Question about Kenmore 84072 Electric Dryer
Time to change the dryer or is it worth fixing? When we start the dryer, the motor starts sluggishly and eventually slows down after 3 minutes. As it slows there is a groaning noise. There is a burning smell. It is a 7 year old dryer.
  • 171 Answers
This could be something as simple as a loose or stretched out belt to a jammed pressure roller to a bad motor. could also be the drum is not mounted right due to worn out or missing felt pads and is causing a binding at the front or rear of the unit.
Posted on Aug 06, 2010
Inglis Gas Dryer... mercy me?
Sounds like what you said. Time for a motor. The motor has an internal overload and will shut the machine off if the motor runs hot.
Good Luck
Feb 26, 2014 | Inglis 6.5 Cu Ft Super Capacity Gas Dryer
Baby lock serger motor slows down after sewing 20 minutes. Why?
Call your local service shop. Baby Locks in closets for years usually have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Been there, done that.
Jul 22, 2012 | Baby Lock Eclipse Serger
Kenmore 868738000 Elect Dryer Starts for 10 minutes then stop.
That is gong to be a bad motor. $72.
Tools needed:
Putty knife
nut-drivers
screwdrivers
adjustable wrench
locking pliers
Notes:
Motor blower is reversed threads
Difficulty 1 to 10 = 3
Start by: removing filter and filter housing screws
then remove front panel screws LIFT UP on panel to remove it.
Remove belt remove tub. Get filter housing off
Clean up dryer. Lock down shaft and remove blower. Pop motor mount clips. Unplug motor. make hote of position f motor. Install new motor use nutdriver to snap down clips. I have the manual and some photos. In my sleep I can completely replace a motor in less than an hour and that includes oiling the rollers and idler and doing a through hoovering out the machine. This machine is worth replacing the motor and really a breeze to repair. Nothing has worked better for over 50 years. Go for it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 22, 2010 | Kenmore 62602 Electric Dryer
When the dryer is turned on, it usually starts slow
Could just be the drive belt, or the motor starter is faulty.
Feb 22, 2010 | Dryers
My dryer doesn't want to get syarted every time i try start a noise and the minutes space say E5,can you help me please
it sounds like the motor is getting weak. This is one of those parts that you have to ask yourself is the dryer worth fixing as it will be around $150 for the part. if you are able to fix it yourself it will be worth it if not then replace it.
Aug 21, 2009 | Amana NED7200TW Electric Dryer
Drum turns hard after holding start button down and has a loud hum
that is a sign of the dryer motor going bad,it will fet to the point where it will not work at all just hum when you push the start button,time for a new dryer it's not worth fixing-mike
Apr 28, 2009 | Kenmore Dryers
Dryer is shuting down after twenty minutes cycle time, seems to be overheating.I haved cleaned the vent.
sounds like motor is going bad.eventually it wont start all you will hear is a humm from motor
Mar 05, 2009 | Crosley CDE6000 Electric Dryer
Gas dryer makes loud hum
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Nov 16, 2008 | KitchenAid KGYS850LT Gas Dryer
Dryer runs only when "Start" button is being pushed
--Bad motor run windings
--bad motor switch
These are two possibilities.How old is the dryer. may not be worth it. get the model# from the dryer & price a motor. (new motor cures both of these possibilities)
Oct 29, 2007 | Dryers
Kenmore 84072 Electric Dryer Logo
135 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
