Question about Garden
How do I attach the vacuum bag for collecting yard waste
    President:
  • 1,545 Answers
Remove the vent at the bottom that sucks in air when it is used as a blower and connect the vacuum tube to it there, then remove the blower tube and connect the collection bag to where it was.
Posted on Aug 08, 2010
Doesn't seem to have much suction when I put my hand under the head. Have cleaned both the filter and the mesh screen
Check the suction from the hose for rge tools see if there is suction
also check to see if there is a obstruction on the short hose to the nozzle
May 16, 2016 | Hoover U5140-900 Widepath Bagged Upright...
What is the waste toner box
The collection box for waste toner. When making a copy or a print not all of the toner that is put on the drum gets used, during the cleaning stage of the process that very small amount of toner is removed and sent to the collection box. Depending on your make and model there is a scheduled image count that the box is replaced or emptied at. If you try to empty it yourself be careful!!! Toner is the finest dust you have ever seen and can become a large cloud in the air (landing all over the place) if not handled properly. And yes it will go through a vacuum cleaner bag and into the motor. Service techs have vacuums that are made specifically for toner.
Aug 14, 2014 | Kyocera Tk-362
Where is the best place to dispose of kitty litter?
Most city councils donot dispose of kitty litter so you have to disguise it with your householdrefuse. Use Clumping litter which means when you are clearing out the littertray you are only removing the soiled parts.
May 14, 2012 | Cats
How do you attach the bag to the barracuda 2595 blower
The motor housing has a spring loaded, hinged cover over the fan blades (so you don't chop your fingers off when using it as a blower). Open the cover using a screwdriver or narrow tool. Holding the cover open, attach the vacuum tube. Attach the collection bag to the discharge port (same place you attach the blower tubes) and secure in place using the velcro strip sewn onto the bag. Adjust the ******** the bag to fit your shoulder, turn power on and go. To empty the bag, just unzip the bag completely. Make sure you tighten the velcro strip so the bag doesn't come off while you are sucking up leaves.
Oct 11, 2011 | RTO Weed Eater Electric Barracuda 2595...
Where do I attach the bag for the vacuum?
When the machine is converted to vacuum mode, the collection bag will go on the machine where the blower tube (long part) is connected for blowing mode.
Mar 19, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
I have a Challenge GBV180 Garden Blower Vacuum. I can only get it to blow ..does this model vacuum and if so how do the bits attach ?
remove the blower tube by turning anticlockwise. remove cover from air inlet same way. attach large diameter suction tube to air inlet (has to fit correctly as this is where the safety switch is) attach collection bag to air exhaust opening (where you removed the blower tube from)
Oct 15, 2010 | Garden
Sawdust does not collect in bag but remains on wood that is worked on. Have tried to locate problem (probably blockage but have not found cause or remedy)
Best way to clear the vacuum path: remove the sanding belt and collection bag. Use an airhose to blow compressed air through the opening where the bag attaches to blow out anything that may be in the airway. After blowing through the outlet, check around the rear of the drive pulley for any wood that may have to be picked out. Reattach everything and try it again. If it still doesn't work, the vacuum is driven by a fan on the end of the armature. You'll have to take the case apart and check that to see if the fan blades have broken off or the fan has come lose from the armature.
Oct 12, 2010 | Makita 9404 4'' x 24'' Belt Sander
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Aug 20, 2009 | Kirby G5 Bagged Upright Vacuum
What is vaccum packing?
Vacuum packing is a method of storing food and presenting it for sale. Appropriate types of food are stored in an airless environment, usually in an air-tight pack or bottle to prevent the growth of microorganisms. The vacuum environment removes atmospheric oxygen, protecting the food from spoiling by limiting the growth of aerobic bacteria or fungi, and preventing the evaporation of volatile components. Vacuum packing is commonly used for long-term storage of dry foods such as cereals, nuts, cured meats, cheese, smoked fish, coffee, and crisps and also for shorter-term storage of fresh foods such as vegetables, meats, and liquids such as soups.
Vacuum packing is also used to reduce greatly the bulk of non-food items. For example, clothing and bedding can be stored in bags evacuated with a domestic vacuum cleaner or a dedicated vacuum sealer. This technique is sometimes used to compact household waste, for example where a charge is made for each full bag collected.
Please rate this fixya
Jan 29, 2009 | Vacuums
Craftsman leaf blower/vacuum
There is a round grille on the bottom of the unit. Insert a flat blade screwdriver into the latch to release it and reveal the vacuum opening. You should have a two-piece intake pipe that will attach to the opening.
The collection bag attaches to the smaller outlet where the blower pipe used to be (unscrew the wing nut to release the blower pipe). The bag clips onto the hooks at the base of the opening.
Nov 11, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
124 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
