What kind of cable to do I need for a TV to go from the wall box into the TV
    Problem Solver:
  • 9 Answers
You need a male to male aeriel cable
Posted on Apr 26, 2008
Fix tv picture
If the TV is receiving its signal from a cable TV box or DVR then you need to find out if the problem is in the TV or the cable box/DVR. Connect a different source to your TV such as a DVD or Blu-ray player and play a DVD movie. If the problem occurs again it suggests the TV needs repair. If the TV works OK when playing a DVD movie then that suggests that your cable box/DVR needs repair or replacement.
If your TV is receiving its signal directly from an antenna or cable outlet on the wall then you should try replacing the cable wire from the wall to the TV with a new wire. If that doesn't help then your TV probably needs repair or replacement.
Dec 29, 2015 | Sanyo Televison & Video
How do i setup my tv through surround sound without a cable box?
Unfortunately Without the cable box you will have to screw the coax cable into the coax input on the tv or You can screw the coax cable into a vcr and then plug the Audio / Video RCA plugs from VCR out to TV RCA input (You will have to control the channels from the VCR and the volume from the TV remote)
Dec 27, 2013 | Samsung Televison & Video
Do I need a coaxial cable connecting reciever to tv
Right. A cable from the TV out to the cable in port on the box then another coax from other port on the box RO the wall.
Nov 12, 2011 | Electronics - Others
I can not program the tv with the cable, which input goes with the cable channel. I have a 32 inch RCA with SRS . HELP
I do not see a question. "Which input goes with the cable channel?" Don't understand. Is there a cable box or SAT box connected to the TV? What kind of cable is running to the TV from the source? If you just have the coax cable going from the wall to the TV, then you need to auto format the channels. Select menu on the TV remote. Find Sources or Cable. Select "Cable" not "Air". Select Auto Format. May take several minutes. Input selector from TV remote should be "TV".
Jun 30, 2010 | RCA Televison & Video
Setting up a new TV
you will receive upwards to 150 channels (depends on how the tv is designed) you will not receive all the channels which you receive on the tv which has the "box". You will need an addtional box if you want to receive essentially any 200 or above channel.
Hope this helps
Apr 12, 2010 | Samsung Televison & Video
The list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
Mar 01, 2010 | Televison & Video
Direct TV satellite to TV connection issue
hi cable from the wall into the box then a cable from the box into the tv or hdmi cable from the box to the tv thanks
shaun
Jun 13, 2017 | Toshiba Televison & Video
We lost power the other night when it cam on there was no power to my cable box or tv the outlets still work because i plugged something else in them is there a reset button on the tv
Is the TV connected directly to the outlet in the wall or through a power outlet on the cable box? If so connect the TV directly to the wall and see at least if it does power up. If it does than the cable box is bad and will need to be replaced. If neither the cable box or TV power up when connected directly to the outlet then the possibility is you had a power surge that damaged both.
Nov 17, 2009 | Televison & Video
Connect from wall cable to tv.
you are trying to use a monitor as a tv, you will need a tuner to get a pic, use a cable box or digital to analog tuner to get something
Nov 17, 2009 | Polaroid FLM-3701 Television
I have an Olevia 23t lct hd tv. I am plugged in
you said you are using composite cables..? that means you have some kind of cable box ? if you want to get HD channels you have to use a HD box that is supplied by the cable company.. the HD cable box then has to connect to the tv with component cables (green,blue, red cables) or HDMI cable.. to send the HD signal to the television.
May 13, 2009 | Olevia 237T 37 in. LCD TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
