops have it - sometimes you can remove the deck, flip it over and wallop the inside edge of the left mandrel until the blades are even - a 2 lb. sledge works well for this
Aug 26, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Its not mowing evenly
You need to level the deck. On most mowers you level the deck from side to side evenly but have the front of the deck 1/4" lower than the back.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Uneven cut
1-----------tire pressure? 14 front 10 rear
start with a level mower on a level surface
2------------deck level side to side?
3------------deck level front to back? (front can be 3/8 lower than back)
4-----------deck hangers bent or hung up?
5------------blades even when pointing at each other? no more than 1/8 high or low
6------------blades dull or upside down? turned up ends go towards deck
7---------------incorrect blades for mower?
8------------deck lifting mechanism should pick up deck evenly and drop evenly?
9-----------under the deck need cleaning because it is packed with grass?
Jun 15, 2009 | Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
361 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
