Question about Vacuums
I need 2 new handles for my 7 quart stock pot, it is a REBA... the pot is fine, i want to keep it, please help me find replacemtn handles by description & pictures thanks
  • rlsb000 Aug 04, 2010
    when removed, the handle has these numbers:
    366BA
    i can also tell you there is a metal piece sticking out from pot...
    and that the screw goes in at 45degree angel -through handle into the extruding metal piece.
    Can you help me find a place that offers 3D views of their handle replacements??
    the brand in Renaware...
    it is prob old.
    thanks
  • Vacuums Master
  • 6,826 Answers
Http://renaware.com/Locate+a+Consultant/default.aspx
The above is a link to contact a consultant for Renaware.
Also, this not a vacuum which it is listed under, it's a 7 quart stock pot.
If you want the parts, I think the best thing to do is to deal directly with the manufacturer of your product.
Posted on Aug 05, 2010
  • 3,230 Answers
HI there,
Well it is very hard to find them separately, you may please tell us the model number of we can try to help you.
Thanks
Posted on Aug 04, 2010
I need to print how to assemble a bissell proheat shampoorer
First locate screw pack (you will need a Phillips screwdriver). 2 long Phillips screws with hex nuts, 2 short Phillips screws. Should be taped to under part of handle.
2, Put upper handle into lower handle.
3, feed the power cord through the tool caddy from the flat side. Place caddy to handle so the hex shaped holes on upper portion.
4. Place the hex nut in the hex shaped hole and insert long bolt through the front of the handle. Do the same on the other screw and tighten them snuggly. Be careful not to over tighten them.
5. Insert small screws into lower 2 holes through the back side of the lower hose rack. Turn until tightened.
6. Attach tool(s) (that would be a small brush or the pet brush attachment to end of hose and on the attachment holder on front of upper handle.
7. Wrap hose around large holder closest to handle and power cord is wrapped around outer holder with rotating clamp.
Hope that helped
Dec 11, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
I replaced the handle on my Hoover UH30010 Platinum Bagged upright and now the check bag light is on and vac will nut run.. Is there a reset button? How do I fix this?
Hey. I believe you will need to replace the main PCB board too. My new handle was sent with a new PCB board. However, I tried just replacing the handle first and it acted the same way you describe. Once I changed the PCB board it worked fine. Hope this helps.
May 25, 2012 | Hoover Ultra U6430-900 WindTunnel Bagged...
Is it possible to get a liner for a rival 1 quart crock pot model # 3200/3?
Although Rival does sell replacement parts, I could not find any listed for the model you have.
Perhaps you might like to look at their replacement parts webpage:
http://www.crock-pot.com/CustomerService.aspx?id=rpt
They also have a toll-free number, 1 (800) 323-9519.
Good luck from Detroit, MI.
Jun 12, 2011 | Vacuums
Hi a curve piece of wire or metal fell out of the handle when taking it apart.Can`t figure out where it goes?
If it is about 2" long , it is the snap ring almost right at the end in the narrowest part which keeps the extension tube in place .
If it is about 7" long , It is the antistatic strip which sandwiches between the 2 halves of the handle underneath.
Hope this helps.
Jan 03, 2011 | Miele S514 Solaris Electro Plus Vacuum
Seem to have a belt slipping problem. The motor runs but the belt is not turning. Have been trying to get new belts. IMPOSSIBLE !!! I have two machines...148 15600 and 385 1233280
I assume you need belts for both machines? Searspartsdirect (SPD) are the best place for Kenmore replacement parts.
There are 2 belts on the 385 1233280 - the timing belt and the drive belt. Both are in stock at SPD and can be obtained by clicking on the following link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-machine-Parts/Model-3851233280/0582/1220000/00024020/00008?blt=06&prst=&shdMod=
If you hover over the exploded parts diagram you can see a larger view. The timing belt is number 7 and the drive belt is number 15. If you scoll further down the page you can add them to your shopping cart.
They also have both belts for the 148 15600. They are numbered 16 and 17 in this diagram:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-machine-Parts/Model-14815600/0582/1220000/00033316/00008?blt=06&prst=&shdMod=
Again both are in stock, and can be ordered by scrolling down the page and adding numbers 16 and 17 to your shopping cart.
Yoiu may be able to get these from a Sears store, but you can any which you need from here.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 16, 2010 | Vacuums
I have been trying to find the pot for the Masterbuilt Electric Turkey fryer since before Thanksgiving. Now with Christmas around the corner, I still can't use my fryer because I need to replace the pot...
Please click on the following link to obtain the part you need for your fryer:
http://www.appliancefactoryparts.com/gasgrillparts/helpcenter/breakdowns/masterbuilt/masterbuilt-20010306.html
The inner pot costs $49.98 but I always suggest contacting online suppliers to confirm they have stock and their shipping times before ordering. Their phone number is 1-800-955-7075, or complete the online help request here; http://www.appliancefactoryparts.com/support/open.php
If they are unable to help you, you should be able to get one direct from Masterbuilt:
Masterbuilt Customer Service:
Phone: 1-800-489-1581
Email: customerservice@masterbuilt.com
The part number you need to quote is 902060010.
These are the only suppliers I can find at present, but please post back if you need further assistance and I will try to find some more suppliers for you.
Regards,
BElectric
Dec 07, 2010 | Vacuums
Water won't come out when you press handle to shampoo carpet.
I Had the same problem with my model 79011...take the upright handle apart & you will see a pot-metal rectangular box midway down the lower section of the handle with wires on it & 2 hoses attached. This is the water heater unit. LET IT COOL IF YOU JUST HAD THE UNIT ON AS IT WILL BE HOT!!! Take the hoses off & carefully **** the inlets out ( do NOT probe more than about an inch in) with a piece of coathanger wire. Flush heater unit out by hooking a peice of hose up to the heater unit & blow into it to flush the loosened crud out. Hook it all back up & it should work like new! What happens, is the alkalis in the cleaning solutions react with the pot-metal & cause corrosion to build up, eventually clogging the unit, thus not allowing waterflow thru it. Built to fail just like all modern junk! ;) Hope this helps! Ross
Sep 07, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
I have a kirby legend 11, the long handle is loose, how do I tighten it please?
If it is not staying up the handle falls down then is caused by the handle spring assembly. Replace the assembly and it should do just fine. There about 7 different components inside the shell, it's usually the spring but after so many years the bushing and shaft could be bad as well. Recommend to change the whole assembly and it does require a specialty tool to tension the spring assembly.
Nov 03, 2008 | Vacuums
Model number U5763900 Serial Number 090400013588 Handle broke off just above the four screws that attach it ti the boby of the vac. Hoover does not list parts for models that are more than two years old....
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=658103
Generic problem for all Vacuums
Posted by rlholif on Jun 09, 2008
Model number U5763-900 Serial Number 090400013588
Handle broke off just above the four screws that attach it to the body of the vac. Hoover does not list parts for models that are more than two years old. The vac operates perfectly but without a handle my wife cannot use it, where can I find a part replacement. Easy to remove four screws and replace. Don’t want to drive 100 or more miles to find an authorized repair shop. Oh yes, this is a Hoover Preferred Wind Tunnel Bagless
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You have all the information needed but I would contact your local vacuum cleaner dealer and they may have a good used one or they may stock a new handle for your you or they can ship you one If you live too far from a factory authorized dealer. The vac shop that I worked in always had good used parts for ½ the price and it worked just fine – the only difference was the color and for the handle that would not make a difference in the performance and your wife could use the vacuum again. Also Hoover can ship the part to you providing they have it in stock. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Vacuums
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
