Error code 22 = short circuit protection. That means that the power source has detected a short on one of its output lines and has shut itself down for protection. To find the cause you must open the tv, find the output line that is shorted using an good AVOmeter then checking one by one the parts that are powered by that line, the failed part. To do that you need good electronics experience, otherwise you will not be able to interpret the indications of the meter.
If you don't have any then it's better to call a repairman.
This is pretty non specific!! One response on your website said this was the easier error to fix. Can you provide more details?
You know, there are around 150 parts on that power source. To find out which has failed you must test the board, as i said. I can't help you more because i don't have the unit in my hand to test it myself, you have to do that. If after testing you still don't know what is wrong then post here the results of the tests and ask for more help.
BTW it is one of the easiest failures to fix, a shorted component is much easier to find than a defective one.
Hi
Thanks for using FixYa. Error code 2-2 means short protect which is either caused by bad convergence ICs and/or 2 Pico fuses (F9A05 and F9A04). You’ll need to open the back of the unit and replace the parts that have gone bad to resolve this issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
If it was not complete then you could have posted back for more assistance as stated earlier. Please check this picture to know the location of convergence ICs:
Thanks
Rylee
Sorry about that; don't really know how your system works. The diagram below does not match with our tv; just took the back off. Model is WS 55411.
Thats fine, the diagram was just an example of convergence ICs location if yours does not have a black heat sink you can check this picture:
The earlier advice was less than complete; I need more information.
Model No. is 55411.
