Question about Ovens
I bought this new clock kit WB50K5013 and have to replace the original clock with this new one the wiring is different I need a digram or instructions on how to wire this new clock my oven is gas not electric. My oven model no jgrp16gep1bg
  • davemccollum Aug 04, 2010
    The new part # is correct according to GE
    I did not recieve any diagrams or instructions for wireing the new part# to the old oven
    I wonder if Daniel S could help me with this
    the conclusion we came to together that I had the wrong part is incorrect
    I still need help wiring the new part
Powerman
  • 68 Answers
SOURCE: Kenmore oven clock control installation instructions
Your prpblem is not the control, it is a short circuit in the ribbon cable between the keypad and control. You can find my fix at:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
I have now shared this with over 1400 folks and most report success.
Please let me know if this works for you. Email me at:
hutchipop@yahoo.com
Posted on Nov 22, 2007
SOURCE: Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Posted on Oct 05, 2009
SOURCE: I have a classique gas/electric oven and need to
Cassique gas top & electric oven. Oven does not have usual temperatures but has 1 to about 20. What do these numbers relate to in terms of temperature
Posted on Oct 13, 2009
blackmar
  • 235 Answers
SOURCE: I have a GE electric oven mode JSP48G*J2. It has
Normally the mechanical timers have only 2 terminals. Active supply in and oven load out. It doesn't matter which wire you put where. If you don't use the timer just join the active supply and the load together and the oven will work.
Posted on Feb 16, 2011
SOURCE: hi i have been given
You need to set the clock for the oven to work.
Hold down "Minute minder" and "Cook period" and press +
Posted on Feb 27, 2011
Suspected burned out heating element
your "specific" answer is same for all, If your element is "open" then your ohn reading would be infinite,if it is shorted it would be 0 ohm both cases would need replacing. You need to look at the wiring digram for a temperature switch[thermostat] which will be connected in series with the element. All heaters,microwaves ovens,are required to have them They open up when or if oven gets too HOT. The little units cost about $2-3 and can be bought online [e-bay] Go to applianceaid.com/appliance-repair-help.php find your make,model and they will show you the part and how to replace it.Good luck Steve The unit is a protection device always replace it with proper temperture rating.!
Oct 15, 2012 | Bosch Ovens
I have thermador double electric wall ovens and I have slowly over time lost the abilitty to read the information in the window display. I took off the face plate in the hopes that it was a simple bulb or...
You need a new display kit. The display kit has a new clock relay board and the white harness to the clock. The repair is straight forward.
Apr 22, 2011 | Ovens
I have bought a replacement main oven Thermostat for a tricity bendix Town & Country Mod no SIE459TCGR the conections on the replacement thermostat 46THC15/F5G1E2 are different from the original can...
Hi.
This is an universal replacement part, that is the reason why it is different from your TB original part.
The thermostat should have the temperature probe already attached.
Fit temperature probe and thermostat, then connect the element (s) wires on one side of the thermostat. The order in which you connect element polarity to thermostat does not matter. The thermostat will cut off power to element when the specific temperature is being reached by the temperature probe.
Dec 12, 2009 | Ovens
I need a wiring diagram for the replacement ERCU on the JKP27WW1WW oven. Our oven is from 1994 and the new 'clock' module (ERC3) is slightly different where it connects to the 'bake' and 'broil' contacts....
I am not sure if this will help you but I did find a fellow that says he has the adaptable diagram for an updated part on this forum :
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/15496-wiring-diagram-oven-control.html
Oct 30, 2009 | GE JKP27 Electric Double Oven
Thermador CMT21 clock and timer don't work
If you have the old analog clock, there is a new digital replacement kit that makes this oven look modern and give it more life
Mar 17, 2009 | Ovens
Dim LED on SC301 Thermador
local part whare house can sell you a "dim clock" kit for your machine i believe it contains a new display board as well new wire harness
Mar 14, 2009 | Thermador SC302T Electric Double Oven
Replace clock timer
ok bobo lets go....always unplug unit first...pull the range from the wall,,,best if you get behind it if you can,,,now you those 8 phillips head screws around the top back of console..remove that bact console panel...now there 4 screws holding the clock in remove screws but not the wires..let the old board just hang from wires,,your close now ...put new board in there did you get the overlay with the new board ,,no..so take that flim strip overlay of the old one,,ok mount the new clock put back for screws,,,take the old clock timer connection off one by one and put on new clock ,,...you did it,,,just reverse to put together,,,
Dec 29, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Troubleshooting failed bake element
What exactly do you mean when you said element caught on fire?
Jul 31, 2008 | Ovens
Clock display too dim
You are going to need a display kit to fix this. It comes with a new display and relay board. The kit is about $200 and is somewhat difficult to install. This repair altogether usually runs about $400 to fix if you dont have someone handy that can do it for you. It involves removing and replacing at least 20 wires from the relay boards, as well as either pulling the oven from the wall or working in a tight space to change the board. You may be able to find just the display board somewhere, and that is very easy to install, but I've only ever gotten the part as a kit. Hate to be the bearer of bad news. Good Luck!
Aug 16, 2006 | Thermador C301U Electric Single Oven
Ovens Logo
61 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
