Question about LG AX245 Cellular Phone
I want to know how to completely deplete the battery before charging it again
    Guru:
  • 19 Answers
Use your cell as long as its battery depletes completely itself or play Music, Games or call in order to deplete your battery completely.
When your cell gives "Empty Battery" or "Low battery" type warning for three times and turns off itself your cell's battery is empty then. Recharge it till its battery full to have more talk time then usually you have.
Posted on Aug 04, 2010
  • donna_smi103 Aug 04, 2010
    i already knew that much - but i know on some of the older (older than this one!) that there was a key combo that would "discharge" the battery - i wondered if there was a way to do that on this phone
  • Babar Khan Aug 05, 2010
    I am not sure if there is such code for LG phones, although it is for Nokia. But here is some thing that might help you:
    http://www.fixya.com/support/r5482192-lg...
How do you know when the battery is charge
Hi there, it's Jack at Dyson.
If your machine's charge has been completely depleted, it will take a maximum of 3.5 hours to recharge again completely. When it's fully charged, the light on the charger will go out. You can either plug the charger cord directly into the machine, or store and recharge the machine in its docking station.
I hope this helps, but if you'd like any further information you're welcome to contact us directly. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 29, 2014 | Dyson DC35 Handheld Vacuum
Power schemes battery
Chances are that your battery doesn't / wouldn't hold a charge anymore. The laptop runs off battery power. When it is plugged in, the AC power "goes right through the battery", to support the laptop's operations. When the power cord is unplugged, and the battery doesn't hold a charge, the laptop will shut down, as your battery is (too) low to continue supporting the laptop's operations.
The easiest way around this problem is to get a new battery for the laptop.
If your battery is (quite) new (and a Lithium battery), you may wish to see if you can "revive" the battery's "life" ... first by depleting the battery (completely), then charging it (until it shows it is full, plus a couple more hours), and repeating this process a few times. If you're lucky, the battery will slowly/gradually start to hold some charge, but, don't expect it to be very long.
The (preferred) way to use re-chargeable batteries is to charge it fully, unplug it from the external power source, use it until it is depleted, then plug in the external power source to charge it up (fully) again .... and NOT to keep it on a power source all the time.
Oct 26, 2013 | Lenovo G500 59373039 Intel Core i5-3230M...
New phone that I've used for a week without problems. Yesterday it shut itself off and I tried to charge but it won't stay charging and I can't get it to stay on. It will say it is charging for about 30...
Battery of device been depleted completely of functionality requiring a new replacement. Refer with the device user for details with power malfunctions also recommending direction to resolvment
Apr 04, 2011 | Cell Phones
My sony wega trinitron srs bbe won't power on
Power on is indication of current supply malfunction. For example, the battery supply requiring recharge before powers back on again once depleted of supply at prior usage. A completely depleted device battery would require full battery recharge before any images are displayable once more. Ascertain the full charge duration requirement to perform battery charging. Meanwhile, inspect the device for power device maladjsutments. For example, the battery compartment may have malalligned due to impact. verify that each compartments contributing towards powering up is in place. Open battery compartments to ascertain integrity. Thereafter, plugging device to power source should restore default power functioanlity soon after full charge is acheived. Also, the process of powering on the device may require continously pressing on extensively to acheive restore display for images. Refer to the device user manuals for diagnostic on power malfcuntions. Consult technical experts when required. Good luck
Jan 08, 2011 | Televison & Video
I HAVE 18/24V DEWALT NI-CD BATTERIES THAT LOSE CHARGE CAN THEY BE REPAIRED, THEY DO NOT HOLD CHARGE CAN SPARES BE PURCHASED OR BATTERIES EXCHANGED
completely drain all the batteries by taping the on switch and, letting the drill run until it stops.
then recharge again do this three times for each battery ( these batteries have a "memory" and, only recharge to the level of last topoff if this does not work the chemicals in the battery are depleted and, must be replaced they can be purchased from Dewalt.com
Sep 14, 2009 | Drills
Motorola CP040 charging time
The rapid rate charger WPLN41__ will typically charge a battery in 90-120 minutes. Your battery should be depleted or nearly depleted when you place it in the charging stand. Be certain your radio is always turned off, when charging an attached battery. The NiMH battery will generally go 12-16 hours on a charge when new. If you work an eight hour shift, you might see if the radio will go 2 days on a charge. Later as the battery ages, you will need to charge it nightly. (Think of putting it in the charger as putting it to bed at night.)
Rapid charging is necessary on NiMH and Li-Ion batteries. They require a "hotter" charger, a fast rate, to completely charge the battery. It will not harm this chemistry of battery. It is safe to leave the battery on the charger overnight, or for a weekend. We would not recommend leaving the battery on the charger longer periods of time, as that will age the battery and reduce its life.
(Sidenote: Frequent rapid charging will however reduce the life of a NiCD battery.)
Aug 12, 2009 | Motorola Radio Communications
Radio Reset on PPT
The Battery Pack:KEBT-071-B was memory depleted. Just Try using Alkaline Batteries and test again, if the test results OK, Memory Discharge de Battery Pack Full Discharge and them complete the charge Cycle Again until the Memory Charge error disapear, or optional Buy a new Battery Pack.
Jun 12, 2009 | Motorola T8500 Two Way Radio
LG AX245 Cellular Phone Logo
63 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
