Question about Gateway M285-E Notebook
Friend gave me his laptop. Will not boot from hdd. No os found. Wants to boot from lan. How do i access the hdd? Will not let me change boot options.
The problem is in the BIOS settings. You can change the boot device there
Posted on Aug 13, 2010
ASUS K55A won't boot from OS installation on C: Drive. HDD does not show on BIOs boot.
try re seating the drive and your ram. if it does not show then your hard drive is bad.
Dec 28, 2014 | ASUS K55a 15.6-Inch Laptop Black Intel...
My laptop computer upon start up says the following: Check cable connection! PXE-MOf : Exiting Intel PXE ROM No bootable device -- insert boot disk and press any key I tried taking it apart to check...
Go to BIOS Settings pressing F2 while booting up .Change the Boot order 1st Choice should be HDD.If it is already HDD ,your HDD or operating System is up to something
Jun 13, 2011 | Computers & Internet
I recently got a Samsung notebook from my friend (NP-R540). He told me that as soon as he presses the power button on the laptop, it advances up till the BIOS and then stays that way. Since I am a student...
yes, reinstall a new OS. :D just boot the OS installer and it should work. since pc loads BIOS that means you could still change which drive you would want to boot in to
Mar 27, 2011 | Samsung Computers & Internet
When i am swiching on the laptop it shows os not found
Dear Friend,
As there is no primary drive in this vaio, it boots form Hard drive. If OS on hard drive is corrupt OR HDD is bad then you will get such massage. Go to set up. Enable external booting option. Try booting the system from USB pen drive ( You have to make a bootable pen drive ). If it boots then you have to replace HDD.
Dec 05, 2010 | Sony VAIO VGN-UX280P Notebook
The laptops said the operating systems was not found first and now the laptop wont start up.
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH.
2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM
2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD.
BIOS OPTION----CONTINUOSLY PRESS F2 KEY.
Nov 18, 2010 | Gateway MX6453 Notebook
Sir my laptop is does not start. error ir operating system not found.
If the laptop does not find the operating system on boot up it's ether the HDD has failed or the Operating system is corrupt the only answer is to reinstall the operating system or change the HDD.
You could try getting into the Bios on boot up normally by pressing F12 after pressing the power on button and checking if the laptop is seeing the HDD.
I say F12 but without knowing the laptop model it's a guess.
It should tell you on the boot up screen which function key to press to enter the Bios.
Once in the Bios check to see if the HDD is listed if it is the laptop is seeing it so it should be a simple matter of reinstalling the OS if its not then the HDD is faulty you will need to replace it and reload the OS.
Sep 12, 2010 | Computers & Internet
IDE#0 ERROR
Usually the HDD is set on IDE #0.
The PXE error appears if the notebook tries to boot up from the LAN but the cable is not connected or there is no possibility for LAN booting.
In my opinion there is something wrong with the HDD or the BIOS cannot recognize the HDD correctly. I would recommend checking the HDD pins. Furthermore you should change the booting order in the BIOS.
Apr 24, 2009 | Toshiba Satellite A100-S8111TD Notebook
Computer loads operating syatem not found
I've gist had the same problem after flashing bios ...
go to BIOS and change the SATA mode to IDE. it worked for me.
original instructions:
http://forums.lenovo.com/lnv/board/message?board.id=N_Series_Lenovo_3000&thread.id=10549
Feb 23, 2009 | Compaq Computers & Internet
Booting problems with acer laptop - no operating system found??
PXE (pronounce Pixie) is an agent used to boot on to the network.
It's using the DHCP protocol to localise a server where the image of the OS is located
If, for any reason, the hard drive is not seen the computer will attempt to boot on the network controller.
This can be caused if the hard drive is missing, unplugged or corrupt, or simply by not having the boot order configured correctly.
When you start your laptops, press F2 repeatedly until you enter the bios set up, navigate to the boot order and make sure that the hard drive (sometimes listed as HDD....) at the top of the list.
Hope this helps, let me know if you need anymore help.
Jan 27, 2009 | HP Pavilion dv6000z Notebook
IBM Thinkpad T30
there are programs you can buy .
but for no money you can just boot the xp cd and reinstall
Mar 04, 2008 | IBM ThinkPad R52: R52 P M 760(2.0GHz),...
Gateway M285-E Notebook Logo
82 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
