Question about Bose Wave radio remote control - Graphite Gray Shelf System
My bowes wave radio simply turns itself on in the middle of the night frequently and I have to get up to turn it off. Also, even if it was onn a radio station it comes on at a no station site with lots of static and noise when it does turn itsefl on.
    Brigadier General:
  • 8,546 Answers
Find the manual and UN-set the Alarm function.
Posted on Aug 05, 2010
Want to disable Aiwa NSX-350M clock radio.
Google (Aiwa)(NSX-350M)(manual) without parens for instructions.
Jun 29, 2017 | Audio Players & Recorders
Tv turns itself on in middle of night
Go into the menu options and see if it has a setting for alarm. It may be turning on at the same time every night to wake you up. It is also possible a neighbor has the same infrared code and is pushing their power button and it is turning your on.
Feb 08, 2015 | Insignia Televison & Video
2002 rav4
Ok. If they turn on by them selves. Even at night when the key is removed from the vehicle it may be the day time running light sensor. But with the key out this should not happen. You may have an issue with your security system.
Aug 28, 2014 | 2002 Toyota RAV4
Why bose wave radio touch pad does not work ?
There's a setting to turn the touchpad on or off. Yours has probably been turned off. Here's how to turn it on.
1. Press and hold Alarm Setup (Menu) on your remote until -SETUP MENU- appears in the display.
2. Press Tune/MP3 until TOUCH PAD- is displayed (8 presses)
3. Press Time- or Time+ to select OFF or ON
4. Press Alarm Setup (Menu) to exit the menu, or simply wait 10 seconds.
You're done!
Jul 22, 2014 | Bose Wave Radio
Why does my bose wave radio turns itself off every twenty minutes?
I am not sure how to fix your radio; but my wave radio wasn't working and I took it into a Bose store and got an excellent trade in for a new one. I traded a wave radio without a CD player for a new Wave radio with a CD player. I would take your radio into the nearest Bose store.
Jul 08, 2014 | Bose Wave Radio
When the car is turned off, the radio starts up by itself - in the middle of the night!
fault is the radio, the memory circuit probably shorted or if it has a c/d or tape player, the micro switches and bad.
Oct 14, 2009 | 2005 Volkswagen Golf
Expensive Monte Carlo ceiling fan turns on & off by itself
needs an electrican to inspect
faulty on /off switch
flat batteries/ faulty remote
or
rodents in the roof chewed wiring
Mar 22, 2017 | Monte Carlo Dryers
Sony Dream Machine clock radio
0) Read the last answer first :) it is the most likely.
1) Make sure that the noise is electronic, not mechanical,
a) Electronic noise comes from the speaker
b) Mechanical nose originates in the clock
(older mechanical clocks only)
c) Clocks come in 3 varieties:
Electronic
Mechanical "Flip Leaf"
Mechanical "Motor/ Gear" driven.
2) Assuming that your clock is electronic, there are
only two possibilities for causing static.
a) Extremely intense electromagnetic interference,
as in radio waves, from a thunderstorm or a powerful
transmitter nearby, such as a HAM radio or even
an active cell phone.
Intense electro-magnetic waves can be picked up by
internal wires within the radio which act as an antenna,
rectified (demodulated) by internal diodes and transistors,
filtered by internal capacitors and the speaker's inertia,
and still present enough audio frequency energy to the
sensitive speaker coil to be "quite" audible and irritating.
This can happen even with the power off, when the
interference is so strong that it needs no amplification !
This happens to my computer speakers, every time my
cell phone rings, and starts transmitting a return signal.
3) The power switch is intermittently shorting causing a small
amount of DC power to enter the radio, the more intermittent
the switch, the more noisy it gets.
This causes my old clock radio to turn on by itself when its
not supposed to.
The cause of the problem in either in the main power/ mode
switch, or in the clock driven switch or relay.
4) Old switches and volume controls get oxidized with time
and/or bridged by products of corrosion. The simple solution
is to clean them using a good aerosol contact cleaner,
available from an electronic shop for about 10 bucks.
Simply spray the cleaner into all the switches and controls,
while vigorously exercising each switch or control back and forth.
Make sure that you use a safe "electronic cleaner" designed
for the job. It must be safe on plastics, non-conductive, good
solvent and it must evaporate quickly. Don't breath the stuff !!!
Typically the spray will contain TF (tri-fluoro-ethane), or some
other freon substitute.
Freon (Di-fluoro-di-chloro methane) is bad for the ionosphere,
now illegal in most countries for that reason.
Also stay away from Carbon-Tetra-Chloride, which is
VERY toxic.
Do NOT improvise, or use acetone or alcohols, which may (will)
melt the plastic, causing the controls to permanently seize.
Get electronic contact cleaner from an electronics hobby shop.
Good luck. Martin
Please rate my answers.
Jul 04, 2008 | Audio Players & Recorders
BOOM BOOM BOOM
The Bose engineers in their "infinite" wisdom developed a $300 radio with no, that is NO, tone control. This means the only way to tune bass response is to reposition the Wave radio itself. If you put it in a corner of a room, it will produce the most bass. If it is only against one wall, not so much bass. To reduce bass response to a minimum, you would have to suspend the device from a wire in the middle of the room. Good luck. I would never buy a radio without a tone control; I literally inherited by Bose Wave Radio and use external speakers which do have tone controls.
Jun 10, 2008 | Bose Wave Radio
Radio turns on and off by itself
I think It might be the anntenna.
May 23, 2007 | Emerson CKS3029 Clock Radio
1,588 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
