Question about Vacuums
Hi my Amazon Kindle (earliest model) froze up. No buttons or switches do anything. The battery is fully charged.
  • Mike Ayer Aug 09, 2010
    It didn't help but it's not the Expert's fault.
  • 2,272 Answers
1. Plug-in your charger. Sometimes the Kindle battery can get run-down enough so that it will "freeze." Plugging the charger in and giving your Kindle battery some much needed power often will un-freeze the screen.
2. If that doesn't work, try what is called a "soft reset." To do a soft reset on your Kindle press the <ALT>, <Shift>, and <R> keys simultaneously. Your Kindle screen should go blank or dark and then slowly come back to life.
3. When doing a soft reset doesn't work, you will occasionally have to do a "hard reset." To do a hard reset -
- Make sure your Kindle's battery is charged (about an hour of charging time should do it)
- Remove the charger cord from your Kindle
- Open the back of your Kindle
- Locate the small hole under the word "Reset"
- Open a small paper clip
- Insert the paper clip end into the hole and press GENTLY for about 10 seconds
- Your Kindle screen should go blank (or black) and then the Kindle should re-sta
4. When a hard reset doesn't work you can try to remove and replace the battery in your Kindle. This is a bit more complex but not too difficult
- Turn your Kindle off
- Locate the gray battery, and the finger-notch for removing the battery
- Gently press the battery toward the back of its compartment, then lift the battery out
- Locate the connector that attaches the battery to the Kindle
- GENTLY pull the battery connector out of the Kindle
- With the battery out of the Kindle turn it on for about 5 seconds
- Replace the battery and close the back cover of your Kindle
- Turn the Kindle on
If your Kindle is still "frozen" after completing the steps above, your next move is to contact the Amazon Kindle support team. Go to your Amazon account page - select "Manage my Kindle" and contact the support team from there.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 04, 2010
    Thanks for the tips. Nothing worked. I'm going to leave it overnight with the battery out.
Dyson handheld works for 30 seconds the cuts out
Hi Edward, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your Dyson handheld. In order to help further, we would need some additional information about your particular machine, including which Dyson handheld model you own. It would also be beneficial for us to talk you through some quick diagnostic checks when you have your machine fully charged and easily to hand. We should then be able to help you determine which part is at fault.
At your earliest convenience, please give our experts a call - you can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Feb 03, 2015 | Dyson Vacuums
IRobot will stop after few seconds ..
How old is the unit? It looks like the battery needs to be replaced.
Feb 24, 2008 | iRobot 4296 Robotic Vacuum
When I press the trigger the green light comes on but motor does not
Hi Perry, it's Jack at Dyson.
If the green light comes on when your DC35's trigger is pulled, but the machine does not run, this would usually signal that the battery has no charge.
The battery should recharge fully from depleted in 3.5 hours. However if your machine has been connected to the charger for at least this long and still won't run, it could mean there's an issue with either the charger or the battery.
We're happy to talk you through some simple diagnostic checks when you have your machine to hand, to help determine which part is at fault. At your earliest opportunity, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jan 26, 2015 | Dyson DC35 Handheld Vacuum
I have to press the button very hard and it work for one swipe, then it goes off, press it very hard again and the same thing happens!
Hi Alison, it\'s Jack at Dyson.
I\'m sorry to hear you\'re having difficulty with your DC44. In order to determine what\'s causing the intermittent power, we would need to take you through a few simple diagnostic checks when you have your machine easily to hand. If a replacement part is needed, we can also confirm if this is covered under your Dyson parts and labour guarantee.
At your earliest convenience, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We\'ll look forward to speaking with you.
Jan 05, 2015 | Dyson Animal Bagless Cordless Hand Vacuum,...
My dyson dc34 stops irraticaly
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC34 is cutting out in use. In order to determine which part of the vacuum may be at fault, we'd need to take you through some quick diagnostic checks when your machine is fully charged and easily to hand.
At your earliest convenience, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We'll be happy to provide further assistance, and if a replacement part is needed we can confirm if this is covered under our 2-year handheld warranty.
Oct 01, 2014 | Dyson Vacuum DC17 Belt 3-Pack; Replaces...
Battery is charged motor won't start
I am sorry to hear you are having difficulty with your DC35. Based on the details you provided we would appreciate the opportunity to trouble shoot with you and we may be able to resolve this issue over the phone.
At your earliest convenience, please call us directly at 1-866-693-9766 (US) or 0800 298 0298 (UK). We look forward to speaking with you.
Best wishes,
Jessica
Oct 02, 2012 | Dyson DC35 Handheld Vacuum
My amazon kindle is frozen
Resetting Kindle 2 is easy, all you need to do is follow 3 steps below:
  1. press and hold the power button for 15 seconds and then release.
  2. Once your kindle is Off remove the batteries for 10 seconds and reinsert it back.
  3. Turn On the Kindle.
kindle-reset.gif How to Reset the Amazon Kindle 1 Reseting kindle 1 is a little bit complicated than Kindle 2. Checkout the steps below:
  1. First, you need something pointed like a paper clip or the tip of your earing.
  2. Now, open the back cover of your kindle by pressing it firmly while sliding it to the right using your thumbs.
  3. You will then see the reset button as shown on the picture. Use the paper-clip or your earing's pointed tip to press on the reset button.
  4. A few seconds after pressing the button, your kindle will then reboot and will be restored.
Mar 10, 2011 | Vacuums
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Pulsing Amber - Charging
Green - Fully Charged
Amber - Partially Discharged
Red - Almost Fully Discharged
Flashing Red - Fully Discharged"
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
Seems to charge but then wont come on
Sounds like you bought a defective battery
You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
Vacuums Logo
637 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
