Question about GE Profile JK955 Electric Double Oven
GETTING F O FLASHING ON SCREEN CAN'T TURN OFF OTHER THAN FUSE BOX
Element will not turn off
Call an electrician you can cause a house fire with this amount of amperage
Sep 18, 2016 | Ovens
Why won't my double oven lights or power go on?
I think it would be a good idea to find the electric box and then:
1) find the circuit breaker or fuse that controls the oven.
That information is supposed to be written on the inside of the door of the electrical box.
2) Turn off the circuit breaker, or remove the fuse that is supposed to be the one.
3) Pull the oven out from it's place and try to get behind it to test (with an ohm meter or a multi-meter) and see if the unit is getting electricity at all.
Obviously, you will need to turn the breaker back on or screw in the fuse.
BE CAREFUL, THIS IS DANGEROUS STUFF YOU ARE DOING.
Sounds like you may need to reset the circuit breaker ( that means to turn it off and on a few times) or to replace the fuse.
God bless you in your efforts.
Sep 04, 2015 | Maytag MEW6627B Electric Double Oven
My baumatic oven elemant burned out and blew mains fuse,so replaced both and their seems to be no power at all getting to oven
Some units have their own fuse. Usually near where the power supply goes into the oven. Check your Meyer box for tripped RCD or circuit breaker too.
Nov 22, 2014 | Baumatic Ovens
Cleaned now wont turn on? power clock flashing
sounds like you have a built in kitcheaid oven? usually blows the safety fuse in the back of the oven. it's proper name is thermal cutoff. need a model number for the part you need
Aug 30, 2010 | Ovens
I have a Kenmore gas built in oven, model number 790.30179400. It's 5 years old. I just used the oven and it wouldn't turn off. It seemed to be hotter than the temperature I had it on. I have a fuse box in...
Usually F11 is a comunication error and the initial fix is to remove all power for 30 seconds then try it again.
The oven element that did not turn off is a sticking relay on the Electronic Range Control (ERC) board /clock timer that did not open the relay electrical contacts when the power was removed from the relay coil. Or there was an on the printed circuit board (PCB) fault in the ERC that allowed power to remain on the relay coil until you removed power by pulling the fuse.
The most probable cause below with the cheapest source being Sears Direct in 2nd link.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-316418553-%3d%3di1064462&PartID=1064462
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=79030179400&productCategoryId=0125200&brandId=0582&brandDescription=KENMORE&modelName=GAS-WALLOVEN&diagramPageId=00001&componentDescription=CONTROLS&documentId=R0409085&blt=06
Thanks for using FixYa!
Kelly
Jan 20, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
How do i turn on the oven?
First set the clock if you cant do that just press buttons till the numbers stop flashing the turn the knob with pictures to one that looks like a fan in a box that should be fan forced option the select the tempreture with the other knob
hope it helps
Aug 17, 2009 | Fisher and Paykel OB24SDPX1 Electric...
Oven will not shut off
f1 is a control failure and the eoc must be replaced some have 5 yr parts only warrenty but you have to use authroized servicer to get warrenty cost will be about the same either way check owners manual for warrenty details after first year example 2-5 year warrenty
Mar 05, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
GE Profile JK955 Electric Double Oven Logo
27 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
