Question about XRS-757 Radar Detector
Can you tell me what the symbols stand for? i.e. Ka1, Ku, X1, X2, POP etc.
  • 3 Answers
Here is a great explanation of radar types
http://www.radarbusters.com/detectorsfaqsarticle.cfm
Posted on Aug 04, 2010
Factor quadratic equations
The calculator cannot do symbolic algebra. If equation is aX^2+bX+c=0, write it in the form a(X^2+(b/a)X+(c/a))=0 and solve the quadratic equation X^2+(b/a)X+(c/a)=0. Get the approximate roots X1, and X2 (if they exist) and write your original equation in the for
a(X-X1)(X-X2)=0
Your quadratic polynomial is factored as a(X-X1)(X-X2)
May 28, 2014 | Casio Office Equipment & Supplies
Vision battery date code
ALL VISION BATTERY MODELS
Date code stamped on top of battery container
X1 X2 X3 X4
Where X1 denotes year of manufacture A = 2001 B = 2002 etc.
X2 denotes month of manufacture A = January B = February etc.
X3 X4 denotes date of month of manufacture
Eg AH27 = battery manufacturing date 27th August, 2001.
Dec 12, 2013 | Exide Chloride Power Station (EXP2000) UPS...
Hello How to solve complex equations using casio fx 9860G AU For example (2+i)A+B=6 2A+(1+i)B=1 How to solve A and B using this calculator
The simultaneous equation solver requires the coefficients to be real. Similarly matrices must have real coefficients.
Your only alternative is to express each of A and B as a real part and imaginary part.
A= x1+iy1
B=x2+iy2.
Substitute x1+iy1 for A in the two equations. Substitute x2+iy2 for B in the two equations. Do the algebra. Gather real parts and gather imaginary parts. Split each original equation into two equations: One equation comes from setting Real Part of left side = real part of right side (1); the other equations comes from setting the imaginary part of left side= imaginary part of right side (here 0).
Do the same procedure for the 2nd original equation.
At the end of the process you will have 4 coupled linear equations in the 4 unknowns (x1,y1,x2,y2).
Then you might want to use the calculator to solve the derived system. Once you have x1,y1,x2,y2 you reconstruct A=x1+iy1, etc.
Aug 29, 2011 | Casio FX-9860G Graphic Calculator
What is the equation of the pair of points (-5,-8) and (-3, -1)
The site seems to eat the plus signs I enter, so I will use PLUS to symbolize addition.
To find the equation of the straight line (
y = a*x PLUS b) that passes through two points P1(x1,y1) and P(x2,y2) , you need to use
1. the coordinates of the points to calculate the slope a (gradient) as a=(y2-y1)/(x2-x1)
2.
Replace the calculated value of a in the equation and write that one of the points ( P1(x1,y1) for example) satisfies the equation. In other words y1=a*x1 PLUS b.
Here y1 and x1 are known values, a has been calculated, and only b is still unknown. You can now use the equation
y1=a*x1 PLUS b to calculate b as
b=(y1-a*x1)
Example: Equation of the line through (1,5) and (3,6)
Calculate the slope (gradient) of the line as a=(y2-y1)/(x2-x1) where y2=6, y1=5, x2=3, and x1=1. You should get a=(6-5)/(3-1)=1/2
The equation is y=(1/2)x PLUS b, where b is not known yet.
To find b, substitute the coordinates of one of the points in the equation. Let us do it for (3,6).
The point (3,6) lies on the line, so 6=(1/2)*3 PLUS b.
Solve for b: 6 MINUS 3/2=b, or b=9/2=4.5
Equation is thus y=(x/2) PLUS 9/2 =(x PLUS 9)/2
I trust you can substitute you own values for (x1,y1, x2,y2) to duplicate the calculations above.
Jan 27, 2011 | Texas Instruments TI-84 Plus Calculator
How to factor a polynomial equation on casio fx-300es?
The Casio FX-300ES does not handle symbolic algebra. So it cannot factor a general polynomial expression. The methods can be found in any book on Algebra.
However if you are interested in approximate factorization of quadratic and cubic polynomials, you can use the calculator to do that. It can solve aX^3 +bX^2+cX+d =0 and the quadratic equations.
If you want to factor a cubic polynomial P3(X) = aX^3+bX^2+cX+d , you write the corresponding cubic equation as aX^3+bX^2+cX=d =0 , then you divide all terms of the equation by a to obtain
X^3+(b/a)X^2+(c/a)X+(d/a)=0.
You use the calculator to solve (approximately) this equation.
Suppose you find the 3 roots X1,X2,and X3. Then the polynomial X^3+(b/a)X^2+(c/a)X+(d/a) can be cast in the factored form (X-X1)(X-X2)(X-X3) and the original polynomial P3(X) can be written as
P3(X) = a*(X-X1)(X-X2)(X-X3)
You can handle the quadratic polynomial the same way.
P2(X) =a*(X-X1)(X-X2) where X1, X2 are the two real roots
Hope it helps.
Sep 27, 2009 | Casio fx-300ES Calculator
How do you Factor a Polynomial on a Casio fx-300ES
Sorry, but you cannot use this calculator to factorize a general polynomial.
1. It does not know symbolic algebra.
2. It can only manipulate numbers.
However if you have polynomials of degree 2 or 3, with numerical coefficients (no letters) you can set [MODE] to equation and use the equation solver to find the real roots of 2nd degree or 3rd degree polynomials. Assuming that your polynomials have real roots (X1, X2) for the polynomial of degree 2, or (X1, X2, X3) for the polynomial of degree 3, then it is possible to write
P3(X)= a(X-X1)(X-X2)(X-X3)
This is an approximate factorization, except if your calculator configured in MathIO, has been able to find exact roots (fractions and radicals)
where a is the coefficient of the highest degree monomial aX^2 +...
or aX^3 +....
But I have a hunch that this is not what you wanted to hear.
Good luck.
Mar 08, 2009 | Casio fx-300ES Calculator
How to factor with this model
Sorry, but you cannot use this calculator to factor a general polynomial.
However if you have polynomials of degree 2 or 3, with numerical coefficients (no letters) you can set [MODE] to Equation and use the equation solver to find the real roots of 2nd degree or 3rd degree polynomials. Assuming that your polynomials have real roots (X1, X2) for the polynomial of degree 2, or (X1, X2, X3) for the polynomial of degree 3, then it is possible to write
or aX^3 +....
While the [MODE][5:Equation] only handles quadratic and cubic equations, the [SHIFT][SOLVE=] solver finds the roots of arbitarry expressions (not limited to polynomials). In principle you can use it to find the roots of an expression. If it is a polynomial of dgree higher that 3 you can factor it (approximately).
Hope it helps.
Dec 09, 2008 | Casio fx-300ES Calculator
Cobra 757 codes
X stands for wide band radars(easy to detect,lots of false alarms)
K/Ka stands for pulse band radars(similar signal has auto doors)
W,L stands for laser detection (very little false signals)
Ku stands for signal most used on speed cameras
V stands for radar detectors detector
Have in mind that you can only lower your speed 20-30 km/h in city zones, and up to 50 km/h on highway.This depends on car,brakes and You.
Jun 16, 2008 | XRS-757 Radar Detector
XRS-757 Radar Detector Logo
499 people viewed this question
Top Cobra Vehicle Parts & Accessories Experts
Marvin
Marvin
Steve
Frank Mangiapane
Level 1 Expert
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
