Front panel the front of the tv where the buttons and the sensor is torn up and I can't turn the tv on the tv works and the remote is not working either I was running it thru the vcr but someone unplugged it and I can't turn it back on
    Problem Solver:
  • 9 Answers
There is no other way you can turn the tv on sorry
Posted on Apr 26, 2008
Emerson LC320EM82S Unit works ok with manual buttons at top of set but Emerson remote and after market remotes wont work at all
Hello
The remote sensor inside the front panel of your TV is faulty. This is a three terminal device, can be located just behind the infrared window at the front panel of your TV. You have to open your TV, and unscrew out the front panel circuit board to access it.
Sep 05, 2011 | Emerson LC320EM8 32 in. LCD TV
3 yr old KDL-40V3000. Remote suddenly stopped working. Changed batteries twice - didn't make any differnence. Then noticed no LEDs lit on TV front pane! But TV is powered on. Also TV can be operated...
U have a Digital Camera turn it on,take ur tv remote pushes all the remote buttons on the front of the Digital Camera.One by one buttons.If all buttons of the tv remote work will register on the Camera viewing screen,because the Digital Camera able to read infer red signal output.Will figure out wright away the tv remote work or not easily.Tv remote sensor/board have no LED power light lite up might just be a lose connection or just a dead LED lamp only,because all the buttons on the remote sensor/board to the tv panel work wright?Try website Remotes.com to buy tv original remote.
Jun 10, 2011 | Sony BRAVIA KDL-40V3000 Television
Remote control not working
It could be either remote is bad or remote sensor located at tv front is not working.
You can test remote with help of any digital camera, watch remote front through camera and press few buttons on remote, you will see infra red led blinking at remote front, that means remote is good and working. Remote sensor in tv is defective and need to be replaced by qualified tech.
If infra red led of remote does not blink pressing any button while watching through digital camera then problem is remote, buy new one to solve the issue.
Thanks.
May 05, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Remote sensor in the TV
Remote sensor is locketed on pcb it an be replaced
May 11, 2009 | Televison & Video
The remote operates all the units except for the TV's vol, channe
There are 2 possibilities: either you have a stuck front panel button, or the remote sensor is bad.
You can eliminate the button issue by removing the front speaker grill and access panel and disconnecting the button assy wiring harness.
There is a plug/socket connection there that you can easily disconnect. If after disconnecting the control panel, you still have no remote, its the sensor. Its located behind the screen assy mounted behind the CRTs. You will have to remove the screen assy to get to this.
If you're not up for this, a service company will charge you $300 or so to replace the sensor for you.
michtech
Feb 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Remote Sensor on TV Doesn't Work and Can't Manually Adjust Menu
I just realized that there is no usb port on this tv. Called tech support at vizio since I'm still under warranty. They're sending a new remote. I know it's not the remote because neither the verizon nor the vizio remote works, although the vizio remote will intermittently work if I'm one foot away from the sensor on the tv and holding the remote on a downward angle. Tech support says they will send a new remote to rule that out before they send a tech over. I'll check the posts to see if you find a solution when I finally get the tech guy out here. If not, I'll let you know what he does.
Good luck.
Aug 04, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Front panel button turn tv on and off
If both the remote and the front panel buttons do not work, I would be thinking that it is a problem with the TV's main uPC area. This type of fault can be involved, and would require factory level service where the fault can be properly analysed.
I can tell you in advance, that this type of fault can be expensive to service.
Jerry G.
Jul 30, 2008 | RCA TruFlat 27F520T 27" TV
Controls
the sensor for remote has fallen off its usually connected to a 8 inch wire which fell back into system pull the sensor wire forward the way to get into tv 3 ways front pannel pops off sensor is set at front
there the back of tv
then theres threw the
Mar 19, 2008 | Apex Digital GB5108 51" Rear Projection...
i bought tv ,just week ago and tv sensor on tv want wwork, that why we cant use remote.
Aug 19, 2006 | Sony FD Trinitron WEGA KV-20FV300 20" TV
First Inspect the remote batteries. also make sure TV is not on a LOCK ON option... now, the sensor is a small smoothly part near the TV front buttons, you can clean it carefully FYI, exposing unit remote sensor to direct fluorescent or outdoor light may cause signal interference.
Nov 14, 2005 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
