Question about Vacuums
No power to the single cup coffee maker (model # 1360). the outlet is working. When I pushed the on button nogthing happeed.
  • 3,230 Answers
Well first of all you may please check out the followings -
1. Check the on/off switch - check to see that on/off switch is working fine.
2. The one-way valve can get clogged open or closed - You can out the debris that causes this problem with a toothpick.
3.The tubes may be get clogged - You can run vinegar through the machine once, and then run water through to clean out the vinegar.
Post comments if further you have the same problem.....
Good Luck!!
Thanks
Posted on Aug 04, 2010
I need a downloadable manuel for a Keurig single cup coffee maker Model B40
just go to keurig.com - they have manuals you can download there
the "b40" is the "elite/b40"
morelater
the show doctor
Aug 16, 2011 | Vacuums
Shows that it is ready to brew, but says "de scale"
What model do you have? I'm guessing we are talking coffee maker, is it a Keurig? If you're getting a message saying to "de-scale" it need a good cleaning. That's usually the issue & the quickest fix. If the Keurig (or any other coffee maker) gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off or keep making partial cups. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup or filters, also remove the reservoir carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir. Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This should eliminate your problem & should be done every 2-3 mths, regardless of whatever the model of coffee maker you have. Good Luck.
Jul 08, 2011 | Vacuums
Need to clean cuisinart 12 cup coffee on demand coffe pot. How do I clean?
Do you have the DCC-2000?
To delime a multi-cup coffee maker, mix white vinegar with water (1/3 vinegar and 2/3 water) and fill the water reservoir completely. Then turn the coffee maker on. Wait until the unit completes the "brewing" cycle and beeps 5 times. Turn off the coffee maker. Discard the liquid after the cycle. Then fill the reservoir with clean water and turn on again. When this cycle completes, again discard the liquid. Repeat the water rinse if you notice an odd taste to the coffee afterwards. (If the coffee maker still has deposits, repeat the vinegar cleaning cycle and rinse cycles.) There are commercial deliming products, mix them with water following the package directions.
The manual for the DCC-2000 is available as a link here: http://www.cuisinart.com/products/coffee_bar/dcc-2000.html . The direct link to the manual is http://www.cuisinart.com/share/pdf/manuals/dcc-2000.pdf .
I hope this helps.
Jun 19, 2011 | Vacuums
This is the first time I'm using my Mr Coffee Frappe maker and after plugging in the machine and pushing the power button, nothing happens. Should the red light come on right away?
yes you should get some kind of power indicated that power is on the machine i would first check the circuit breaker and then assure that you have power coming out of the outlet after which you could then use a multimeter to folow where you do have power going to sometimes it could also be a bad switch on the unit itself but first assure where you do have power going to and any further questions message me back Thanks Rick
May 19, 2011 | Vacuums
When i make a cup of coffee with my kuerig coffee maker my coffee is coming out with coffee grinds though it. how can i fix this problem?
Your coffe may be ground too finely for your maker.
Is your coffee maker flat-bottom or cone shaped? Or is it a french press?
Your coffee needs to be ground according to the brewing method. Too coarse and it will be watery, too fine and it will be too dark, or you might get grounds.
May 06, 2011 | Vacuums
I have a coffee maker that makes 36 cups of coffee. How many cups of ground coffee should I use to brew 36 cups?
I would ordinarily use half the amount of scoops of coffee as the amount of cups the coffee maker makes. A scoop being a Tablespoon of ground coffee. Less if you want it weak and one or two more if you want it very strong.
Apr 09, 2011 | Vacuums
B77 Keurig coffee maker won't dispense coffee if k cup is in holder. Help?
I had the same problem with my Keurig coffee maker. The needle is clean, and no deposits. Above the needle is a check valve. This is a simple fix. Open the K-cup arm and look up, in front of the needle housing is two silverish screws. Remove them and lower the arm but don't lock. Slide the black top cover out to expose supply hose and check valve. Carefully cut the zip tie and remove hose from check valve. Remove the two scres holding the valve in place and drop it down and out. Blow into the end where hose attaches. You should be able to blow thru, with some resistance. If you can't, thats your problem. Take a paper clip and carefully bend and insert into end where hose attaches, pushing ball in valve down alittle. Blow into it again, you should be able to now. If not, keep trying, it will go. When done re-assemble and run a cup of water, with out cup to clean it. Hope this helps ya!
Dec 07, 2010 | Vacuums
I need the manual for farberware fsu 236 coffee maker. How much coffee for 36 cups of water?
For medium strength coffee, start with about 2 cups of coffee. Adjust for taste in later batches until it's the strength you want.
Nov 24, 2010 | Vacuums
Vacuums Logo
13 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
