Question about Lowrance Boating
The plastic cover screen on our Lowrance LMS350A is dirty on the inside. How do we clean it.
    President:
  • 1,194 Answers
Thanks for using Fixya.
Depending on when you got your Lowrance you should go get it exchange from the store (If it is warranty period).
Sorry to tell you that there is no way of cleaning it, do not try to open the screen and clean it because you are gonna mess it up more then what it is.
You might be able to send it to a store were they may clean it for you
Good luck and have a nice day.
Posted on Aug 04, 2010
How do I get to and clean the inside of both headlamp glasses because my car failed the MOT because the inside of the headlamp units are very dirty. Not the reflector but the front plastic cover.
NORMALLY THE ISSUE IS WITH THE OUTSIDE OF THE PLASTIC COVER. THEY CAN BE CLEANED WITH HEADLIGHT CLEANING KITS FROM ANY PARTS STORE.IF THE PROBLEM IS REALLY ON THE INSIDE THEN REPLACEMENT IS NEEDED
Dec 18, 2014 | 2002 Hyundai Santa Fe
How do I remove the outer plastic cover on the head lite assembly
the outer shell is not separable from the housing. you will have to replace the complete headlight shell.
Sep 28, 2014 | Jeep Grand Cherokee Cars & Trucks
Lowrance screen
there is a spray you can buy to clean your screen same stuff you clean glass's with and did you get cloth that came with your lowrance that's what its for
May 06, 2013 | Lowrance ELITE 5 GOLD COMBO
Remove tv screen from hitachi projection tv
The entire screen unit can be removed but first remove rear cover and look at the lens--clean with a lens cloth etc----peek up inside and look at the mirror--if not dirty or smudged just clean the lens.
removing the screen with its frame can be tricky--easy to damage the screens etc. Removal usually requires front speaker grill to be removed first---most just pull off but a few are secured from rear by some screws.
With it off look to see if at bottom of screen there are a row of screws--if the entire front unit can be removed it will pull out at bottom and be snapped in place.
A better suggestion is look at rear of set above back cover--if the upper part is plastic--it with the back removed can also be removed--careful as mirror is bolted into it---that way you can clean the mirror and get at the lens for the tubes without trying to remove screen unit--some of the smaller sets this is the ONLY way to get at the mirror.
Yes a number of screws but if plastic upper rear comes out with mirror much easier and safer way.
May 29, 2012 | Televison & Video
Our oven door has become dirty from juices spilled and has got in bewtween the glass on the door. Can this be taken apart and cleaned out????
Depending on the make and model of microwave it should be cleanable.
If you have countersunk screws along the outer of the door edge, unscrew the screws and then the plastic from should pry off allowing access to clean the inside portion or let you remove even more screws allowing access to the inside.
Some have a plastic bead on the inside of the door that covers up the screws. That is held on by long plastic clips, covering the screws that hold the front on.
Hope that helps.
Dec 10, 2010 | Microwave Ovens
Screen seems dirty from the inside. How do you clean?
around the rim of the screen there is a plastic cover you can pull this off there are clips holding it then you can take protection screen off and clean
Oct 16, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Can't clean the inside of the glass door--the screen blocks it
Have to replace the door. You probably removed the protective plastic cover inside the unit intended to keep material from passing through the screen into the area where the glass is located. That was my problem. I thought the plastic was shipping material. My Bad! No way to clean the glass from the inside because they "never imagined" someone would remove the plastic cover.
Nov 10, 2008 | GE XL1800 1100 Watts Microwave Oven
Cleaning the screen cover on my sony big screen
To clean its front screen, you should not open front cover as its complicated procedure. just take off its back cover as its shown in picture and use air-blower to clean dust. Then use soft cotton cloth to clean its screen from internal and 3 bulbs / lenses (CRTs) and job is done.
Need further help, let me know.
Bye.
Sep 13, 2008 | Sony KP-57WV600 57" Rear Projection...
My Haier 5,200-BTU Window Air Conditioner keeps freezing up. how do I remedied this?
You need to clean the unit outside(take it out of the window) with a water hose because it is dirty inside( you have to remove screws on cover and take cover off), be sure to cover the electronic control board with plastic so you don't get it wet.Clean fins on front and back with water hose and inside .
Sep 02, 2008 | Haier hwr10xc6 Air Conditioner
Boating Logo
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
