Ensure there are no wiring faults from the Digital Motor Electronics (DME) to the throttle motor using a break out box.
If the wiring is not faulty then replace the throttle motor, then clear the DME adaptation values.
Switch off the ignition for approx 30 seconds.
Turn on ignition and delete DME adaptations and fault code memory.
Push down on the accelerator pedal four times to wide open throttle.
SOURCE: trouble codes 171, 174, 137 & 401 came on after engine replacemen
did they ever reflash the ecm with the new codes for the motor
