Question about Gateway GT5220 PC Desktop
I hav a gateway vx700 monitor. I need 2 widen the screen , 4 i have about an inch all around. Where i see my desktop window. can u tell me how can i remedy this situation? Thanks so much.
    President:
  • 2,571 Answers
Change the resolution
control panel / display
Posted on Aug 04, 2010
Widen the screen on Westinghouse tv
Screens are controlled by ASPECT RATIO.
Monitors can have 4:3 16:9 and 16:10 ratios.
You are doing 1 of 3 things.
  1. You have a regular monitor and the tv and are duplicating the screen.
  2. You have a regular monitor and the TV and are extending the screen.
  3. You have just the tv connected.
Your video card has to have a screen resolution that meets the tv's ratio to have the tv take the full screen.
If your configuration is 1. the tv will only match the monitor resolution, so if you change the screen resolution, you may get bars on the monitor, and the tv will go wide screen.
if your configuration is 2. the tv is controlled independently and you can select it to change its resolution to an appropriate aspect resolution. *this requires that your video card gives you the correct screen resolution for your tv. not all displays will work.
If your configuration is 3. the tv is the only resolution that is being pushed and just adjust the resolution til the screen is filled in.
To adjust the screen resolution, right click on the desktop where there isnt an icon and select either Properties (windows xp) or Screen Resolution (windows vista, 7 and 8).
if you have 2 screens press the identify button and it will put a number on each screen. click the appropriate screen and go to the resolution dropdown below. Change, apply and if it doesn't look right, revert and try a different setting. if you try them all and it won't take up the full screen, then the video card can't push the video resolution your monitor wants.
Sep 30, 2014 | Computers & Internet
WIDEN MY DELL MONITOR SCREEN
I am unsure what you need o do. is it changing the resolution to make it fit? If not, then you can widen the screen by the monitor settings on the menu
Mar 16, 2013 | Dell Computers & Internet
Widen border on Toshiba lap top
Widen border on what? A document, if so go into page setup. If you're talking about the whole screen, go into the Desktop under the Control Panel and change the screen resolution.
Mar 30, 2012 | Computers & Internet
My screen is blank about half an inch on both sides.How do I get the screen to widen on both sides? Thank you
Just set your Display setting horizontal or vertical where you feel need, it is easy and simple.
Good Luck
Feb 04, 2011 | Dell Dimension 2400 PC Desktop
Gateway monitor pixels discolored on monitor
This happens when you keep a device close to monitor which uses wireless technology or signal(Cell phone, wireless router or modem). Also try to make distance between speakers and monitor, as speakers contains magnets and that causes such issues.
Nov 18, 2009 | Gateway Profile 5.5 Desktop PC w/17"...
Pixel Bands On Computer Screen
Try to connect other monitor.
May 13, 2009 | Gateway GT5220 PC Desktop
I have a 1 inch on the left and right side how do I get full scre
if you hav a monitor separate from your computer(not a laptop)then just use your settings on the monitor untill it works again the way you like it..
or for laptops and monitors with no controls on them go 2 control panel>>>>appearance and themes>>>>display. then click on the tab that says settings. go 2 advanced and the dpi setting should be set at 96....and if nothing changes go 2 the appearance tab then 2 advanced. and at the bottom for the item look for active window border and the size should say 1. if it does then keepo trying to make the number bigger so your page doesnt have a black border
Nov 30, 2008 | Gateway Computers & Internet
Hi i want to widen my screen
The Resolution can be changed in Windows XP by minimizing all applications, right clicking on the desktop, selecting Properties. In the Display Settings window go to the Settings tab. Here you can change the resolution. I think you are wanting to use a widescreen setup so going for a resolution of 1280x800 should fill your screen. Play around with the available settings to resize the screen.
If you are using MS Vista, you need to minimize all applications to the desktop, right click, select Personalize. In the Personalize Window click on Display Settings down the bottom, modify the resolution as appropriate.
Alternatively, you may be able to find the function key that did this to your resolution. Above your F1-F12 keys there should be a little picture. If you click on the [fn] key (near the Windows key) as well as one of the F1-F12 keys you can cause different functions to be performed. This may be how the resolution changed initially.
Good luck
Apr 23, 2008 | Toshiba Satellite A35-S159 Notebook
Need value of resistors R7A4 and R753 in a Gateway VX700 monitor. Chassis family V8705. Board bears the codes CT920A2600 and CT920A2600. The resistors are physically located around the high tension...
long time since i worked on one of those chassis but if i remember right there both 250k ohm 1/2 Watt carbon in series
but its more common for them to go open circuit if there burned you better check out the rest of the circuit around the LOPT stage
Feb 28, 2008 | Computers & Internet
Gateway GT5220 PC Desktop Logo
251 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
