Question about Frigidaire Affinity ATF6000F Front Load Washer
The door is sagging and does not line up with the door lock. It has to be lifted slightly to close the door. It was always slightly out of align and seems to be getting worse.
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Sagging microwave door
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If the door seal is damaged or out of alignment, there is a chance of leakage, which can cause burns, damage to the oven or even a fire hazard.
Posted on Feb 09, 2009
miket756
  • 2702 Answers
SOURCE: Our microwave will not cook when the door is
please dont even try this, fix it yourself job!!! yes it is an easy fix!! if you know what you are doing,, but if you dont know what you are doing,,,, well to be blunt,
you could just be finding a fast way of killing yourself!
even with the power plug pulled out the wall scocket and stood on a rubber mat!!! just one tuch across the capacitor and you could very well grow wings!!!!!!!!!!!!!!
do you realy wont to die??? call the guy back to fit a new micro switch in the door lock as its set back deep in side the unit and its a cheep part as well
but just like all fixes,,, its not the parts you pay for,
its knowing how to fit them in that costs you so much
this not knowing could cost you your life???????
play it safe,, please,,
Posted on Oct 21, 2009
Testimonial: "Thank you for your input! I did not know about the capacitor and how lethal it could be. I'm glad that I asked before attempting the repair! Thanks"
  • 35 Answers
SOURCE: door sags and is out
If there are any screws right where the door connects then they shouldnt be loose. If you can lift the door up and then close it you probally just have a couple of screws loose LOL! If not then you might have broke the pin inside the door. Either way it should be fixed before you have water damage. Hope it helps let me know what happens. Thanks
Posted on Dec 22, 2010
SOURCE: frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom.
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
Posted on Apr 16, 2012
How do a fix a Westinghouse fridge door that has dropped slightly
Hinge screws probably loose. Refrigerator doors have hinges screwed on the outside. The hinges allow for you to move door to be level, loosen screws, move door level and hold it there till you tighten screws. Sometimes the hinges are covered with a plastic piece that you pry gently up on to remove.
Jul 03, 2016 | Westinghouse Refrigerators
95 chevy blazer 4 door. driver door started to sagg slightly, shortly after the interior light wont go off without pulling the fuse. then the power door locks wont work. Ive heard when door is shut it must...
with the door sagging it may not be pushing button in far enough to shut light off or aligning with button right.Replace bushings in door.The fuse is probably the same one for light and door locks.
Sep 18, 2017 | 1995 Chevrolet Blazer
Driver door won't close 1999 ford contour
Drivers side door will not close because, it might have dropped out of alignment and is sagging down slightly!!! or if it has electric door locks, and someone in the family has failed to mention door locks were activated while that one door was still open!!! now lock mechanism has passed it's normal stopping place and is now stuck, therefore already locked and not allowing door to close all the way!! you might try disconnecting battery then try jiggling the lock, and hope silenoid didn't get burned out, open passenger door and look at lock latch, then check drivers side lock latch!!! if your lucky lock latch should unlock when battery is hooked back up. i have seen this problems happen often on older vehicles!!! especially on cars or trucks that have been in fender benders.........body shops know what to check for, they fix problems like this often!!!!! Good luck!!
Dec 13, 2010 | 1999 Ford Contour
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Same - the counter counts down, but doesn't cook.
Yes your door isnt aligning right when closed and the lower interlock isnt being made when shut. Look and see if where the door pivots if it is broke or sagging down.
Sep 11, 2009 | Frigidaire FMV156EM Microwave Oven
Garage door chain is sagging
If the chain is adjusted properly the chain will sag slightly on one side when the door is closed and on the other side when it is open. It should not sag enough that it is dragging on the T-rail. You can adjust it at the trolley. If you over tighten it you will hear a clicking sound when the opener opens or closes.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Dacor DCM24 Door is out of alignment
Loosen 3 screws on lower hinge, lift the door to realign, then re-tighten screws.
Jan 29, 2009 | Dacor DCM24 Convection/Microwave Oven
Door sagging
put a hammer in between bottom hinge and close door slightly this will lift the door
Dec 05, 2008 | 2001 Oldsmobile Bravada
Both Doors are shot
are the doors sagging? if you lift up on the doors is there play in the hinges? you can buy new hinge pins and bushings for about $20 a side they are pretty easy to install and this should realign your doors to shut right -jeff ...also napa or autozone should have the parts or try online please rate
Sep 12, 2008 | 1988 Chevrolet C1500
Frigidaire Affinity ATF6000F Front Load Washer Logo
186 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
