Question about Coleman Electric Cooler 40 Beverage Cooler
We are using a coleman model 5645 in our truck for about 5 months but it has stopped cooling. I notice ice on the inside top where the air comes out. Anything we can do as a first step?
  • 77 Answers
You can have the pressure checked if it's a gas refrigerator, if the gas is too low the coils will freeze over and won't actually cool the interior.
Posted on Feb 06, 2012
Look at Kool A Tron! They are a lot better!
Posted on Aug 25, 2010
Trying to find my model number on my coleman q.e.d II emerson model
Your unit can be low on freezon and can have stop up inside coils if air cant move across coils it will ice up on inside clean coils and check if unit still ice up it low in freezon.
Apr 08, 2014 | Coleman Heating & Cooling
I have an older Coleman in wall propane furnace, Model 2343.
compressed air or take apart and blow out also check gas pressure
Jun 28, 2012 | Coleman Propane Forced Air Heater...
I have a model 5645 and it has stopped cooling
the outside fan can be replaced with a 92 x 25 mm computer cooling fan. Inside fan is a 60 x 10 mm. Remove the cover on the inside by pulling straight up. Plug it in and check if the metal heat sink on the inside is getting cold. If it does, then the problem is one or both of the fans.
Mar 15, 2010 | Coleman Electric Cooler 40 Beverage Cooler
Coleman model 5645 inside fan motor not working .. how do you open the cover to get to the fan and motor
pull straight up on the cover. Remove the 4 screws that hold the fan to the heat sink. You can then remove the 2 torx screws and remove the heat sink if you need to. Clip the wires as close to the bad fan as possible so you will have enough for the new fan.
Feb 01, 2010 | Coleman Electric Cooler 40 Beverage Cooler
We have had a coleman central air system for 5 yrs. It stopped blowing cold air into the house about a week ago. You can still here it running but no air is coming out. my husband replaced the fuses and...
Ice is an indication that the refrigerant is not flashing off correctly in the evaporator coil. In most cases you can simply turn the unit off (until it completely thaws inside and out) and replace the filter. Make sure that all the vents in the house are open as well. If this does not work then you will need a technician to come out and check the refrigerant levels in the system. Ice can indicate that the refrigerant is low. I hope this helps.
Jul 08, 2008 | Coleman Heating & Cooling
Freezer up top cools but not at the bottom .
I think you must call a technician to check the air damper control and have an adjustment for the air passage to avoid clogging of ice to the air vent located at inside the freezer section cover.And to check if theres air leakage on the gasket of the fridge.
Apr 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
Coleman Electric Cooler 40 Beverage Cooler Logo
661 people viewed this question
Top Coleman Home Experts
Donni Steen
Tom Chichester
Are you a Coleman Home Expert? Answer questions, earn points and help others
