Question about Minolta DiALTA Di250 All-In-One Laser Printer
Model PF-108 error c0991 a piece of a roller fell off when opening the bottom paper drawer is there a way to order the part and fix it ourselves?
  • 1,110 Answers
Yes you can order the parts. I know exactly what happened. I sure this is on the lower most tray also called the LCT or large capacity tray. There is a defect in these trays where a plastic arm that holds the feed rollers warps and does not hold the feed rollers high enough so when the tray is opened/closed it hits the tires and snaps it off. The problem is that you have to pull the whole paper feed assembly out of the tray to replace the parts. This is not an easy process and certainly more than I could try and type here. The easier way if you have the manpower is to remove the latch plates and the 4 corners of the lower tray "cabinet", disconnect the wiring that is behind the center plate on the back side and have a couple guys lift the machine up off of the paper feed cabinet.
Then you will be able to see the feed parts.
Precisionroller.com has parts with pictures that hopefully you can match up with what you need.
Hope this helps.
Posted on Aug 04, 2010
How do i fix the paper jamming which happen in my copier machine ricoh 2027at the second,third fourth drawer?
you need to check does the sensor on the drawer which is on the right side front of the drawer, does correspond with the paper inside the drawers.
Oct 10, 2016 | Ricoh Aficio Office Equipment & Supplies
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
What is a PF kit
This is a "Paper Feed" kit and comprises several small pieces including rollers, springs and friction separator pad. Some models have several of these and will be named "PF1 kit", "PF2 kit" etc normally one for the manual feed tray and one for the paper drawer.
If you look at the front of the paper drawer, you will see a spring loaded friction pad in the centre used to hold back all but one sheet of paper. Directly above this in the printer chassis will be a loose rubber roller assembly which grabs the sheet of paper. together, this collection of parts is called a "PF kit".
The printer memory counts the number of pages fed and will count down an estimated useful life of these parts but this is at best a "guess". When they will no longer reliably feed fresh new paper without jamming, they probably need replacing.
May 30, 2014 | Brother MFC-8460N Laser Printer
Can not get the copier to pull paper from the top draw with out jamming each time.
first, pull out the top drawer and open the right lower cover and door. now if you look into the "hole" where was drawer, on right side you will see the 3 rollers that pick, feed and separates the paper.
Remove all rollers and clean them with alcohol and dry them out, or change the places with rollers from lower drawer. Also when the right door are opened you will se two axis with two rubber rollers, clean them very well.
The iR2270 has issues with pressure on lower right cover and you need to put the rubber or similar in wide and narrow slot on lower cover, so that when its closed presses the inner paper guide which touches the rollers on axis. If You already have metal "wings" on lower cover, you don't need to apply any additional pressure.
But necessarily change the roller for paper of both cassete's and in fixing unit the fixing cleaning roller.
Hope that helps!
Mar 22, 2011 | Canon imageRUNNER 2270 Copier
Turn printer on ERROR comes on screen. Carriage jam Open Door clear carriage jam and then press OK to continue. I do this nothing found in carriage close Error comes up the same?? What to do?
Joe,
Pull all of the paper out of the machine. Look for a wadded up small piece of paper. After you look for it. Examine the door slide tray where paper is stored. Look at take-up rollers... make sure slide drawers close easily...examine door where print cartridge is....Look at (on side) feed tray...Paper feed tray... If you fail get a flashlight and take another look it does not have to be a very large piece of paper...good luck
Nov 26, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Same as other, white foam piece and sensor fell out of position
Check your model number. The number RF265AA is listed as an oven. If listed correct or if a refrigerator then I can help you, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
Jul 02, 2009 | Samsung RF265AA Bottom Freezer French Door...
Paper jam Brother HL-5050
1. Turn off the printer. 2. Remove any paper trays. Inspect them for wrinkled or damaged paper. 3. Also open the back cover of the printer if this model has one. 4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. 5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it. 6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. 7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside. 8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. 9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path. 10. see alternative if the problem is still not solved. alternative : Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 05, 2009 | Brother HL 5050 Laser Printer
Brother FAX-520MC Error 8A. What do i do?
Abnormal load applied
to the paper feed roller
PF-related gear(s)
broken
Replace the PF-related
gear(s).
PF encoder disk
stained or scratched
Replace the PF encoder
disk.
PF encoder sensor
defective
Replace the PF sensor
PCB.
Paper feed motor
defective
Replace the paper feed
motor.
Nov 18, 2008 | Brother Office Equipment & Supplies
Paper jam check drawer two t640 printer
Hello there,
If you are getting "Paper Jam check drawer two message" I would suggest you to check for any paper stuck inside the paper drawer two. If you don't see any paper jammed inside drawer two, you might also want to check out if its is stuck anywhere in the paper path. Removing the paper jam should fix the issue. Try cleaning the pick rollers (the rollers which pick the paper) in drawer two. This should help fixing this issue.
Merry Christmas!
Aug 20, 2008 | Lexmark T640 Laser Printer
Loose spring fell in paper drawer
It should hold the roller that rolls the paper into printer from drawer.
Jan 31, 2008 | Dell 1700n Laser Printer
Minolta DiALTA Di250 All-In-One Laser Printer Logo
179 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
