Question about Toshiba Satellite A135-S2276 Notebook
My toshiba satellite A205-S4587, freezes a short while after it has been booted. It is most of the time in an air condition room so hopefully the problem may not be over heating. Please help me.
  • 106 Answers
SOURCE: Toshiba Satellite A205-S4777 Camera help
sounds like the camera wires are broken. you would have to take apart the screen portion of the laptop to see if it is connected still. you would then have to splice the wires together if they are broken/damaged
Posted on May 23, 2008
SOURCE: Toshiba satellite A205-S5847 booting problem
Check your GraphicCard. Have you tried downgrading to XP and can you tell if you facing same problem?
Posted on Jul 26, 2008
  • 476 Answers
SOURCE: hot unlock bois password on toshiba
what OS are you running thanks XP or ????
  • 108 Answers
SOURCE: Toshiba satellite a205-s5804 laptop will not start
Hi, there are a couple of possibilities:
1. If you are able to start the laptop on battery then the dc connector on the motherboard may be broken or have come loose, in which case take it in for repair.
2. The power switch may be broken, again take it in for repair.
3. Tip of the trade: Disconnect the battery and plug in the charger, see if it will switch on. If not then put the battery back in with the mains still plugged in and see whether it springs back to life.
4. Tip of the trade 2: Leave well alone for a couple of days without any battery or power connected then plug back in and see if it will switch on.
Removing the BIOS memory, don't know where you saw that but not recommended at all unless you want to render your laptop completely useless. Don't attempt to strip down unless you are technically experienced with disassembling a laptop.
Posted on Jun 10, 2009
Geekman
  • 32281 Answers
SOURCE: toshiba satellite a205-S5847 cuts off while working
You could have an overheating problem, The CPU shuts down when it overheats and the laptop won't bootup until the CPU has cooled down.
The overheating problems are caused by a faulty fan or the heatsink/fan assembly is clogged with dust which prevents proper cooling.
Check the fan to see it it spins freely, if not (it has a bearing problem) then replace the fan. Also remove and vacuum the dust off the fan and heatsink.
Posted on Aug 19, 2009
My satellite a205 lcd is not working or blank
Are you able to connect it to an external monitor? If it works on an external monitor you know the issue is video/screen related rather then a main board issue.
Aug 26, 2013 | Toshiba Satellite A205-S4587 Notebook
Toshiba a205-s4707 will not boot windows from any location.
You didn't mention the DVD/CD rom? Shut down, unplug, remove battery, plug in reboot and try this procedure: http://www.ehow.com/how_5766144_restore-satellite-laptop-factory-disc.html
Dec 16, 2012 | Toshiba Satellite A205-S4707 Notebook
Cec_main.exe
This file is associated with the web cam software. You can try to uninstall the software and reinstall it. You can find the web cam software here (page 6):
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1702259&rpn=PSAF0U&modelFilter=A205-S4587&selCategory=3&selFamily=1073768663
Jun 02, 2010 | Toshiba Satellite A205-S4587 Notebook
Computer Shutdowns after displaying welcome screen toshiba written on that....
That is a hard drive issue. Swap it out, and your computer should work perfectly
Oct 16, 2009 | Toshiba Satellite A205-S4587 Notebook
Im having problem with my 2yr old Toshiba Satellite A205-S4577 laptop.when i plugged it in.my computer hangs up.what should i need to do.i have to work long hours and i cannot rely just on the battery....
this is the problem of power surge. get your system properly checked. or do one thing first you plug in the system the turn on the system. if problem persists get back to me.
Jul 09, 2009 | Toshiba Satellite A205-S4587 Notebook
I want to change the 2 x 512DDR ram by 2x 2GB DDR ram memories in my A205-S4577/Toshiba. Will it work?
hi,
it will work as your notebook is supporting maximum 4 gb RAM but please check that you are using 32 bit operating system or 64 bit one.
If it is 32 bit then the system will be showing 3.2 gb RAM only as this is the 32 bit os limitation.
Jun 03, 2009 | Toshiba Satellite A205-S4587 Notebook
Jul 26, 2008 | Toshiba Satellite A205-S4617 Notebook
My web cam
Without being there and checking, it sounds like a service is locking the cam at boot.
One thing to try would be to remove the device in device manager then reboot to reinstall it.
Jun 19, 2008 | Toshiba Satellite A205-S4587 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
131 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
