Question about Lakewood HV 18-c Floor / Box Fan
How to oil lakewood fan floor model high velocity
bigg t
  • 640 Answers
SOURCE: lakewood floor fan
most likley the set screw that secures the blade to the motor is loose.
Posted on Aug 01, 2007
konzzz
  • 255 Answers
SOURCE: need help with fixing my lakewood floor fan.
try cleaning it and put oil especially at the base of the shaft.then try wiggling the shaft for bushing tolerance.if you feel the shaft wiggles to wide, then you'll need to replace the bushing and the shaft.but before anything else check the thermal fuse.it is found on the motor itself or try to borrow a tester with resistance measurement to check for continuity of the winding by connecting the probes with the plug, one each terminal.then turn the fan on.the pointer should move if its ok, unless burn out.if not.then the thermal fuse blow-out.
Posted on May 28, 2009
  • 109 Answers
SOURCE: Need to rewire Lakewood Fan
wires should be color coded. You can go to the hardware store and pick up some crimp connectors
Posted on Jul 07, 2009
  • 8404 Answers
SOURCE: I need a fan blade for a Aloha Breeze floor fan
check the big box stores for replacement blades.
Posted on Sep 29, 2009
SOURCE: my lakewood high speed floor model HV-21T stopped
Try replacing the "start-run" capacitor. It is the rectangular black box mounted on a tab next to the motor inside the cage, two wires attached (cut them close as close to the capacitor body as possible). Other symptoms include not moving at all with a hum, and getting very hot. The capacitor is a 5% tolerance 8 microfarad rated at 250vac. It doesn't have to be the exact form factor but it does have to be heat rated at or above 70C per design parameters of the fan.
WARNING! Make sure to protect the leads properly because this capacitor is connected directly to the power mains during operation. If one of the leads electrically shorted against the fan housing or cage could cause a catastrophic failure of the fan, and possibly a fire, and possibly give a nasty shock to whoever was switching on the fan at the time.
-Brandon
Posted on May 31, 2011
Do you bypass the run capacitator on a lakewood model hv-18 fan with a 2.4 motor
More than likely it's not the start capacitor why your fan will not run this more than likely it's not the start capacitor why your fan will not run this lubrication try turning the fan motor by hand if it does not turn freely it's lubrication I have answered this another post.
more than likely it is lubrication spray WD-40 into the oil holes after you have unplugged the fan of course Keep turning the fan and you'll notice will start turning more freely apply more oil to the rear of the motor as this is an oil bushing you're putting more oil into
hope this solves your problem
May 03, 2012 | Lakewood HV 18-c Floor / Box Fan
Polar Aire 20 In. 3-Speed High-Velocity Floor Fan on off switch wiring
i need an on/off switch for my utilitech 20" high velocity floor fan model # LF-20MCA
Mar 26, 2012 | Dryers
Since Lakewood doesn't make fans any longer, any idea where I could pick up a couple of their 9-inch high velocity fans (new or used)?
Hi randy r metc...
I found one 9" High Velocity fan on ebay, it is new at a cost of $19.99 and free shipping.
Please take time to rate me
To see the fan go to the following webpage
http://www.ebay.com/itm/Lakewood-9-High-Velocity-Fan-1016-/320745163838?pt=LH_DefaultDomain_0&hash=item4aade6cc3e
Aug 18, 2011 | Lakewood High Velocity Fan 9 Inch
Burning smell from motor when I plug cord in outlet. Also, blades do not turn.
if the smell is foul smelling the windings in the armature of the motor are shorted out against the metal housing of this armature. You need a new motor or replace the fan
Apr 08, 2010 | Lakewood High-Velocity Fan
Sep 28, 2009 | Dryers
Need help with fixing my lakewood floor fan.
May 28, 2009 | Lakewood HV 18-c Floor / Box Fan
Lakewood HV 18-c Floor / Box Fan Logo
165 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
