Bought a PCI-E graphics card for the mobo. Unlpugged the power cord and opened the side panel, inserted the card on my table put it back together plugged it back up try to start and nothing won't start up. Reopened it took the card out try to start it up and nothing! Can u help? dont have any rug where I worked on so hopeing it aint electrostatic! Power supply green light is on also.
    Scholar:
  • 151 Answers
Some PCI-E cards require a special 6 pin power adapter, be sure that yours is connected if it is required.
I know that some PCI-e cards also require lots of power, if you are using a power supply less than 300 watts, your system may not be able to handle it.
also, check your BIOS settings. Your PC may still be trying to start off the on board video rather than the new PCI-E card.
Posted on Aug 09, 2010
Hi I have a supermicro x8sti Server Board inside
Basically you have two choices for installation of video card:
1. To purchase small form factor PCIe card suitable for installation on 1U server chasis or
2. Purchase PCI express riser card and to install most full-sized PCI Express cards (Check this link for PCI Riser )
Oct 04, 2013 | SUPERMICRO COMPUTER Supermicro X8STi-F...
ET1161-07 onboard Video gone bad. I tried a Gforce 8800GS 384mb card, that works, and I have no video, 1 long beep that never stops. Ican't get into the bios with the onboard video or the new video and...
Hi.
One continuous beep means that you probably have not put the graphics card in the PCI express slot or there is a short somewhere in the system.
Follow these steps to try and resolve the problem:
Remove the power cord and the video lead from the back of the machine and then remove the side panel to reveal the motherboard.
Remove the graphics card and take a look at the PCI Express slot for dust. If you see any dust get a clean, dry paintbrush and clean the dust from the slot and then blow on the slot to remove the rest of it.
Next look at the brass contacts on the graphics card and clean then. Re-seat the card making sure that it is fully pushed down in the slot.
Check that any other cards you have installed in the machine are seated properly.
Without putting the side panel back on, connect both the video lead and the power cord and turn it on. DON'T TOUCH ANYTHING INSIDE THE COMPUTER!!!
If the computer boots up turn it back off and put the side panel back on. If not then please post back telling me what the computer is doing.
Good luck.
Jun 07, 2011 | eMachines ET1161-07 Desktop PC
I have a compaq presario pc. Motherboard is Asus P5LP-LE : Lithium UL8E. I have 3 Gig of RAM installed, a 400w PSU. I have just purchased a new graphics card - Radeon HD5570. My MoBo has 1 PCI-E x16 and 3...
I think you have not connected power connector to your Radeon HD5570 .
This graphics card have 6pin power connector .
You need a 6pin power connector cable that comes with the graphics card box.
1.First connect your 6pin power connector to Graphics card.
2. Then connect other part of the cable to PSU.
Hope it will work for you.
Thanks for using FixYa.
May 14, 2011 | Computers & Internet
I need instructions on how to install a new Graphics card for my HP Pavilion a6600f. How do I go about doing it safely. I do not want to risk making a mistake. I will also be installing a new power...
From the manufacturer's web-site:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01357119&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=ca&lang=en&product=3794742#N201
this motherboard:
  • Also supports PCI Express x16 graphics cards
  • Turn the computer off.
    Disconnect the AC power cord.
    Disconnect the "data" cord from the "on-board" video-card.
    Remove the side-panel.
    Buy a PCI-E video-card.
    Insert the video-card into the PCI-slot -- make sure that it is fully "seated".
    Connect the "data" cord from the monitor to the new video-card.
    Replace the side-panel.
    Reconnect the AC power-cord.
    Turn the computer on, and let Windows "discover" the new video-card, and load new device-drivers.
    Dec 20, 2010 | HP Pavilion a6600f Desktop PC
    How do i replace the graphics card/ motherboard in my hp G60-121WM. Need disassembly steps
    1 . Before beginning any work on your computer, be sure to turn it completely off and then remove all connected cords or cables.
    2 . To get to the old graphics card the side panel of your computer's case must be removed. Most cases will have two screws that must be taken out at the top and bottom of the panel. Some cases will alternately have a twist off knob on the side instead of screws that simply needs to be turned several times until the panel slides off.
    3 . Once the panel is removed it is time to take out the old graphics card. The card will typically be held in place by a single screw connected to the case. Remove this screw and then simply pull the card straight out.
    4 . The new card is installed easily by pushing it into the correct slot on your motherboard and then putting the screw back in place. Depending on your motherboard, the card will either be connected to a PCI, PCI Express, or AGP card slot. The slots do not change the way that the card is installed, but it is important to make sure you have the correct type of card for the correct slot. A PCI card will not fit in an AGP slot and vice versa.
    5 . Place the side panel back on your computer's case and re-attach the screws or turn the twist knob until snug. Plug back in any cords or cables that were removed and power your computer back on.
    6 . A new graphics card will need to have drivers installed so that it works properly with your operating system. If your graphics card came with a CD, insert the CD into your computer and follow the on screen prompts to install the software. If your graphics card did not come with a CD then Windows may prompt you automatically to search for drivers to install
    Hope the above information will be helpful to you.
    Thanks.
    Dec 16, 2010 | Computers & Internet
    I have a Geforce 8400gs PCI video card
    Helo frnd i sugest u to reset ur bios by opening the mobo n find a jumper were clear cmos is written then fix the jumper to the other two sides oor read the mobo manual to do it
    Feb 19, 2010 | Asrock P4VM890 - Motherboard - micro ATX -...
    No signal problem with xfx 9400gt fatal1ty
    Check for bios jumper set for normal operation, check for onboard vga jumper set for pci or external video.
    Jul 14, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
    How to install device
    *Power down your pc
    1. Identify what interface does your motherboard has (AGP,PCI-E etc)
    2. open side panel case
    3.simply give space and insert your device on the designated slot on the mobo carefully(If it wont fit then it never will)*make sure it is inserted properly
    4.If it has a molex power connector, plug in one
    5.turn on and install drivers
    rate please hope it helps
    Jun 26, 2009 | ATI RADEON 9200 SE (128 MB) AGP Graphic...
    Want to disable onboard graphics to install and use pci vga card
    During the initial boot sequence (as soon as you turn your PC on), try pressing <DEL> button (or F2 or F10 - you will see info on the bottom of the screen stating something like "Press _____ (del, F2, F10) to go to Setup..."
    This will take you to BIOS, main setup panel for your PC.
    There you can find and option for switching your main GFX card.
    Options will be something like: onboard, pci, agp. You should choose
    PCI.
    Try doing this after you insert your new PCI gfx in your computer.
    Good luck,
    Milan
    Jun 01, 2009 | EliteGroup P4VMM2 Motherboard
    I want to install graphics driver in my system by downloading same from net so wat to do
    easy just install it take side panel off what one u need pci or agp or new pci express 16x ? what model cpu u have mobo
    Dec 09, 2007 | Graphics BV200 BizView 128MB (128 MB) PCI...
    Computers & Internet Logo
    Alun Cox
    David Payne
    David Payne
