Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Engine just stopped ...Not Getting FUEL . sPRAY STARTING FLUID and it will start. it is a 2135 12.5 Kohler.Does this engine have a fuel pump?
  • Cub Cadet Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Posted on Aug 11, 2010
We have a Cub Cadet 2166. After mowing the grass after 30 minutes are so ...it hesitates...like it wants to die out and eventually it does. You cannot continue to cut grass because it hardley moves...it seems to help a little when you let the engine cool down...then starts acting up again. Can someone tell me what is causing this? Thanks!
Posted on Aug 13, 2010
Engine cranks but will not start 2005 buick terraza cxl
is the engine light on or other warning lights glowing
if so there are fault codes in the ecu to be read
can be a fuse
or fuel delivery to the motor
or coil /spark problem
Jun 21, 2016 | 2005 Buick Terraza CXL
Kohler engine command pro 27 hp not start cub cadet m60 tank
spray some starting fluid in carb if starts ether bad feul filter or fuel pump or need to rebuild carb
Jul 23, 2014 | Cub Cadet Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Won't start. I've replaced the fuel filter, the spark plugs, wires, and ignition coils. Will run off of starting fluid, but not by itself. Checked fuel pressure and it's coming up around 40. What else...
SOUND LIKE FAULTY FUEL PUMP OR BAD PUMP RELAY. IF YOU SPRAY STARTER FLUID AND VECHICLE RUNS.ITS NOT GETTING FUEL..NEXT TIME ENGINE STALL OUT.GET A FUEL PRESSURE READING.DONT TURN ON THE IGNITION .IF FUEL PRESSURE READS ZERO YOU KNOW YOU HAVE FAULTY FUEL PUMP RELAY OR FUEL PUMP RELAY FAULTY.
Dec 25, 2010 | 1993 Saturn SL2
Engine ran fine. Stopped it. Could not restart. Fuel pump was replaced and fuel filter. 40 psi when rolling over engine. Have compression and spark on all cylinders. Timing belt appears okay. Engine rolls...
try spraying starting fluid in the breather and see if it tries to start if so check fuel lines etc. to make sure that it is getting fuel to it.
next would be check injectors to see if they are getting voltage to them.
Nov 14, 2010 | 1992 Ford Escort 4 Door
Car will crank but will not start
First check you are getting spark to plugs. If yes check for fuel. You can spray starting fluid in intake when you pull off intake rubber hose that sits on top of engine. If you start momentarily you have fuel problems. Turn key forward just where its left after you start. Listen for fuelpump to whine back by gas tank filler. If no noise most likely fuelpump. Always change fuel filter right after its install.
Jun 09, 2010 | 1999 Ford Explorer
1997 Chevy Silverado 1500 4x4 will not start. Getting spark checked all fuses, changed rotar - spark plug wires,
Have you checked the fuel pressure? Fuel pumps are a common failure item on those trucks. Pick up a cheap fuel pressure gauge and hook it up to the shrader valve on the fuel rail. With the ignition on and you should have 55-65psi. Even if it's a few psi below spec it could stop the engine from firing.Once you determine the fuel pressure isn't adequate make sure you have a good power and ground at the fuel pump. If that checks out, time for a new fuel pump module. I recommend only replacing it with an AC delco unit, I've heard bad stories about aftermarket replacements.
You could also spray some carb cleaner or starting fluid in the throttle body and crank the engine over. If it runs for a few seconds after spraying starting fluid in you know you have a fuel delivery problem.
Mar 14, 2010 | 1999 Chevrolet Silverado 1500
I have a 1988 toyota van le cargo 2.2 engine
Try spraying starting fluid into the intake of the air cleaner while someone else starts the car. Continue spraying the starting fluid for about 15-20 seconds. If the car starts, more than likely your fuel pump is bad. Check your fuses, and make sure you are getting power to the fuel pump. jpwtruck@yahoo.com
Feb 17, 2010 | 1988 Toyota Cressida
Gas not getting engine(flter or pump)
Sounds like the fuel pump and filter. Spray starting fluid in throttle body if cars starts the its your fuel pump and fuel filter.
Oct 29, 2009 | 1998 Ford Crown Victoria
Spray a shot of starting fluid in throttle body and it starts but dies almost immediately after it starts and needs another shot of starting fluid to start again. Once it starts again it dies almost...
Sounds like u have a fuel problem. The engine is not getting the fuel it needs thats why when u spray the starting fluid in it runs then dies when it burns it up. check the fuel pump and see what kind of psi your getting.
Oct 21, 2009 | 1989 Jeep Wrangler
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
584 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
