Question about Emerson LC195EM9 19 in. LCD TV
After 10 minutes picture cuts off and off on switch flashes.
  • Emerson Master
  • 8,457 Answers
Check the power source?Yes,Power supply board is the problems,it dying.That the board on the tv,the power a/c cord plug into it.That the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Aug 04, 2010
My television comes on and plays great for about 10 minutes then the picture goes out but you can still hear sound,then you'll cut it off for another 10 minutes and turn it on and it plays great again for...
a good indication of one or more electrolitic capacitors failing or a cathode ray tube ie picture tube with a heat related internal short shutting down the high voltage system if this is a rear projection tv time to call a certified electronic tech
Dec 17, 2014 | Televison & Video
Yesterday I was taking pictures with my Canon 5d MarkII and Speedlite 580X. I control the flash from the camera enu but at some point the meanu was no longer accesible and I got a message that either the...
It sounds like the flash went to sleep. The normal time for this is 10 minutes. If you switch the camera over to slave mode, it should switch to 60 minutes.
I hope this helps! That's a great setup!
Mar 06, 2011 | Cameras
A friend of mine lost her keys, she had a new one cut from dealer. Problem is it will open door but will not turn ignition? What can we do to move it or get it started. It needs to be moved from it's...
PLACE NEW KEY IN THE IGNITION SWITCH.TURN THE IGNITION TO THE ON POSITION 10 MINUTES UNTIL THE SYSTEM LED WILL ILLUMINATE OR FLASH AND SWITCH ITSELF OFF. THEN YOU TURN OFF IGNITION SWITCH WAIT 5 MINUTES THEN SEE IF VECHICLE START UP.IF NOT TRY THIS PROCEDURE TWICE.STILL NO LUCK THE DEALERSHIP HAS TO REPROGRAM NEW KEY TO IMMOBILIZER.
Jan 08, 2011 | 1998 Saturn SL
Sony KP-57WS520 57 inch rear projection TV. When I turn it on I hear sound and it cuts itself off and standby light flashes 5 times over and over, if I cut it on again I hear sound and then it cuts itself...
sanschargrin,
I hate to be the bearer of bad news but your unit has some optical engine problems. Here is a web site which explains it all and tells you where to apply for class action compensation. http://sites.google.com/site/sonylcdrptvproblems/
Thanks for using FixYa and for the great rating.
hardrocko
Dec 15, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
RED LIGHT FLASHING after local power cut in East London
I switched off the power, then I disconnected the lid from the base, put the power back on, the green light came on & then I reconnected the lid to the base & it has been working fine ever since
Aug 27, 2009 | Epson Perfection 4990 Flatbed Scanner
Tv shuts off after 10-20 minutes
its not the problem with ur electron gun tube or with any picture ic or sound ic. Every t.v. is microcontoller switched machine.
any damage to microcontroller ic that controls the switching will lead to this kind of problem.
0.01% chance of residue EHT voltage would have affected the microcontroller.
Jun 06, 2009 | Panasonic TH-42PC77U TV
Security light flashes car cranks but won`t start any way to bypass security .
turn key on for 10 minutes until light stops flashing then try to crank car over
May 23, 2009 | 1999 Oldsmobile Alero
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Picture on my TV starts to flash after a few minutes of use
This problem is common in Samsung projection TVs. The DMD board is going bad.
Mar 21, 2008 | Samsung HL-R6167W 61" HDTV
Emerson LC195EM9 19 in. LCD TV Logo
61 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
