Question about Garden
The chain on my homelite chainsaw keeps coming off. Any suggestions as to why and what I need to do to repair it. The chain becomes very dull as a result since it travels through part of the metal casing.
    Champion:
  • 221 Answers
Are you keeping the chain tight per the manual? Chains will stretch with use and typically as they get hot they loosen. When you have the chain tight, on the bottom of the bar between the bar and chain you should only be able to slip a dime in (the narrow part). I usually have to tighten my chains about every 30 minutes or so. If you over tighten the bar hold down bolt you risk stripping (pulling) it out of the engine.
There is no magic bullet for this. You must periodically snug the chain up as you use the saw.
Another thing to check is wear on the bar. If the bar groove is worn the chain will come off with less slack in it then it should.
I hope this helps.
Posted on Aug 04, 2010
I have a homelite 350 automatic chainsaw. How can I get a repair manual for it?
http://www.mymowerparts.com/pdf/Homelite-Parts-Manuals-For-Chain-Saws/
May 02, 2016 | Homelite Garden
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
New Homelite. Cut great for an hour, then the chain wouldn't grip or cut. Chain was loose so I tightened but still doesn't cut- just
The blade is no longer sharp, something not unusual after about an hour of cutting. How long a blade stays sharp depends on what type of wood you're cutting, whether the blade contacted the ground or anything other than wood at any time, and how hard you are working the bar through the wood. If you are cutting hardwood or something like railroad ties the lifespan of the blade is greatly reduced. You can easily sharpen the blade with a hand file or dremel tool with a chain saw blade kit on it or have the blade sharpened. Best practice is to have one or two extra blades so you can change them as they become dull.
Mar 29, 2012 | Homelite Garden
I just started up my new 16" Homelite and the engine starts, but the mechanism that powers the chainsaw isn't rotating... any suggestions?
The engine needs to be accelerated to make the chain turn. The chain should not be so tight on the bar that you can't turn it by hand. Make sure the chain brake is off by pulling back on the brake paddle which has a 'toggle' effect--it should snap over to the new position. If still having problems, it is time to return for warranty exchange or repair. Hope this helps!
Jan 09, 2011 | Homelite ZR10926 16" Chain Saw
My chain keeps losing tension after a few cuts. Installed new bar and chain, no help. Could it be adjustment screw? Thanx!
Yes.try to put an "precision metal o ring'" on the bolt.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 28, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I HAVE A HOMELITE XL2 CHAINSAW WITH A 12 INCH BAR, CAN I INCREASE THE BAR TO A 14 OR 16 INCH BAR.
Usually, yes. Take the saw to a service dealer who can fit a longer bar and proper length chain. You will need to keep the chain properly sharpened and adjusted to prevent extra load on the engine. Hope this helps!
Aug 16, 2010 | Oregon Scientific Oregon Bar And Chain Set...
Ryobi pcn3335 chainsaw chainbrake will not release fully
1. Is there a Homelite/Ryobi dealer/authorized repair facility near you? If yes I'd try them they may repair it.
2. Any major chainsaw seller/repairer may be able to repair it... there will be a fee.
Lou
I own a few chain saws without chain brakes. I also own and use good PPE.
Feb 25, 2009 | Ryobi Garden
Chain brake will not release (homelite chainsaw)
The header says you have a Homelite saw and if this correct you can go to Homelite.com and look up parts or other information that you might need for your saw. There is also a contact us area. Good luck
Jan 25, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
351 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
