Question about Bosch Refrigerators
I have a Bosch Refrigerator at my church that is not cooling on the Refrigerator side, it is a Model # B20CS50SNW /02. I am an electrican but not an applance tech. The blower fan for that side is not turning, it does try to and it is getting about 12.6 Volts DC, also the Freezer side blower seems to be turning very slowly and seems to have a hard time stating. Also the ice maker is not working, and while the freezer side is still cold some icecream that is in it is very soft so i think it is not getting cold enough for the ice maker to fill, i wonder if the main PC board is bad and not puting out enough voltage to run the blowers? Does anyone know how much and what type of voltage these fan motors are susposted to run on? Bosch# for Fan Motor - 497841, PC Board - 640603, thank you Mike
    Sergeant:
  • 216 Answers
Generally the fans use line voltage, but if you have a controller board and are getting 12 Volts this would be the correct voltage. The problem is the fans. You will need to replace these fans and defrost the freezer and fridge. When the evaporator coils have frozen overdue to insufficent air flow then no fan will be able to cool the fridge. So make sure that once you replace these fans you get a good defrost for at least 8 hours. Unless you use a hair dryer or heat gun to speed up the process. You will find that these fans are about $52.00 each and trying to repair or fix one will only result in a second repair.
Posted on Aug 04, 2010
Testimonial: "that is the answer i got from another expert site, so now i feel very sure and have ordered both fans and will put them in tomorrow, ty very much :) "
    New Friend:
Have Bosch b20cs81snb side by side with similar issue. Replaced evaporator fan and working fine now ice blocking drain after repair opened up bottom freezer panel and thawed with blow dryer. Going to replace fan on fridge side also as seems to not be running well. This was at year 4 for the appliance. Have gone through 2 condenser fans on this fridge as well, seem to only last 1.5 to 2 years. Would rather have more durable fans and use little more electric.
Posted on Jul 03, 2013
  • John d Jul 03, 2013
Looking for bosch refrigerator handle manual to match up parts since no model number on the refrigerator
Take a picture of the display and the whole front. I will try to help you out.
Dec 24, 2017 | Bosch Refrigerators
Verr loud clicking noises every couple of minutes in my bosch frost free fridge freeezer has done since I bought it 6 plus years ago
Hi, I think there is a problem with the refrigerator's compressor,get it checked by an expert. Thanks, C Rahul
Jul 05, 2011 | Bosch Evolution® 500 B20CS50SNW Side by...
Refrigerator section not cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 18, 2010 | Bosch Evolution B20CS50SNI Side by Side...
Bosch side by side isnt freezing
call a repair service locally , but with what you tell us , it may be too late for a fix
Oct 09, 2017 | Bosch Evolution® 500 B20CS50SNW Side by...
Bosch kgn34x00 not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
ghkddg
May 25, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch Refrigerator B20CS50SNW. How much refrigerant does unit take to work correctly? The Model Tag has been damaged.
When you ask how much refrigerant does it take, I'm assuming you have taken out the gas for some reason?. It will depend on what type of gas it uses, but the best way is to remove all the old refrigerant, evacuate the system, Test the system for leaks by checking your gauges that the vacuum does not climb ( ie: the vacuum decreases if it draws in air from a leak in the pipework or joint). If it does not leak then introduce a small amount of approx 0.500 grms of gas, Wait for that to equalize in the system about 10 min's. Start your unit then with a clamp meter on the live wire continue to introduce gas in vapour form until your meter reads maximum load running amps for the compressor fitted. you should then have the required amount in the system. You can work on a plus or minus 0.005 grammes. If it is running on R600a. You must get a specialist in to do it as this is a flammable gas. ISOBUTANE.
Apr 16, 2010 | Bosch Evolution® 500 B20CS50SNW Side by...
Refrigerators Logo
726 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
