Eiki LC SVGA 870. on screen the image edges are blurred and the green colour edging can be seen
  • 76 Answers
It sounds like a polariser lens has failed, if so it may be cheaper to purchase a new projector than have it repaired.
Hope I was of assistance to you
Posted on Aug 05, 2011
Eiki LC-XC1 color problems
check all the optical parts around the blue lcd-panel, they might be darkened due to heat
May 07, 2012 | Eiki Office Equipment & Supplies
Projects blurry picture onto screen even after adjusting the focus. It is an EIKI Diamond Projector LC-SD10.
Did you connect signal with native resolution 800*600
blurred picture can also be caused by extreme contamination of optical parts
Aug 22, 2011 | Eiki LC-SD10 Projector Multimedia...
LC-XG200 bulbs where can I get one in the UK? At the moment my image looks blurred is that caused by the lamp or is some other issue?
In the first instance:
Adjust focus of the projector.
Make sure a projection screen is at least 4.1' (1.2m) from the projector.
Check Projection Lens to see if it needs cleaning.
NOTE : Moving a projector from a cool temperature location to a warm temperature location
may result in moisture condensation on Projection Lens. In such an event, leave a
projector OFF and wait until condensation disappears.
Apr 03, 2011 | Eiki LC XG200 Multimedia Projector
Eiki lc-sd15 has no power. The lights do not come on when plugged in and nothing works.
near the lamp door is a small hole with a resetable thermal fuse under it, try to push pin carefully
Jan 18, 2011 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
Can't find a reseasonable price for eiki replacement lamp lc sd15 6103177038
That is a Sanyo type lamp. Try searching ebay, there are several dealers that sell through there and ebay will search in price order for you.
Hope that helps
Dec 09, 2010 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
Model LC-SVGA 860 suddenly lost color, everything is monochrome.
If it is a DLP type projector and not an LCD, then you've broken your colour wheel. I would recommend professional replacement as it can be a bit fiddly and you need to source an exact genuine part.
Jan 17, 2010 | Eiki Office Equipment & Supplies
The projector switching off after 30 seconds
check the following :
1.does the lamp glow
2.do u get the connected image
3.if yes does the screen show temperature or overheat
4.if yes then one of the cooling fans do not work properly & hence the unit turns to standby & goes into protection
if no 1 does not happen, then check the lamp physically,it should not show melted or breakage.
if the lamp seems ok, then the ballast is defective!
Feb 08, 2009 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
Crt tv
This sound very simple. You might need to DEGOUES your tv. Try to find a small degouesing coil at a parts store. This will take 2 seconds to fix. Just plug in the coil and wave it in front of the screen, pull it away from the screen, and it is fixed.
Jun 12, 2008 | Televison & Video
Bulb Life
hi,
This is 2000 Hours, 160 Watts, UHP lamp. dont keep it on always.Check the usage and then replace the lamp. It's better to turn off the projector after each class.
The lamp is around $400.00 for Eiki LC-SD15.
Viren
Rave Services India
Feb 07, 2008 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
109 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
