Question about 3Com 7760 (3CRWE776075US) 802.11a/b/g Wireless Access Point
I'm upgrading firmware of the 3com 7760. I'm get from 3com.com and i download a file .img, but in the 3com web interface say "Please Input Address Path for Upload". I selected the file .img. Excuse me for the English, i'm not American.
I know this was from a while ago but 3com 7760's have a problem when uploading it files either firmwere or setting backup files you have to use internet explorer or you will get the "please input address path" error
Posted on Sep 16, 2010
Superstack 3 3848 reset at default
Hi ! I think this solution should be approached. Because this procedure is the same for switches 3Com and HP A-series with Comware OS.
1. Connect light blue console cable between a computer (serial) and the 3COM switch (RJ45 console port)
2. Open PUTTY or Xshell or HyperTerminal with a serial connection and the following settings (19200, 8, 1, N) If not connected may use 9600 or 115200 bps
Starting......
* 3COM 2928-SFP Plus BOOTROM, Version 119 *
Creation Date : Feb 3 2010
CPU L1 Cache : 32KB
CPU Clock Speed : 333MHz
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Mac Address : 002473959EC8
4. When "Press Ctrl-B to enter Extended Boot menu..." appears, press "CTRL+B"
Press Ctrl-B to enter Extended Boot menu...0
Please input BootRom password:
BOOT MENU
5. Press "7" to "Skip current system configuration"
1. Download application file to flash
2. Select application file to boot
3. Display all files in flash
4. Delete file from flash
5. Modify BootRom password
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set BootRom password recovery
9. Set switch startup mode
0. Reboot
Enter your choice(0-9): 7
7. Press "Y" to skip the current config at next reboot
The current setting will run with current configuration file when reboot.
Are you sure you want to skip current configuration file when reboot? Yes or
No (Y/N):Y
Setting...Done!
8. Now Press "0" to reboot the switch
BOOT MENU
0. Reboot
Enter your choice(0-9): 0
9. The switch will reboot, allow it to fully boot this time
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Starting to get the main application file--flash:/S2900-CMW520-R1101P09.bin!...
The main application file is self-decompressing................................
.........................Done!
System is starting...
Configuration file is skipped.
User interface aux0 is available.
10. Press "Enter", you will not need a password to login.
Press ENTER to get started.
<3Com Baseline Switch>
#Apr 26 12:00:16:292 2000 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>: login from Console VMadmin.co.uk
%Apr 26 12:00:16:461 2000 3Com Baseline Switch SHELL/4/LOGIN: Console login from aux0
11. Now type "initialize" to delete the configuration file and reboot the switch once more, Press "Y" to accept reboot.
<3Com Baseline Switch>initialize
The startup configuration file will be deleted and the system will be rebooted. Continue? [Y/N]:Y
Please wait...
#Apr 26 12:00:33:537 2000 3Com Baseline Switch DEV/1/REBOOT:
Reboot device by command.
%Apr 26 12:00:33:641 2000 3Com Baseline Switch DEV/4/SYSTEM REBOOT:
System is rebooting now.
12. The switch will full start up again, this time completely factory reset.
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Startup configuration file does not exist.
13. Press "Enter", then enter the username "admin" and password "<blank>". Press "Enter" and you will be logged in.
Login authentication
Username:admin
Password:
#Apr 26 12:00:19:811 2000 this article is from VMadmin.co.uk 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>:admin login from Console
%Apr 26 12:00:19:981 2000 3Com Baseline Switch SHELL/4/LOGIN: admin login from aux0
14. If you type "summary" you will see all the switch details.
Amongst these details are the IP address of the switch. If you have DHCP on your network this switch is connected to it will receive one as in my case below, so I can now configure the rest via a web browser.
If not you can use the "ipsetup" command to set a static management IP and access via a web browser.
<3Com Baseline Switch>summary
Select menu option: Summary
IP Method: DHCP
IP address: 192.168.1.250
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.254
Current boot app is: flash:/S2900-CMW520-R1101P09.bin
Next main boot app is: flash:/s2900-cmw520-r1101p09.bin
Next backup boot app is: NULL
3Com Corporation
3Com Baseline Switch 2928-SFP Plus Software Version 5.20 Release 1101P09
Copyright (c) 2004-2010 3Com Corp. and its licensors. All rights reserved.
3Com Baseline Switch 2928-SFP Plus uptime is 0 week, 0 day, 0 hour, 1 minute
128M bytes DRAM
128M bytes Nand Flash Memory
Config Register points to Nand Flash
Hardware Version is REV.B
CPLD Version is 002
Bootrom Version is 119
[SubSlot 0] 24GE+4SFP Hardware Version is REV.B
15. Once you can access the web management page for the switch make sure you set a strong password for "admin" and store it in a secure encrypted location for next time.
16. Don't forget to save your new configuration! Otherwise the switch will be at factory defaults if the power goes off!!
Jul 24, 2017 | 3Com SuperStack 3 3848 48-Port Gigabit...
We have a 3CRWDR101A-75 3com wifi router and its not upgrading the firmware, I downloaded the firmware from the site and then when I try to upgrade all I get is file verification failed... any thoughts...
The downloaded file is "corrupt", and thus it fails the "verification" process.
Download the firmware again, and compare the two files.
Or, use a different computer to download the firmware, and to do the firmware-update.
Apr 20, 2011 | 3Com OfficeConnect Remote 612 ADSL Router
Wire less disconnect very often When i disconect the wireless and connect again it takes time to reboot the wire less
Disconnecting wireless problems can be cause by any number of things. Please click on this link and follow my instruction to identify the problem and fix :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Feb 11, 2011 | NetGear WGR614L Wireless Router
My belkin play router works fine on my xbox, yet when I try to use my computer I get a "this webpage cannot be displayed" error, but when I reboot the play router it stops for a few hours
Hi lets we tried to Upgrade your firmware version.
Updating your Routers Firmware
The following steps will show you how to update your routers firmware using its web interface.
You do not need to be connected to the Internet as this interface is built into the router itself.
Setup Steps
Locate and download the firmware file from the Belkin support site. (Type in your part number in the search box in the top right and look for "Firmware" in the title)
Save the file to a location on your computer where you can get to it easily, such as your desktop.
Connect the computer to one of the four gray ports on the back of the router.
Open a web browser on the computer.
In the address bar of the web browser, type http://192.168.2.1 and press Enter on your keyboard.
Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
Click on "Firmware Update" toward the bottom of the left-hand menu.
Click the Browse button toward the middle of the screen to search for the file you saved previously.
Select the firmware file by left-clicking on it and then click the Open button in the lower right corner of the window. This will take you back into the router's interface.
Click the Update button.
A prompt asking, "Are you sure you want to continue with upgrading?" will appear. Click OK.
A second prompt will open telling you the router will not respond during the upgrade and warning you not to remove the power supply to the router. Click OK once more.
Congratulations. The firmware has been updated successfully
Please don't forget to rate techbelkin.
Sep 09, 2010 | Belkin Wireless Play Router (F7D4302)
WRT120N no .bin or .img file in firmware update download
Hi Friend
in order to upgrade the firmware please follow the steps:
1. Click the link (http://homesupport.cisco.com/en-us/wireless/linksys/)
2. Enter the model number of the router and hit enter.
3.Click Download Tab
4.Now enter the hardware version of the router (which you can find by turning the router upside down)
5.Now you can download the firmware which is a .bin file and save it to the desktop.
6.Open the router page and click Administration and click Firmware upgrade.
7.Select the file from the desktop by clicking Browse and start upgrade.
8.Turn off the router for 30 seconds after upgradation and turn it on..
i hope this will resolve the issue.
Regards
Chiranjeet
May 21, 2010 | Linksys WRT120N Router
WRT160n version 2....Can log onto internet but it takes 3 or 4 attempts before it will load my homepage...once connected to homepage when I click on another link it takes forever to load and then goes into...
you will need to upgrade the firmware. you have already downloaded the firmware. that file is .bin file . you will not be able to open that file. To upgrade the firmware, you will need to open the set up page of the router.
click here to know more about routers and network
Jan 18, 2010 | Linksys WRT160N Wireless Router
Netgear DG836GT
OK. First, that dg836gt_1_02_09.img file does not seem to be a firmware file. You need to get a .zip file or a .bin file to upgrade the firmware. Check Netgear's website for the current firmware. If it is a .zip file, then you need to extract the .bin file from the .zip file with winzip software. Then, log into your router with Internet Explorer by typing it the routers IP address in the address bar like this http://xxx.xxx.xxx.xxx. Enter user name and password. Look for a tab that states software update. Browse for the .bin file you downloaded or extracted from the .zip and click update.
Apr 25, 2009 | NetGear DG834 Router
My 3com officeconnect doesn't work after upgrding the firmware
Are you able to login to the router? If you can reset the router to factory defaults..If you can't login to the router...Is there an external reset button on the router you could try to reset. with a paperclip? Otherwise, I had this happen on a linksys router/switch. New router time. You should just return it where you purchased the product. There was already something seemingly going wrong if it was rebooting. 3 weeks? just return it. don't even mention the firmware update. Here is the site info for 3com: http://knowledgebase.3com.com/ OfficeConnect - Firmware upgrade fails with incorrect user interface image Problem: Incorrect user interface image Problem: Firmware upgrade fails Problem: Error when upgrading firmware Problem: Incorrect firmware Problem: Wrong firmware Fact: Firmware Fact: Download Fact: Update Fact: Upgrade Cause: The downloaded .exe has not been extracted Fix: The downloaded .exe needs to be extracted by double clicking on it. When performing the firmware update use the extracted files that were obtained from the "exe" file. e.g You will obtain a "bin" or "dlf" type of file which is the firmware required for your upgrade. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | 3Com OfficeConnect Remote 612 ADSL Router
Open Questions:
See all 3Com 7760 (3CRWE776075US) 802.11a/b/g Wireless Questions
3Com 7760 (3CRWE776075US) 802.11a/b/g Wireless Access Point Logo
2,532 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
john smith
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
