Question about Dryers
I have a roper rex 3514 dryer, not getting heat, tumbles fine
  • 76 Answers
SOURCE: Dryer runs, tumbles clothes, but does not heat
PSUinNC The first thing you have to do is to check in what position is the temperature switch . If the temperature switch is in the "air fluff" position, then the heater will stay "off". If this is not an issue, reset the circuit breaker. The motor needs only 120V to run, but the heater needs 240V and if one of legs is missing, the dryer would not heat. If it did not solve the problem, you have to perform full diagnosis. You will need some simple hand tools and a meter to check a continuity. If you are fillng you can handle it, let me know and I'll give you the step by step instructions. Gendos...post back
Posted on Feb 26, 2007
SOURCE: Roper Gas Dryer
On the front of the dryer there is a plastic hole cover. Take it off. If, when you start the dryer, you see it try to ignite (glow) but does not flame up, most likely the coils have gone bad. $20.00 online, $40.00 ata local store.
Posted on Dec 31, 2007
  • 139 Answers
SOURCE: Defy Tumble dryer not heating
Is this an electric dryer? If so, the most common problem would be a burned-out heating element. There could also be a defective temperature sensor inside. This will need to be evaluated by a qualified appliance repair technician to find the exact cause.
Posted on Jan 18, 2008
goofduck
  • 490 Answers
SOURCE: No heat in dryer
make sure the gas is on to the machine and then make sure gas is getting to the machine and then if still not heating check ignitor
Posted on Apr 14, 2009
jsrock516
  • 5911 Answers
SOURCE: My Roper elictric dryer is not drying clothes
If you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some tihings to check before assuming there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call. If you check everything and still have poor heating issues, please let me know. You may have an internal bias or hi-limit thermostat malfunctioning.
Posted on Jan 05, 2010
Testimonial: "Thanks, it was a very helpfull"
What would the heating element cost for this dryer? Roper rex 4634kqo
Hi Debora
$52.80 from sears parts direct.
Using the link below, it's part number 17.
Hope this helps.
-Steve
Mar 12, 2015 | Roper Dryers
My Roper dryer, model RED4100sq0, will tumble but not dry. Also, the timer does not run so the dryer runs continously after starting. There is no heat from the element. Both of these problems started at...
I fixed a roper dryer with a no heat problem and I did a youtube video you can google Roper Dryer no heat if my movie does not show but I gonna post it for you.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 30, 2013 | Roper Dryers
Dryer wont start
Does it tumble and not heat or just not start at all?
Nov 04, 2012 | Roper Dryers
Roper dryer model REX 3514RQ1. dryer works for/then quits. help!!
I have seen this before. You have got to remove the housing for the filter. Blow out the area around the blower and get the junk out of there. Wash out the filter housing.
Jul 06, 2009 | Dryers
Roper electric drier will not turn off or heat happened suddenly
Replace the heating element. Located in the backside of the dryer
Jan 04, 2009 | Roper REX4634KQ Electric Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
My dryer is a Roper mod # rex 3615ew1 it runs but not heating ?
first of all check your breaker. turn it off and back on. sometimes only one breaker will trip causing it to run with no heat.
other causes: heating element thermo switch burnt wire or cord ...
May 03, 2008 | Kenmore 63942 Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
