SanDisk 4GB microSD High Capacity Memory Card Logo
Anonymous Posted on Aug 04, 2010
I was trying to do different things with my SD card and my phone gave me an option of formatting the card so I did not know what that meant so I went ahead and did it now my card is wiped clean and none of my saved photos sounds or anything are on my phone they are just gone
Roy
Level 3:
  • Master 2,571 Answers
  • Posted on Aug 04, 2010
Roy
Master
Level 3:
Answers
2571
Questions
0
Helped
494515
Points
7959
That what happens when you format. BUT... you may be in luck, there are a few free recovery programs that should be able to recover your files.
Recuva from pirnform. http://www.piriform.com/recuva
file recovery tools from PCTools http://www.pctools.com/file-recover/download/?ref=google_fr&gclid=CODt1_2soKMCFVeX2AodKg0mpA
Testimonial: "Thank you rcw1962 your help was awesome I can never thank you enough"
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
203
Points
Having network problem on my mobile phone Samsung j700
Anonymous
Level 3:
  • Master 506 Answers
Anonymous
Master
Level 3:
Answers
506
Questions
Helped
119809
Points
1487
You can get you data back with some software if that is the first time you are formating the drive. Use getdaback software connect the phone computer using a USB cable you can recover you lost data
How do i get muve music to work on a sd card thats not from cricket?
I don't use move music so I just put a new one in. Since my SD card wasn't dead all the time, I was able to copy it off to my computer.
After inserting the new card, formatted it, and all I restored were my pics. That's all I needed.
Two other options you can try:
https://play.google.com/store/apps/details?id=com.sandisk.shima.fixer
http://www.mycricket.com/support/faq/how-do-i-get-the-free-muve-music-sd-card
2answers
HP Photosmart M425 card has wrong format press ok to format card unable to format
You could try formatting it in My Computer on PC by right clicking on its icon to bring down the option, then format again in the camera to ensure compatibility
2GB Micro SD needs format code that I never gave it
You can format your micro-SD Card using a software which you can download by clicking this link. I uploaded it to my FTP site for you and it will be there for a limited time. Download that file and save it to your PC. Then unzip that ".zip" file.
If you format micro SD card connecting it to your PC via USB port, it may not ask for password. (I think your phone asks password to format.)
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
Hope this helps you.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
I have a motorola i856 phone and I guess the phone does not recongize the sd card... I have went to the memory card option under ''settings'' but there is no option of formatting it! Help!
To acsess the memory card settings and format on a motorola i856 you need to first look in the settings menu then Memory card here you should find Foemat card and also help.
This is the standard menu layout your phone may differ
My sandisk micro sd card got locked up. even i
nothing new. It happens a lot . sry but ur memory card data will be deleted./. u will have to format it.. that is the only option ..connect it to pc via card reader and format ur card
2answers
I bought a new mico sd card for my nokia 6233 bu it keeps sayin memory card not formatted hw cani format it
Dear
There Are two ways to format sd card
1) by Phone : Go to Memory card option
Gallery - memory card - option - format
& ur card will be formatted
2) By pc : connect ur phone to pc or sd card reader & right click on removable disk which is your sd card's slot & select format option.
Then it will ask for custom & quick format, select one from them & ur card will be formatted
Thanks & regards
4helpful
4answers
How to format the microSD?
actually u shold format it by the device in which u are going to use. eg camera. This will enable correct formating for usage of this device.
otherwise their is a standard Sd format and u can use that to format
You can format the card by SD card Utility. SD utility is a format utility which is release from SD Association. It is a standard for all SD type card and will self determine the SD card's file system. Please kindly refer to the link below for SD format utility download webpage.
http://www.sdcard.org/about/downloads/
48helpful
6answers
Unable to download songs onto SD card
umm i just want to learn how to put stuff onto my sd then on my wii
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
