Question about AEG Lavamat 16810 Front Load Washer/Dryer
Configuration Code Hi, I have just replaced the electronics assy board in an AEG L16810 washer/dryer. However, the board requires a configuration code. Do you know how I can program the code into the machine please? Thanks very much for any help, Paul
    President:
  • 1,462 Answers
I know this is not very helpfull, but you will need the instruction manual for this - it is not that easy the first time round. the code should be printed on a label on the old module so don't thow it away. code is 16 digits long from memory
Posted on Jun 19, 2008
How to go configuration code
Posted on Aug 10, 2008
What does error 90 Mean on an Electrolux Ewf 1087
E90 is family error code visible to the customers. It is necessary to read the error in the service mode so please proceed with the following procedure for rapid reading of alarm codes:
Press and hold down START/PAUSE and the option button nearest to the START/PAUSE button for at least two seconds!
After that the display will show one of the following errors that are more precise:
E91, E92 - Communication incongruence between main board and display board (versions not compatible). Posible causes: wirings, main board or control/disply board.
E93 - Incorrect configuration of appliance. Posible causes: Incorrect configuration data; electronic board faulty.
E94 - Incorrect configuration of washing cycle.
E95 - Communication error between microprocessor and
EEPROM. Posible causes: Electronic board faulty.
E97 - Incongruence between programme selector and
cycle configuration. Posible causes: Faulty electronic board (Wrong configuration data).
Considering that this is a complicated fault, my advice is to contact an authorized service center.They have special equipment such as an interface that allows them to upgrade software in your appliance. If you are not doing anything on the appliance before the failure, the only thing you can check is the contacts between wiring and electronics.
Dado
Feb 22, 2016 | Electrolux Washing Machines
AEG L87480 on desplay makers E91 what means
Dado
Jan 11, 2016 | AEG Washing Machines
Hi Ihave an electrolux EWD 1477 washer/ dryer. It keeps showing up an error E90 and starts beeping and stops working? Any ideas how to fix it ? Thanks kindly
Dado
Feb 12, 2015 | Electrolux EW1000i Front Load Washer
How do I fix my AEG Lavamat T57800 dryer
E51 - Motor power triac short-circuited
Motor faulty ; Wiring faulty ; Electronic board faulty ; Motor capacitor ; also check tension of belt
Dado
Jul 15, 2014 | AEG T57800 Electric Dryer
Aeg error code e20
E21- Canister fill pump triac faulty.
Could be : wiring faulty or electronic board faulty
E22 - Triac "sensing" circuit for the canister fill pump faulty
Could be : Electronic board faulty
Dado
May 04, 2014 | AEG Dryers
Hi, I bought a new frontdoorgrip. Partnumber 0012932; for the Lavamat L16810. When mounting the screws I found out that they are too thin: I can push them easily into the holes. Do I need nuts behind...
No nuts. The screws fit into the plastic electric door mechanism which, after you took the screws out, will be hanging iside the machine. Either take the lid off to access or, easier but a bit fiddly, is to feel for it (with your left hand) through the rubber drum seal. With a bit of manipulation you will see the screw holes and door catch appear; line them up and replace screws and plastic facia.
I did the same thing and learned not to unscrew anything without knowing what it's there for!!!
Aug 18, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
Zanussi jetsystem 1400- error e90
e90 is configuation problem reinstating configuration code may fix this(not easy to do) or electronic has lossed communication with display board. can be a bad connection between electronic and front display board. faulty electronic board the most likely.
Jul 23, 2010 | Zanussi FJS1225W Front Load Washer
Continuous beeping with only the on/off button lighting up
this sounds like a configuration of the electronic problem. error e90 there are at least 9 beeps . can be badly connected wires particularily between main board ond front display board but usually ends up with a new main electronic (£120) also configuration is a complicated operation.
Jun 12, 2010 | Zanussi FLE1416W Front Load Washer
E93
E93 is showing that the configuration code has not been put into the new Module if no configuration code came with the module then you will need to send me the p.n.c. of that model and I will get the correct code.
Hope this helps.
Good Luck
May 07, 2010 | AEG L62600 Front Load Washer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
392 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
