Question about Toshiba 57H84 57" Rear Projection HDTV-Ready Television
Picture flutters vertically - Toshiba 57H84 57" Rear Projection HDTV-Ready Television
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Many of these sets (57H84 etc) had a problem with the "Hyper" board.
It is a circuit in the set that processes all signal from the tuners, and all inputs.
Most of the time this problem shows up when the set is first turned on and after several minutes the picture goes to normal----the delay if you have this problem slowly gets longer and longer.
The hyper board is NO LONGER AVAILABLE-and the only way to correct it is remove it and send it out for rebuild.
There are about a dozen very small "surface mounted filter caps" on the board that dry out and cause the problem.
2 people with this problem were able to remove the board and replace all the tiny caps but IT IS NOT EASY AND NOT A TASK for a do it yourself person unless you have some real skill.
The problem usually looks like noise lines from left to right across the whole or part of the screen---if it started gradually---it is a bad Hyper board.
Let me know by responding with a comment if you need help or advise.
SD TECH
Posted on Aug 04, 2010
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Picture flutter
As I indicated (I think) in another string, this sounds more like bad connections than anything else. Try resoldering the pins on the convergence ICs. Let me know if that does not resolve the problem.
Dan
May 13, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Sharp - 27G-S100 Pictures starts to pulse / flutter. When we smack(slightly) the side or the top, the picture then becomes normal. Now the unit won't even turn on.
sounds like you have bad solder connections usuall on whats called the vertical amp IC. This prob;em is very fixable but you would need solder equipment and experience to do it yourself or it would need to go to the shop.
Mar 10, 2008 | Televison & Video
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Visual
The same is true for rear projection. There may be an adjustment for vertical hold in a hole in the back of the cabinet.
Oct 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Horrizontal fluttering when warmed up.
1. HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB
Oct 18, 2006 | Mitsubishi VS-60705 60" Rear Projection...
No picture
You have an intermittant vertical sweep circuit! It could be the vertical out put IC solder connections on the printed circuit board, or maybe the IC itself has poor connections between the IC and the contact legs that mount the IC, or another componet in the vertical sweep circuit. If you know how to solder and unsolder, work on printed circuit boards, then you shoul have no problem replacing the vertical sweep circuit. Good Luck
Oct 09, 2006 | Panasonic CT-25G6 25" TV
Toshiba 57H84 57" Rear Projection HDTV-Ready Television Logo
135 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
