Question about Euro-Pro Shark GI490 Iron
The "Burst of steam button" on the upper right side of the iron is stuck in the down position- I cannot get it to release. I have tried everying including spraying WD-40 into teh slot but nothing works to get it to release Can I fix this issue myself? Pat Leen
snakehead
  • 1074 Answers
SOURCE: Euro pro steam iron model G6118H
the preasure tank inside the iron could have a hole or the holes at the bottom of the iron are clogged up and needs to be cleaned.good luck
Posted on Apr 18, 2007
  • 19 Answers
SOURCE: no steam when ironing and no burst steam
bad connection to heating coil. Not worth fixing.
Posted on Feb 22, 2008
JULIANFIX
  • 975 Answers
SOURCE: Rust
use "CLR" Product , is very good removing and cleaning, you can find it at WALGREENS , WAL-MART . . . . .HOPE IT HELPS AJ
Posted on May 26, 2008
SOURCE: Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
Posted on Jun 25, 2009
  • 19 Answers
SOURCE: Brown steam bursts coming out of my G1490 Shark iron
make sure you do a self clean as often as possible to remove debris and scale from iron
Posted on Aug 16, 2009
How to release the stuck steam button stuck in the up position in a morphy richard
On this model i believe you have to slide the button back to release perminent steam function. I am not sure what screws are on this iron as to what they are called.
regards, I hope this was useful.
May 13, 2014 | Irons
I have lost my instructions on how to "self clean"
Straight from the manual:
http://www.applianceinsider.com/storage/user-manuals/rowenta/user-manual/DX8000.pdf
Fill the iron with tap water to the max mark on the water tank.
Be sure that variable steam lever is set to minimum.
Stand iron on heel and plug in. • Set thermostat to ••• setting.
Once heated, unplug iron.
Hold iron horizontally over the sink with the soleplate pointing away from body.
Move the variable steam lever completely to the right and hold in the self clean position for one minute.
Warning: Doing this will cause steam and hot water to be ejected from the soleplate. Take all proper precautions and hold iron away from body.
• Move the iron gently back and forth and side to side until all water has run through plate.
• Carefully wipe all water and material from the soleplate with an old towel, as the water and minerals can stain the soleplate (although this has no effect on glide or performance.)
Warning: Iron and soleplate may still be very hot. Exercise care while wiping.
• Place iron on heel and leave to cool. Before using iron after self cleaning, test steam and burst
of steam on an old towel or cloth than can be discarded.
May 04, 2011 | Rowenta Professional DX8800 Iron
No water released from iron when burst of steam or additional spray of water buttons are pushed
The jets might be clogged with minerals from hard water. Try using some vinegar in it to see if it breaks up the minerals. You might need to let the vinegar sit in the water resovoir of the iron for a little while. Also use vinegar on the jet holes where the watre comes out of the iron.
Oct 28, 2009 | Rowenta Surfline Iron DE-333 Iron
Jun 24, 2009 | Euro-Pro Shark GI490 Iron
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
HINARI LIFESTYLE STEAM PRESS
The RED button is located on the pull down handle.
Sep 22, 2007 | Irons
Steam button wont push down
take down and clean the parts where the steam button is the spring could be dead and needs to e replaced.good luck
Sep 10, 2006 | Rowenta Professional DE880 Iron
Euro-Pro Shark GI490 Iron Logo
32 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
