Microwave Ovens Logo
Posted on Aug 04, 2010
How do I reset my panasonic inverter dimension 4 microwave after turning it off at the mains?
5 Related Answers
A
Anonymous
  • Posted on May 26, 2008
SOURCE: Panasonic Dimension 4 the Genius
i had to take the entire cover off the microwave (it is held in pace by screws at back as well as the bottom). Take the busted bulb to hardware store (bunnings) or panasonic spares and replace. Note I have a slightly different models (nn9853, nn9807).
AH
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 12, 2008
SOURCE: PANASONIC NNC753BBPQ DIMENSION 4 800W MICROWAVE
You will find that here.
-.htmWe're happy to help and we appreciate your thoughtful rating of our answer.
Anonymous
  • Posted on Aug 23, 2008
SOURCE: Panasonic Dimension 4 Turbo Bake
Your Magnatron is most likely to have failed, its an expensive part and on a turbo 4 could be 2M236-M42. Unfortunatly this appears to fail due to reduced air flow. So if you do replace it I would clean the rear grills completely to increase the airflow within the oven.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 07, 2008
SOURCE: Stuck in Demo mode
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
If that doesn't work, check the owner's manual.
You should be able to download your Panasonic owner's manual here.
David Hanks
  • 178 Answers
  • Posted on Sep 14, 2009
SOURCE: Need a users manual for a Panasonic Dimension 4
http://www.retrevo.com/samples/Microwave-manuals.html
Hope this helps!!
Panasonic invertor Dimension 4 Genius NN-CD997S. Comes on for about 2sec then switch automatically to cool...happens with all the functions
Inverter or Mag $ !!!! Probably time for a new unit. If Possible, Stay away from those Horrible Inverters!!!
Panasonic Dimension 4 Microwave- Model NN D801. Whilst microwaving for 2 mins on high - heard a zapping noise. Didnt heat food. Front operating panel works. turntable still works. Any suggestions?
A "zapping noise" usually indicates a problem in the high voltage circuit. If it's an inverter oven, it should have provided you with a fault code. If a non-inverter, the most likely causes are a shorted high voltage rectifier or bad magnetron. But there are many other possible causes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
1helpful
After entering time to cook, then press start, Panasonic microwave Dimension 4 NN-CD987W .. Code appears H97
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
5helpful
HOW DO I UNLOCK THE panasonic dimension 4 Genius inverter NN-C20035
Its a child lock if your suffering with the same thing as us,My six year old brother managed to lock the microwave,all it displayed was a frustrating 'LOCK' message.to fix it i just hit the 'stop/reset' button three times
1helpful
Panasonic Dimension 4 microwave switches off
Try resetting it--aka, unplug for about an hour, then plug back in and try again. If that doesn't work, make sure you try a different outlet, and if all else fails, contact Panasonic. They should be able to help you out with a repair/replacement (and if you're still under warranty, usually it'll be free!).
Their phone number (acccording to their website, www.panasonic.com ) is 1-800-211-PANA (7262)
Good luck! :)
1helpful
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
1helpful
Faulty Panasonic inverter dimension 4 combination microwave
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
2helpful
Panasonic inverter dimension 4 microwave oven runs for 27 secs in micro mode then cuts out no heat either convection oven grill work fine ????
I would recommend that you contact your nearest Panasonic-authorized servicer.
42helpful
5answers
Panasonic Microwave Dimension 4 convection (11 yrs old)
You need to press clock 3 times, then start 3 times and then clear/reset 3 times. Then you can reset the clock by pressing clock 1 change the time and press clock again.
Top Panasonic Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
