Question about Olympus FE-310 Digital Camera
Sand in the lens - Olympus FE-310 Digital Camera
  • 4,102 Answers
Hi, the only chance you have of getting this sand out is to buy a can of compressed air you can get this from most computer stores its about the size of a deoderant can and just contains pressurised air you then spray this onto the lense and around the camera and then this should remove the sand.
one other way you can try is hold the camera in one hand and tap it into the palm of the other hand doing this should get some out but wont be as good as the can of air
try not to keep using the camera untill the sand is out as it will scratch the lense when you keep opening and closing the camera so go and get a can of compressed air or you could go to your local car garage and ask them if they could blast the camera out for you as they have compressor for their power tools just offer them a drink for doing it for you.
let me know how you get on or if you need further assistance ok
Posted on Aug 04, 2010
Screen says lens problem
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism (look closely for sand particles around the lens barrel of your camera. A single grain of sand can jam in the gaps around the barrel, preventing the barrel from closing. Use air or a thin sheet of paper to dislodge them). Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 22, 2010 | Canon PowerShot SD1000 Digital Camera
Tip
Dull or tarnished headlights fix
if you have dull or tarnished headlights that are plastic a good easy cheap fix it a wet sand and buff.
first take some 1000 grit or smoother sand paper and water and lightly sand the headlight lens evenly over the whole lens. while going a little heavier on the duller spots.
after wet sanding is done wash the lens with soap and water. now take a little compound with buffing wheel to the lens again evenly over the whole lens.
wash again making sure you have got all the compound off.
next you will need to glaze the lens with the buffing wheel. again evenly and you will see you headlight lens will look better than brand new.
on Dec 03, 2009 | Toyota Camry Cars & Trucks
Sand in lens.
Are you sure its sand? Usually it is the plastic gears or parts of them in the lens that make noise. Unless its under warrenty , time for a new camera.
Mar 22, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
Digital camera dropped lens-opened on the beach and now the lense will not open properly
Hi
There is sand in your lens and it is jamming upthe gears. One grain of sand will cause the lens to fail! You can try to take the lens apart and clean out the sand but it's not easy and an opened lens usually never focuses exactly right again.
Look for a defective camera online that has a good lens but broken LCD or some other problem and fix that one using yours as parts or have yours fixed with a new lens.
We can do a new lens install for you for about $80-90 I believe. If we can help please let us know!
Thomas D
Owner, Darntoothysam com
Affordable Digital Camera Repair
Sep 20, 2009 | Canon PowerShot SD870 IS Digital Camera
FEEL IN THE SAND...
This is a common problem to digital cameras for those who take it to the beach. The problem was that there could be granules of sand in the lens and thus preventing your lens to come out.
What you need to do is to hold you camera on your right hand, with the lens facing downwards. Then turn the camera on as you gently hit it with your left palm. Do this several times until the sand comes out and your lens could retract out again.
Sep 12, 2009 | Casio Exilim EX-Z57 Digital Camera
Lens error canon powershot sd1100 is
Apparently, you missed some sand and it just took a while to work its evil way into the works of your camera.
Aug 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens Error
Sand is a killer to cameras. If sand becomes lodged in the lens bellows it will jam. I have never after thousands of repairs had any lasting success in trying to repair. When taking a camera around water and sand buy some sandwich bags to place camera into protects against water and sand.
Jul 01, 2009 | Nikon Coolpix S550 10 Megapixel Digital...
Sand in my camera
Sand, water, salt water, dirt and dust can damage the lens to the point of no return, so to speak.
It may not have been dropped if you had used the wrist strap, how ever it is now in damaged condition.
The lens needs to be taken apart to completely clean out the sand. This is a very tedious and is a job for a professional with experience.
The parts are extremely small and have close tolerances, thus any dirt or sand can cause grinding or damage to the internal parts of the lens mechanism.
If you ever get a chance to see the gears and the gear teeth, you would understand why just a few grains of sand can jam these small parts. One grain of sand can stop a lens gear from working and possibly cause a broken gear. The parts are so small that in order to see the grains of sand which cause the problem, it may be necessary to use a magnifier lens.
To even make things worse, there is grease usually on the gears. The grease will hold any sand and cause it to stick in place. Cleaning these gears is not very easy.
I have done it, and returned the camera to working condition, but not an easy job.
Aug 30, 2008 | Nikon COOLPIX L3 Digital Camera
Lens error
The very smallest piece of sand will jam any digital camera lens. You should be extremely careful to never allow sand to get anywhere near any digital camera. The gears are very small, thus the smallest piece of debris will do a lot of damage. To remove all the sand in the gear train is a time consuming effort. It has to be completely taken apart to do it right. You will need a good magnifing lens as well. That may also affect the ccd and alignment. Sometimes it it worth it.
Mar 18, 2008 | Nikon COOLPIX L3 Digital Camera
Lens wont close
tryig to force it closed if sand is in it will do further damage. Can you gently extend the lens and jiggle it to see if any sand comes out. Most likely this fault needs repairing to open it up and remove the sand.
Feb 27, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Olympus FE-310 Digital Camera Logo
80 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
