Question about LG Heating & Cooling
I just purchased an LG Model #. LP1010SNR just yesterday. I hooked it up and it seemed to run just fine. It was a floor model and did not come with owners manual. Itis intended to run for several hours at a time as it is used for a green house. When I checked on conditioner. It read on the digital display screen (P2). The power comes on. However, the P2 status will not let it turn on. It just beeps 5 times then stops and AC will not come on. I get nothing.
  • 4736 Answers
SOURCE: I lost my manual for
cruiznkay - Here is a link to your missing Owner's Manual, that you can download and print for future reference.You may have to open Internet Explorer to download it.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LP1010SNR&matchedModelCode=NOT_MATCHED&searchEngineModelCode=LP1010SNR&targetPage=support-product-profile&initialTab=documents#
Hope this helped you. Please let me know. Thanks.
Posted on Jun 10, 2011
SOURCE: I purchased and LG Model# LP1010SNR on 8-3-10 at
P2 means the water collection tank is full and needs to be drained. You have to pull the drain plug at the bottom of the unit and drain the water.
Posted on Aug 13, 2010
When you unscrew the bottom cap, there is a "rubber plug" you need to pull out. It is not on the diagram, go figure.
Posted on Aug 26, 2010
  • 83 Answers
SOURCE: can the LG LP1010SNR air
Hi there
According to LG nope. However this may help you
61f = 16C
63f = 17C
64f = 18C
66f = 19C
68f = 20C
70f = 21C
72f = 22C
73f = 23C
75f = 24C
77f = 25C
79f = 26C
80f = 27C
Regards
Gordon
Posted on Apr 17, 2011
hvac1960
  • 2133 Answers
SOURCE: I have the flashing P2
P2- cut off when coil temp is high due to short of gas. Please find leak testing and rectify.
Thanks.
Posted on Jun 29, 2011
I had a Kenmore Bottom Freezer Refrigerator installed yesterday and when the installer left he told me I could put all the food back in both the fridge and freezer. Today all my food in the freezer was...
Hello Amelia;
My Name is peter. I am a retired field service refrigeration technician.
You have a brand new unit off the floor. You do not have component failure problems.
You purchased a floor model. Floor models are set in the; "Demo Mode". In this mode your unit will not cool. Taking a unit out of the demo mode depends on the model. You need to contact your place of purchase to determine what buttons you need to press to get the unit out of the demo mode.
The people who deliver the units for Sears are contractors. Physical contract laborers. Most can not speak English.
I should know, I am a former Sears Home Service refrigeration/ A&E factory Service technician; all under the same umbrella. I have heard all the complaints about Sears deliveries.
Jul 25, 2012 | Refrigerators
LG portable a/c model LP1010SNR and after running for about 15 mins it reads E4
salaams......the unit will stop and display E4, when coil sensor reads temp less or equal to 2 degree centigrade.so deforst it. orrrrr when the coil temperature greater or equal to 8 degree centigrade.its from manual.
Sep 13, 2011 | LG LP0910WNR Air Conditioner
My LG lp1010snr AC's compressor only seems to run for about 3 minutes on and 3 minutes off, is the compressor being this intermittent normal or is there a problem?
This is called short cycling and it is a problem. It sounds like the compressor is getting hot and shutting off on a thermal overload. When the overload (bi-metal contacts) cool from the compressor being off they close and the compressor begins running again. The refrigerant gas cools your compressor windings, so there may a restriction present or a leak, which would cause the compressor to get hot and open on overload. This is not good for the compressor and will eventually ruin it.
Aug 03, 2011 | LG Heating & Cooling
We have the portable air condioner model LP1010snr and we have drained the tanks and still have the P2 warning. It will not start working. what can we do?
Turn the Master ON/Off Switch to OFF and unplug the unit for 15 minutes. Then plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the electronics reset and reverted back to the original factory settings.
Hope this helped you solve the problem.
Jul 09, 2011 | LG Heating & Cooling
I purchased and LG Model# LP1010SNR on 8-3-10 at Home Depot. It was a floor model and did not come with an owners manual. It has a digital display screen. It is intended to run for several hours at a time...
What happens on this unit is it will suddenly stop followed by a series of chimes. You can reset the unit, but it will end with the same set of chimes. My unit display had a P2 code. As mentioned above, I drained the water (small amount actually) in the shower. Note: There is a cap towards tha bottom of the unit that you will need to unscrew, then pull out the rubber plug. Fired up the unit after the water drain ... it worked fine. If they can make a GI Joe talk ... why can this unit simply say ... "Please Drain". P2 is so intuitive.
Aug 04, 2010 | LG Heating & Cooling
I have a LP1010SNR 10K BTu. Trying to install.
Yes. As long as the seal fills the gap from sill to unit the width will be just fine.
Jul 08, 2010 | LG Heating & Cooling
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
Hooking the monitor/computer to cable
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Computers & Internet
Heating & Cooling Logo
154 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
