Please can you tell me what each of the disc slots are for on the front of the 3220 e-machine tower computer.
    President:
  • 2,571 Answers
You are probably refering to the card reader.
This enables you to read/write to removable memory cards.
Posted on Aug 04, 2010
  • Roy
    Roy Aug 04, 2010
    Thanks for the 1 thumb mate....
    If you where able to describe what you needed help with , I may have been able to help more.
    YOU ASKED "please can you tell me what each of the disc slots are for on the front of the 3220 e-machine tower computer."
    The only SLOTS will be ...
    Either a card reader.............
    A floppy drive (no longer used)
    a DVD/CD drive
  • Roy
    Roy Aug 04, 2010
    Google you model/make manual
Charging problem
Posted on May 08, 2012
How do I connect a second dvdrw to tower
I connected a second one to mine by just using the install disc that's included and it sets it up as additional drive (example-my second one is drive H) hope this helps your problem
Nov 01, 2017 | Tower Computers & Internet
A disc fell behind the disc tray in my computer.
There should be a small manual eject pin hole in front of the drive tray. Force it open with a straightened paper clip. Disc slots don't have trays so this will not work. You will have to open the machine instead.
Feb 06, 2013 | HP Pavilion Computers & Internet
Is my linux computer compatible with windows xp software? are the parts interchangeable? example= installing a linux video card in a windows 7 tower?
Most devices that have Unix drivers will also have drivers available for some versions of Windows. Asus lists XP drivers for this board: http://www.asus.com/Motherboards/AMD_Socket_754/K8V_SE_Deluxe/#download . The K8V-SE Deluxe motherboard is not listed as Win7 compatible (but it's not listed as known incompatible either). To test if this board is Win7 compatible, update to the most recent BIOS, then use a Win7 install DVD to search for drivers and other support. (I know the Windows Update disc confirmed that my WinXP box would support Win7.)
For moving components into another computer, you will need to identify the exact device that you want to move and the slot/interface for that device. For example, since ASUS K8V-SE Deluxe motherboard has an AGP video card slot, it will not fit in a newer tower with only PCIe or PCI slots. If your Win7 tower does have an AGP slot, you may need to look in will amongst the drivers for "legacy cards". Finding an XP driver will be fairly easy. The Windows 7 driver may not exist and Win7 may not run without an external video card (if it can load at all).
I hope this helps. If you are looking at a different motherboard or wish to check specific components, please add a comment with the make and model of those parts. I'll be glad to try to find additional information. Include in your comment whether the Win7 tower is/will be running Windows 7 32-bit or 64-bit. Drivers for the 32-bit Windows are more common since they don't need the signature. (To check if a Windows machine is currently running Win7 64-bit, click Start > Control Panel > System and Security > System. If the title ends with x64, it's the 64-bit OS. Otherwise it's the 32-bit version.)
May 11, 2012 | ASUS K8V-SE Deluxe Motherboard
How to install a usb pci card to a desktop case computer, it is not a tower. please answer. thank you
Can you please specify what model is your device. Usually its the same as with tower type cases, its just that tower are stand in vertically. You need to purchase Add-on PCI card for USB, and you also need to check if your computer has PCI slot for the add-on card.
Jul 08, 2011 | IBM Computers & Internet
Printer connect
There are two types of slots USB and Parallel ports. You probably have a USB, it should be a small rectangular head, with no holes or pins. You will find a matching slot on the side of the laptop. But that's not the last step as you have to run the disc that came with the printer to install it on the laptop. You will not be able to use the printer until that is done, unless it was added at an earlier date. If you have any questions let me know.
Before logging out pleae rate this solution with 4 stars.
Feb 02, 2009 | Office Equipment & Supplies
Can you tell me where USB port is located in HP pavilion MX75
USB ports are located on the back and also on the front on newer desktop PCs. These are on the computer tower - not the monitor as your posting is categorized. They are rectangular slots with four copper contacts inside.
Jan 30, 2009 | HP Pavilion MX75 17" CRT Monitor
Going to put in more memory!
goto httop://www.crucial.com and run the automatic detection service, it will tell you exactly what ram you can get and what ram is in there and they have about the best prices as well.
Dec 30, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Can't get disc out of tower
Restart the computer, and when computer is starting up keep pressing many times the eject button until disk pops out.
Do this a couple of times
If this does not work you will need to remove the CD/DVD unit and stick a paperclip on the CD eject hole, in the front side of the CD/DVD drive.
Sep 04, 2008 | E-Machines eMachines Desktop PC
Packard bell tower pentium 2= CANT REINSTALL WINDOWSXP PRO
Hi Rob, unfortunatly there is no legal way to load Windows XP without your own disk. Microsoft only allow this to be loaded on one computer per disk and you can not use a friends disk as each computer has its own electronic signature. this is recorded when XP is activated and the disk key is recorded with that signature so it can not be used on more than the one computer.
Regards mistyman
Dec 22, 2007 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Computers & Internet Logo
19 people viewed this question
Alun Cox
David Payne
David Payne
