Itouch will not connect to my zebra rw 420 printer via bluetooth.
SOURCE: Can't connect via Bluetooth connection problem
print a configuration label from the printer to get the BT settings, you may need to use "label vista"(zebra) to configure it. the keys are generated based of the BT mac
Posted on Nov 09, 2007
  • 3 Answers
SOURCE: zebra rw 420 mobile printer probleme with ink
Paper uspide down? Check the communication parameters in the printer setup.
Posted on Jan 13, 2010
  • 18 Answers
SOURCE: I can't connect to my HP Deskjet 460 via
Is your Deskjet still in the default "Private" mode? If so, change it to the "Public" mode.
In the toolbox, go to the printer services tab and choose configure Bluetooth settings. Change the mode to public mode.
Go to --> http:/h10025.www1.hp.com/ewfrf/wc/document?docname=c00625408&cc=us&lc=en&dlc=en&product=466208
Posted on Feb 09, 2010
  • 185 Answers
SOURCE: zebra QL320 plus no bluetooth discovery
Turn the printer up side down and remove the battery. Undo the philips screw and remove the module from the top. re-seat it back on the main PCB and replace the screw and battery. if the module still doesn't work then it is more than likely it has failed.
Posted on Apr 13, 2010
SOURCE: Bluetooth printing to an RW
Hi sorry to tell you but the addition of that CR to the end of a line, is a software issue, in that the as the program translates the material to be printed into the Format that the printer wants, it does so, BUT adds a CR after each 646 characters instead of say a binding space or en EOL marker? Maybe it whatever it is can be changed to this or removed altogether?
What is it? well this is difficult, but i am fairly sure i know what it most likely isn't?
Most likely this isn't the "Buffer" size? or perhaps the "Heap" size? maybe even it's "Page" size? maybe a "Frame" size? but that amount of data isn't a lot, as worked out below it's a little over say 5K of data if done at 8 bit, less if 4 bit?
Again 646 characters is only about 129 words ( 129.2 actually, Using accepted average of 5 letters for a word) again a strange value for anything that is meant to occur?
As for memory well, again, I don't think either so, as the math doesn't really stackup, so, 646 Characters, at say 8 bits a character this equals 5168bytes, or 5.06875Kb ? this is pretty meaningless? as "Memory Boundary"? is this all the Thermal printers memory will hold?
But if anything concerned only has about that much "memory" "address space", etc, etc, then THAT will be the culprit?
I would wonder though, if it isn't a "Bug" in the Fileutil class library? or a "Default" setting for some "Size" of something? that maybe able to be altered?
all I can say id good hunting...
Posted on Apr 23, 2011
Cannot connect to printer anymore
make sure you have the current drivers for this printer are loaded. and select the wired set up configuration type. go to control panel select printers and see if the printer is visable to your pc. if not start over and reconfigure a new printer. and
follow the prompts. and may i also suggest going to there web site and check for the latest and the greatest on your model.
Apr 09, 2017 | Zebra QL 420 Thermal Label Printer
What's your problem?reset my buetooth pass key on my rw420 moble printer
I'm trying to pair a Motorola CN50 device to a RW420 printer. On the CN50 device , I'm being asked for a 'passcode' to establish a secure connection. Is their a default code I could use to establish this connection or another possible work-around to doing this?
Sep 16, 2012 | Zebra RW 420 Printer
Need to have the print darker! /Zebra QL420Plus/ How can I set the darkness?
zgorbe723: The darkness is only setup via software. Adjust it in your Windows driver or including the heat command in your format:
CONTRAST n 'in CPL comtec syntax
^MD+n 'in ZPL zebra syntax
Roberto Martinez
padrino99@prodigy.net.mx
Aug 31, 2011 | Zebra QL 420 Plus Thermal Label Printer
Zebra QL320 plus no bluetooth discovery
Feb 12, 2010 | Zebra QL 320 Plus Thermal Printer
Zebra rw 420 mobile printer probleme with ink
Jan 07, 2010 | Zebra RW 420 Thermal Printer
Portable printers
Bluetooth should work fine (and save $). You have to make sure and spec out the printer with bluetooth. USB as a backup.
May 08, 2009 | Zebra RW 420 Thermal Printer
Connecting to printer via Bluetooth but driver is missing
using the bluetooth software on your computer, do not tell the computer you are looking for a bluetooth printer, instead, use search for all devices, then the printer will show-up and select it.
printing via bluetooth does not require a driver (it's just like printing from your cellphone)
Dec 27, 2008 | Zebra QL 420 Thermal Label Printer
Windows Mobile 5 and RW420
I don't if this matters for Windows Mobile or not but there is no driver listed for it based on the website:
http://www.zebra.com/id/zebra/na/en/index/drivers_downloads/drivers/results.html?productType=7
The problem is that Zebra printers use a PCL language to print with. Forms have to be programmed into the computer being used. Then they are downloaded into the application you are printing with.
These printers are designed for label and invoice use. The applications designed for them send the data over. They use them for delivery services to print with. I know bakery trucks use these in the vehicle. There not designed for straight text printing.
If you have ever seen label printers that they use for shipping out Fed Ex and UPS, that's what this printer does.
If you go to this link here you can get an idea as to how they are programmed:
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.html
If you have any questions about programming forms for them, let me know. I had to go to a special school in Atlanta several years ago to learn how to do that.
Sep 23, 2008 | Zebra RW 420 Printer
Sep 15, 2007 | Zebra QL 420 Thermal Label Printer
54 people viewed this question
jasbo
jasbo
