Question about Maytag M7D24E7A Air Conditioner
Unit will not power up at all. receptacle tests good
I have maytag (fedders) M7D24E7B window a/c unit that is still under warranty but since fedders is now in chapter 11 bankruptcy I can not get warranty repairs done and maytag is dragging their feet, saying there are no parts available so they can't even send a technician out to check it.
    Problem Solver:
  • 10 Answers
There are limited after market parts available but you will pay to have it fixed unless you buy a new one..
Posted on Apr 26, 2008
WOULD LIKE TO KNOW IF A MANUAL IS AVAILABLE ONLINE. TO DETERMINE HOW TO USE OTHER FUNCTIONS THAN AIR COOLING.
I'm sure you can find an Owner's Manual for your unit, if you do a Google search for Maytag M6P09S2B Portable AC Owner's Manual. Most will be free downloads, some you may have to pay for. n addition, the Maytag AC Units were made by Fedders/Airwell under the model # AZ6P09S2A. So, if you can't find it under Maytag, search for the Fedders model number.
Hope this helped you and thanks for choosing FixYa.
Sep 21, 2011 | Maytag M6P09S2B Portable Air Conditioner
The cord and plug are very hot when running the ac
Sadly, for now, the only thing you can do, is turn the unit OFF & Unplug it. The fault may be in the AC unit or it could be in the receptacle it's plugged into. If it's an older unit, that was made by Fedders for Maytag, I'd strongly suggest buying a new one. As Fedders has been out of business for several years.\\
Wish I had better news for you.
Jul 06, 2011 | Maytag M6Q10F2A Air Conditioner
The reset button that came on the cord of my Fedders model AED24E7F-C keeps tripping after a short while. Otherwise the unit blows cold and works fine. I can hit the off button when it is working fine...
Do you have anything else on the same circuit? I have heard about many of these units, not just Fedders, that will not run on a circuit that has another appliance or something that is pulling a lot of amperage. Also, check and make sure the receptacle is not worn and the plug is loose fitting. Other wise, you definitely could have a weak internal connection in the cord. Hope this helps.
Jun 28, 2011 | Fedders AED24E7F Wall/Window Air...
Missing exhaust kit. Need window adapter, hose and connector/adapter for back of unit hot air exhaust port. NMPEB08F2A Rev B made by Maytag / Fedders
Try duct tape , pvc pipping and cardboard, Tape the pipe to the back of the ac and them use a cardboard piece with a whole cut out for the pvc pipe in the window ,coat the cardboard with several layers of tape inside and out..It should work for awhile..Or call the Maytag/Fedders maybe they will send it to you free...
Jun 12, 2010 | Maytag NMPEB08F2A Air Conditioner
Doesn't operate when plugged in
The test and reset is a GFCI device. They do go bad sometimes. The solution is to cut that plug end off, and install a regular cord end that is capable of handling the rated amperage of the unit. ( I assume this is 120-volt unit)
You should replace the wall receptacle with a GFCI receptacle where the unit is plugged in to prevent electrocution
May 02, 2009 | Heating & Cooling
Maytag A/C window unit
Check all of the connections at the outlet. If everything looks ok test the outlet that it is plugged into with a tester. They can be picked up at most stores for around 8 dollars. If you dont have a tester you can just plug in another device that you have into the outlet and see if it turns on. If everything checks out OK then there is an issue with the A/C unit. It could be alot of different things. My recommendation to you is if it is under warranty contact Maytag and send it in for service. If it is not under warranty you can either contact Maytag and send it in for service or you can call a local heating and cooling shop and see if they can service it for you. Keep me posted - Tech101
Jun 27, 2008 | Maytag M7Y15F2A Air Conditioner
M7d24e7b-a
my m7d24e7b-a with not cool ?
May 26, 2008 | Maytag M7D24E7A Air Conditioner
Maytag M7D24E7B
if unit has electronic controls, verify that the fuse/s ain't blown. also check wire connections probably a broken wire from main source.
Apr 26, 2008 | Maytag M7D24E7A Air Conditioner
Dehumidifier m7dh65b2a
Mine broke recently too, although it's 4 and a half -- also under the 5 year warranty.  Maytag won't honor the warranty claiming that Fedders made it.  Fedders simply won't honor the warranty.  Made in China -- any surprise?  So, now I've got a broken appliance under a warranty that no one will honor.  To make matters worse, no one even fixes Fedders in my area (DC suburbs) and to dispose of it will cost me $40!  I'm thinking of taking it back to Home Depot (where I bought it) and telling them to return it to the manufacturer.  Are there any lawyers out there?  Class action anyone?
Oct 11, 2007 | Maytag M3DH30B2A Dehumidifier
Maytag NMPEB08F2A Portable Air Conditioner
I have the same problem w/ a window unit - fedders unit under the Maytag brand. No idea how to fix it, but would be great to get some info on this.
Jul 15, 2007 | Maytag NMPEB08F2A Air Conditioner
Maytag M7D24E7A Air Conditioner Logo
185 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
