Question about Kenwood SW36HT Subwoofer
I have a KenWood SW-32HT and the green light in the back turns on but there is no sound. when i unplugged it from the reciever it made noise when it touched me so i dont think it is broken?
2 Suggested Answers
SOURCE: sw-32ht kenwood subwoofer
Open the case and check the fuses and the speaker to see if it actualy still working and not blown.
Posted on Feb 24, 2009
Have a kenwood sw-32ht green light comes on but have no sound, please help on what it could be
Check the signal or rca's. Make sure the sub is turned on from the headunit. Sounds like you have power but no signal. Also, make sure your power wire has 12 volts. I've seen where the light turns on because remote wire has power, but no power from the battery wire.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Oct 17, 2014 | Car Audio & Video
Using without parking break
Hi James,
Page 27 of the installation manual (http://www.wwstereo.com/_files/155788/documents/Kenwood--Manual.pdf) shows a connection to the parking brake light circuit. It is the Light Green wire labeled "PRK SW" shown below.
If it is connected the way it is drawn, the PRK SW wire is connected between the lamp and the switch that opens and closes depending on the position of the parking brake (set or not). 12 volts is always present from the battery to the top of the lamp. It passes thru the filament to the wire that goes the top of the parking brake switch. So, when the brake is OFF or disengaged, the lamp is off and 12 volts is present on the PRK SW wire to your Kenwood GPS. When you set the parking brake, the ground (symbol is the funny slanted lines under a horizontal line) just under the brake switch passes through the switch and changes voltage at the PRK SW to "ground" or 0 volts. When this happens, the ground on one side of the lamp with 12 volts on the other side of the lamp - make is turn on.
So, what does this mean? Simply tie the PRK SW wire to any grounded metal and the Kenwood will think the parking brake is always set - for as long as it is tied to ground. You can check it with a simple voltmeter to be sure. Set the meter to 12 volts or more, touch black lead to ground & the red lead to the PRK SW wire. Kenwood should only work when at 0 volts (brake set). Release the brake - meter shows 12 volts & the Kenwood shuts off.
I hope this helps & Good luck!
Apr 09, 2014 | Kenwood DNX570HD
Kenwood SW-32HT Subwoofer Dropping sound Yamaha Reciever
Several possible answers. First - is that the Yamaha has a fault that is sending a signal with too much power on it. And the sub detects this and switches off.
Second - either the Receiver or Sub is switching off when no audio is present. A setting problem?
Third - the sub has a fault, possible overload, and goes to standby for safety.
Jul 01, 2017 | Audio Players & Recorders
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
TV won't turn on and green light is solid.
My Dad suggested unplugging the television as it might need to reset itself. We unplugged it, let it sit while I cleaned the back with the vacuum cleaner, plugged it back in and it works fine now.
Jan 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sw-32ht kenwood subwoofer
Oct 26, 2008 | Kenwood SW36HT Subwoofer
Subwoofer doesn't turn on
I felt supid this morning.
I bought a high end cable for my subwoofer.... and it did not work but a regular RCA Cable did. When I went to put the cable back in the package I saw an arrow pointing one way, I turn the cable and it works great.
Dec 12, 2007 | Kenwood VR-405 Receiver
Kenwood SW36HT Subwoofer Logo
503 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
